I have a Dell Latitude 7390 2-in-1, with a pen. I’m using Manjaro with the standard Gnome desktop environment.
The pen works out of the box, unfortunately for whatever reason it will stop being picked up by the wacom sensor and then it will start being detected again. When it works, the pen functions really well, but these interruptions make it unusable for any actual work.
I’m completely at a loss about how to even start troubleshooting the issue. For example, the command xev, doesn’t seem to announce anything when the stylus/pen is picked up. Also the touchpad and stylus configuration has nothing to help.
Finally I can report that I have a separate Wacom Intuos tablet, which runs over bluetooth, that works reliably.
Hello,
Is this your model?
https://wiki.archlinux.org/index.php/Dell_XPS_13_2-in-1_(7390)
Maybe you find some useful information there.
Do you have xf86-input-wacom
package installed? Some Stylus models require that to work properly.
Hi, thanks for your reply. My machine is a Lattitude 7390, not an XPS 7390, but I don’t think it’s important.
xf86-wacom-input was installed, and as I said the pen works (there is even pressure sensitivity) the issue is just that it sporadically stops being detected. For example it will stop working while I am writing, like right in thr middle of a word, and then a few seconds later start working again.
I’m really looking for a way to diagnose the issue. Maybe a log of some sorts.
Is there some log file, or other program that gives some kind of output once a pen/stylus is picked up and once it is no longer picked up?
Hmm… okay. Well I did some digging around and found: gttps://medium.com/tutorials-with-ganofins/how-to-enable-or-disable-the-touchscreen-in-manjaro-or-arch-linux-dce1f7fd349e. Which mentions the utility xinput
(installed via the package xorg-xinput
Running xinput list
shows my pen has id=11
and running xinput query-status 11
(xinput query-status 11 | tail
for a shorter version) gives:
ValuatorClass Mode=Absolute Proximity=Out
valuator[0]=19386
valuator[1]=3097
valuator[2]=8
valuator[3]=0
valuator[4]=0
valuator[5]=-900
when the pen is not detected and when the pen is detected I get
ValuatorClass Mode=Absolute Proximity=In
If I write for long enough the pen switches from Proximity=In
to Proximity=Out
even though I am in the middle of writing a word. Eventually the pen is picked up again.
Running xinput list
shows:
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ DELL0823:00 044E:120A Touchpad id=14 [slave pointer (2)]
⎜ ↳ Wacom HID 4841 Pen stylus id=11 [slave pointer (2)]
⎜ ↳ Wacom HID 4841 Pen eraser id=21 [slave pointer (2)]
⎜ ↳ MOSART Semi. 2.4G RF Keyboard & Mouse id=22 [slave pointer (2)]
⎜ ↳ MOSART Semi. 2.4G RF Keyboard & Mouse Consumer Control id=24 [slave pointer (2)]
⎜ ↳ Wacom HID 4841 Finger touch id=12 [slave pointer (2)]
⎜ ↳ DELL0823:00 044E:120A Mouse id=13 [slave pointer (2)]
I tried disabling certain other pointers but with no luck.
Update: It was actually a “hardware” issue, which was resolved by removing and re-inserting the batteries into the pen. See here: https://github.com/linuxwacom/wacom-hid-descriptors/issues/49#issuecomment-694853480
