Hello again,
Revisiting this post… Integrated Lenovo Yoga pen: button assignments wrong following update 2025-09-26
I’m having problems with my pen, this time more severe and not fixable through a rnote setting.
The pen is not working whatsoever in the program. The pen itself is being recognised on the screen → the cursor inside rnote is working and is following the pen - but clicking anywhere in the app does not work; not even the minimise/maximise/close buttons.
Rnote was not updated in 2 months and before this manjaro update everything worked.
Lenovo ThinkPad Yoga X13 Gen 4
It doesn’t work with any pen - but the pen I have for testing is the integrated Lenovo pen (I tested with a pen of a friend in university)
inxi -zv8:
Kernel: 6.12.61-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=a46e20e3-0afc-49b5-9200-1e62e08cbc01 rw rootflags=subvol=@
loglevel=3 systemd.show_status=1
resume=UUID=6c9e9761-e2fd-4cdd-bdf1-def6241b42c9 udev.log_priority=3
nmi_watchdog=0 nowatchdog modprobe.blacklist=i2c_i801
Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
Type: Convertible System: LENOVO product: 21F2CTO1WW
v: ThinkPad X13 Yoga Gen 4 serial: <superuser required> Chassis: type: 31
Mobo: LENOVO model: 21F2CTO1WW serial: <superuser required>
part-nu: LENOVO_MT_21F2_BU_Think_FM_ThinkPad X13 Yoga Gen 4
uuid: <superuser required> Firmware: UEFI vendor: LENOVO
v: N3OET38W (1.21 ) date: 06/24/2025
ID-1: BAT0 charge: 48.3 Wh (97.2%) condition: 49.7/54.7 Wh (90.9%)
power: 10.8 W volts: 17.11 min: 15.48 model: BYD 5B11H56369 type: Li-poly
serial: <filter> charging: status: discharging control: start: 0%
end: 100% cycles: 220
Device-1: wacom_battery_2 model: Wacom HID 5354 serial: N/A charge: 100%
status: N/A
System RAM: total: 32 GiB available: 31.02 GiB used: 9.6 GiB (30.9%)
Array-1: capacity: 32 GiB slots: 8 modules: 8 EC: None
max-module-size: 4 GiB note: est.
Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
size: 4 GiB speed: spec: 6400 MT/s actual: 4800 MT/s volts: curr: 0.5
width (bits): data: 16 total: 16 manufacturer: Samsung
part-no: K3KL9L90CM-MGCT serial: N/A
Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
Info: model: 13th Gen Intel Core i5-1335U bits: 64 type: MST AMCP
arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xBA (186) stepping: 3 microcode: 0x6133
Topology: cpus: 1x dies: 1 clusters: 4 cores: 10 threads: 12 mt: 2 tpc: 2
st: 8 smt: enabled cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32
KiB, 8x64 KiB L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 601 min/max: 400/4600:3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 601 2: 601 3: 601 4: 601 5: 601 6: 601 7: 601
8: 601 9: 601 10: 601 11: 601 12: 601 bogomips: 59916
de ds_cpl dtes64 dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase
fsrm fxsr gfni hfi ht hwp hwp_act_window hwp_epp hwp_notify hwp_pkg_req
ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid lahf_lm lm mca mce
md_clear mmx monitor movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx
ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt
pse pse36 pts rdpid rdrand rdseed rdtscp rep_good sdbg sep serialize
sha_ni smap smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip user_shstk vaes vme vpclmulqdq waitpkg x2apic xgetbv1
xsave xsavec xsaveopt xsaves xtopology xtpr
conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: Lenovo driver: i915
v: kernel alternate: xe arch: Xe process: Intel 7 (10nm) built: 2022+ ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:a7a1 class-ID: 0300
Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:5 chip-ID: 174f:11a8
alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x0b86 built: 2022 res:
mode: 1920x1200 hz: 60 scale: 100% (1) dpi: 171 gamma: 1.2 chroma: red:
x: 0.655 y: 0.322 green: x: 0.298 y: 0.600 blue: x: 0.141 y: 0.063 white:
x: 0.325 y: 0.345 size: 286x179mm (11.26x7.05") diag: 337mm (13.3")
ratio: 16:10 modes: 1920x1200
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (RPL-U)
device-ID: 8086:a7a1 memory: 30.29 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.328 layers: 6 device: 0 type: integrated-gpu name: Intel
Iris Xe Graphics (RPL-U) driver: mesa intel v: 25.3.1-arch1.2
