Greetings lovely community,
I tend to use both a mix of the Tilix terminal and pamac
application to search, update, install/remove packages, etc. The terminal part of it I understand for the most part (not always of course!), but for pamac
I wonder if the default settings are the way to go or if the settings I adjusted in pamac
are acceptable, please do let me know your opinions. I just want to double check and make sure I’m doing things the “correct way” aka in a way that won’t cause unintended issues in the future.
Below is a rundown of my pamac
settings. Please let me know if my adjusts are acceptable or if I need to change or revert any of the changes I made, thank you. Also, feel free to explain any of the settings if you so wish to, I do enjoy reading and learning more about the underlying Arch-base! Any help/comments is greatly appreciated, thank you!
