I’ve spent most of the week looking to resolve my current issues with KDE/Plasma/Dual Monitor setups (AMD) and the one thing that I have noticed is that most people don’t respond or reply when anyone greets them with the following message
Start here, specifically the first part…
How to provide good information
Though I truly believe it’s the right message, I think it might not be so wonderful to read through a long post - especially if you’re currently frustrated with the issue you have. There is really good tool you mention in that post
Manjaro Log Helper (automated log generator GUI)
which I believe should be at the beginning of that post or used as part of the greeting message - I think it may encourage people to install it and therefore have an easier journey explaining their problems.
As an end user myself, I rarely use the terminal and find adding commands there a little scary (some times) I have been using Manjaro for a few years now and I can’t see myself going anywhere else.
Anyway - I need to keep hunting for my issues.
Have a great day & thank you for taking the time to help others make Manjaro a success.