device-ID: 8086:a7a1 surfaces: N/A
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Lenovo
driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51ca class-ID: 0403
API: ALSA v: k6.12.61-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
IF-ID-1: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> scope: global
IF-ID-2: wwp0s20f0u2 state: down mac: <filter>
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:6 chip-ID: 8087:0033
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 106.17 GiB (22.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN740 SDDQNQD-512G-1201 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 73117101 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 36.68 GiB (36.7%)
fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3 label: Root
uuid: a46e20e3-0afc-49b5-9200-1e62e08cbc01
used: 748 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI
uuid: 78B1-C149
ID-3: /home raw-size: 343.44 GiB size: 343.44 GiB (100.00%)
used: 69.49 GiB (20.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: Home uuid: 17b374a9-bf64-40b4-a327-0274e0018dff
ID-4: /var/cache raw-size: 100 GiB size: 100 GiB (100.00%)
used: 36.68 GiB (36.7%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
label: Root uuid: a46e20e3-0afc-49b5-9200-1e62e08cbc01
ID-5: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: partition size: 33.2 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4 label: Linuxswap
uuid: 6c9e9761-e2fd-4cdd-bdf1-def6241b42c9
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:2 info: Logitech USB Receiver type: mouse,keyboard,HID
lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c547 class-ID: 0300
Device-2: 3-2:3 info: Quectel Wireless Solutions EM05-G
type: communication,CDC-data driver: cdc_mbim,option,option1 interfaces: 3
rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA
chip-ID: 2c7c:030a class-ID: 0a00
Device-3: 3-3:4 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 27c6:6594 class-ID: ef00 serial: <filter>
Device-4: 3-4:5 info: Syntek Integrated Camera type: video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 174f:11a8 class-ID: fe01
serial: <filter>
Device-5: 3-10:6 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0033 class-ID: e001
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 3766
Packages: pm: pacman pkgs: 1699 libs: 399 tools: pamac,paru pm: flatpak
pkgs: 0
1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
2: https://mirror.init7.net/manjaro/stable/$repo/$arch
3: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
4: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
5: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
6: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 433
1: cpu: 100% command: ps pid: 77090 mem: 4.30 MiB (0.0%)
2: cpu: 22.1% command: zen-bin pid: 74670 mem: 449.1 MiB (1.4%)
3: cpu: 13.0% command: kwin_wayland pid: 1881 mem: 315.8 MiB (0.9%)
4: cpu: 11.6% command: zen-bin pid: 3328 mem: 715.3 MiB (2.2%)
5: cpu: 5.7% command: steam pid: 61189 mem: 230.9 MiB (0.7%)
Memory top: 5 of 433
1: mem: 715.3 MiB (2.2%) command: zen-bin pid: 3328 cpu: 11.6%
2: mem: 622.4 MiB (1.9%) command: ./steamwebhelper pid: 61386 cpu: 1.7%
3: mem: 606.5 MiB (1.9%) command: exe pid: 57791 cpu: 5.0%
4: mem: 605.4 MiB (1.9%) command: steamwebhelper pid: 61470 cpu: 1.5%
5: mem: 575.4 MiB (1.8%) command: electron pid: 4228 cpu: 2.3%
Processes: 433 Power: uptime: 4h 27m states: freeze,mem,disk suspend: s2idle
wakeups: 1 fails: 1 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 12.39 GiB services: org_kde_powerdevil,upowerd
Init: systemd v: 258 default: graphical tool: systemctl
Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole
inxi: 3.3.40
I wanted to print the libinput list-devices part of the pen again, but I’m getting a libinput not found, even after installing it by hand (it was installed - I reinstalled)
> paru libinput
36 aur/xlibre-input-libinput-bin 1.5.1.0-1 [+0 ~0.00]
XLibre Official Easy Install Drop in Replacement fork of X.Org generic input driver for the xorg
server based on libinput (binary release)
35 aur/xlibinput-calibrator 0.10-1 [+0 ~0.00] [Out-of-date: 2023-08-26] [Orphaned]
Touch calibrator for libinput.
