I can honestly then say:
Because, I don’t know further…
Thank you for the help I really loved manjaro, the people and the OS itself I don’t want to go but I guess I don’t have any other option until i build my pc where battery won’t create any fuss. I am not even able to update bios from linux
. I know there would be a way to do so using USB or something.
I have to agree.
Updating system BIOS to latest version (F.21 Rev.A - Dec 27, 2023) would need a Windows OS
This is a known limitation for HP systems, so experienced forum users would not suggest updating BIOS unless inxi -Aa data shows a dual-boot system
I think you can use Hiren’s BootCD PE for that.
A BIOS can usually be updated via the BIOS itself, using a fat32 formatted USB drive; that is, unless HP have graciously locked out their Users from doing so.
That’s how I did mine, but like you mentioned, it depends…
That is correct for vendors which do not use LVFS: Device List
However HP does LVFS: Search Results
So you can do a firmware update using
sudo fwupdmgr get-updates
Then
sudo fwupdmgr upgrade
ArchWiki - Flashing BIOS from Linux - Windows PE
If your manufacturer only provides an exe file and you were not successful following the prior advice, you can update your bios creating a Windows PE flash drive and from there flash the bios update as normally.
ArchWiki - Flashing BIOS from Linux - Vendor Specific - HP
Warning: Not all HP BIOSes are the same. A method that may work in one of their models may or may not work in another model.For eg. neither of the below methods work with the HP T730 Thin Client.
i think it’s just a limitation of how some laptops work;they rely on the external PSU; even if your battery is at 100%.
i have an ASUS tuf laptop and when gaming, it uses both power sources and you can see the battery slowly draining even though it’s plugged.
i noticed that in general removing the power adapter would result in slower performance,and i have cpu power set to performance.
Hey everyone thank you for helping me out. So I jumped onto windows and guess what I was facing same problem with windows now.Even after bios update and everything. I came across a blog tho. I’m not able to attach link here. But it is on wintipsdotorg (fix-cpu-not-running-at-full-speed-in-windows-10) I tried everything still was facing same issue. But at last I tried throttlestop method which turns of bd_prochot. Do you think similar thing can be achieved in linux? If yes how can do it. Thank you in advance. I wanna move back to manjaro I miss pacman from windows.
I finally found the issue and the solution. For anyone having same issue as me this might be of help.
PC : HP Pavilion CS 3006tx
Processor : Intel I5 10th generation
So the problem was my PC would throttle the CPU frequency on battery and it was very slow
Solution : on windows you can use throttlestop to do this but on linux you can use msr-tools (disabling bd_prochot)
Install msr-tools
pacman -S msr-tools
Load msr module
sudo modprobe msr
Read 0x1FC register on all cores and output as decimal
sudo rdmsr -a -d 0x1FC
2359391
2359391
2359391
2359391
Switch off the bd-prochot bit by subtracting 1 from the decimal output above. Do not copy paste the below command, but take the output of above command, subtract 1 and replace 2359390 with that.
sudo wrmsr 0x1FC 2359390
If this line gives error you might want to disable secure boot.
credits and useful blogs :
https://github.com/DivyanshuVerma/throttlestop-linux
https://www.wintips.org/fix-cpu-not-running-at-full-speed-in-windows-10/
