Hi all,
Having another issue with pCloud drive (AUR) -
ERROR: One or more files did not pass the validity check!
pamac update -a 1 ✘
Preparing...
Authenticating as:
Password:
Waiting for another package manager to quit...
Nothing to do.
Cloning pcloud-drive build files...
Generating pcloud-drive information...
Checking pcloud-drive dependencies...
Resolving dependencies...
Checking inter-conflicts...
To build (1):
pcloud-drive 1.14.12-2 (1.14.12-1) AUR
Edit build files : [e]
Apply transaction ? [e/y/N] Y
Building pcloud-drive...
==> Making package: pcloud-drive 1.14.12-2 (Fri 16 May 2025 02:22:58 AM +08)
==> Retrieving sources...
-> Found LICENSE
-> Found pcloud-drive.AppImage
LICENSE ... Passed
pcloud-drive.AppImage ... FAILED
==> ERROR: One or more files did not pass the validity check!
Error: Failed to build pcloud-drive
Try forcing a refresh…
pamac update --force-refresh --aur --devel
Keep in mind that pamac
does not access the AUR directly. It uses a local cache instead.
If all else fails, you could try yay
instead, which does access the AUR directly.
Same error.
Maintainer forgot to update the checksum?
pamac update --force-refresh --aur --devel ✔
Preparing...
Authenticating as:
Password:
Refreshing core.db...
Refreshing extra.db...
Refreshing multilib.db...
Refreshing core.files...
Refreshing extra.files...
Refreshing multilib.files...
Refreshing AUR...
Nothing to do.
To build (1):
cp: cannot access '/var/lib/pacman/sync/download-wNMhAX': Permission denied
==> Making package: pcloud-drive 1.14.12-2 (Fri 16 May 2025 02:33:52 AM +08)
-> Found LICENSE
LICENSE ... Passed
Hmm, from what I can tell, it’s trying to build an ALPM package by extracting an AppImage, and that’s where it goes wrong.
However, I also notice this in your output above…
I don’t have a /var/lib/pacman/sync/download-wNMhAX
(or similarly named) directory on my system. So it could in theory be a pamac
issue.
Next up: try yay
yay -Syu
The command took a long time to connect to repo, failed on 1st attempt.
After 10 mins, it finally get the job done.
Thanks for the guide!
system
Closed
6
