Hello, everyone, glad to be here.
I have been using manjaro for a while, it works fine. But recently I have run into a problem. Sometimes a program window can get dimmer, especially chromium. it looks like this:
Screen area other than program window is brighter.
I have no idea what went wrong, but I noticed that oftentimes it happens after a chain of right-clicking save-as.
What could be the cause? Thanks.
System info:
Do you happen to have the “dim inactive windows” effect enabled?
I checked it out that the option is unchecked.
Wow, my gosh, it could be this option’s fault. let’s uncheck it and have a see :—).
Thanks for the clue.
Could it be that when a program’s main window opens a dialog, the main window becomes inactive. When the dialog is closed, it becomes active again.
So there’s a switch to and fro in between.
But sometimes it might go out of order. Anyway, i’ll try it out.
system
Closed
17 November 2021 14:39
5