34 aur/wayboard-git 0.r86.gc22eb81-1 [+0 ~0.00]
libinput-based keyboard input display for Wayland (git master)
33 aur/libinput-xrandr-autorotate 0.1.1-1 [+0 ~0.00]
Allows to rotate screen and touch input for 2-in-1 laptops
32 aur/libinput-gestures-qt 0.4-2 [+0 ~0.00]
Qt-based GUI for libinput-gestures
31 aur/libinput-gestures-git 2.81.r0.g9552f0d-2 [+0 ~0.00]
Actions gestures on your touchpad using libinput
30 aur/libinput-epp 1.29.2-1 [+0 ~0.00]
Replaces Adaptive acceleration with Windows' Enhance Pointer Precision
29 aur/xf86-input-libinput-hires-scroll 1.5.0-1 [+1 ~0.00]
Generic input driver for the X.Org server based on libinput - patched for hi-res wheel scroll
28 aur/python-libinput 0.3.0pre1-5 [+1 ~0.00] [Orphaned]
Object-oriented wrapper for libinput using ctypes
27 aur/lisgd-git 0.3.0.r2.g190a93d-2 [+1 ~0.12]
Bind gestures on touchscreens, and unsupported gesture devices via libinput touch events
26 aur/libinputsynth-git 0.16.0.r75.f369bcf-1 [+1 ~0.00]
Synthesize desktop input for X11 and Wayland
25 aur/libinput-noaccum 1.28.1-1 [+1 ~0.03]
libinput with ACC_V120_THRESHOLD set to 1 for smooth high-resolution scrolling
24 aur/libinput-no-gestures 1.29.0-1 [+1 ~0.75]
Input device management and event handling library - patched to remove gestures
23 aur/libinput-git 1.27.1-1 [+1 ~0.00]
22 aur/libinput-config r84.f373bb6-1 [+1 ~0.00] [Orphaned]
Configuration system for libinput
21 aur/inpulse-to-talk v3.0-2 [+1 ~0.00]
Push-to-Talk with libinput + Pulseaudio/Pipewire
20 aur/bucklespring-libinput-git latest-9 [+1 ~0.00]
Nostalgia bucklespring keyboard sound, sampled from IBM's Model-M. libinput version
19 aur/xlibre-input-libinput-git 1.5.0.1.r3.83adc38-1 [+2 ~0.10]
Generic input driver for the Xlibre server based on libinput
18 aur/showmethekey-git r35.daee517-1 [+2 ~0.05]
A screenkey alternative that works under Wayland via libinput.
17 aur/lisgd 0.4.0-1 [+2 ~0.13]
16 aur/gebaar-libinput-fork 0.1.5-1 [+2 ~0.00]
A Super Simple WM Independent Touchpad Gesture Daemon for libinput. Forked version with new
features
15 aur/xf86-input-libinput-git 1.4.0.r0.g46af622-1 [+3 ~0.00]
14 aur/gesture-manager-x-git r8.d61ed8a-1 [+3 ~0.00]
Extended GUI for interacting with libinput-gestures
13 aur/consolation 0.0.10-4 [+3 ~0.00]
Libinput-based console pointer support for copy-paste, similar to gpm
12 aur/gebaar-libinput-git r67.098a1ef-1 [+5 ~0.00]
features
11 aur/libinput-config-git r79.1d649f7-1 [+7 ~0.00] [Out-of-date: 2023-07-01] [Orphaned]
10 aur/libinput-multiplier 1.28.1-1 [+8 ~0.00]
libinput with scroll multiplier patch
9 aur/libinput-three-finger-drag 1.30.0-1 [+9 ~0.00]
8 aur/gestures 0.3.1-3 [+9 ~0.87]
Modern, minimal GUI app for libinput-gestures
7 aur/xlibre-input-libinput 1.5.1.0-1 [+12 ~0.60]
Generic input driver for the XLibre server based on libinput
6 aur/gesture-manager-git r11.48821e2-2 [+13 ~0.00]
Graphical manager for setting libinput-gestures touchpad gestures
5 aur/libinput-gestures 2.81-1 [+97 ~0.09]
4 extra/xf86-input-libinput 1.5.0-1 [41.94 KiB 103.13 KiB] [Installed] (xorg-drivers)
3 extra/showmethekey 1.18.4-2 [58.64 KiB 168.15 KiB]
2 extra/libinput-tools 1.30.0-2 [145.65 KiB 577.82 KiB]
Input device management and event handling library (debug utilities)
1 extra/libinput 1.30.0-2 [0 B 764.34 KiB] [Installed]
:: Packages to install (eg: 1 2 3, 1-3):
:: 1
Enter Password or Place finger on fingerprint reader:
warning: libinput-1.30.0-2 is up to date -- reinstalling
resolving dependencies...
Package (1) Old Version New Version Net Change
extra/libinput 1.30.0-2 1.30.0-2 0,00 MiB
Total Installed Size: 0,75 MiB
Net Upgrade Size: 0,00 MiB
(1/1) checking keys in keyring [---------------------------------] 100%
(1/1) checking package integrity [---------------------------------] 100%
(1/1) loading package files [---------------------------------] 100%
(1/1) checking for file conflicts [---------------------------------] 100%
(1/1) checking available disk space [---------------------------------] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> Skipping timeshift-autosnap because only 6 hours have passed since the last snapshot.
(1/1) reinstalling libinput [---------------------------------] 100%
(1/3) Reloading device manager configuration...
(2/3) Arming ConditionNeedsUpdate...
(3/3) Looking for Pacnew/Pacsave created.
zsh: command not found: libinput
Is this a manjaro issue or an rnote issue?
What other information do y’all need to help out.
Would love to resolve this, so I can go back to studying…
