The udev I suggested will be ONLY applied if you put your thumb drive into the usb slot and it gets automatically mounted. That does udisks for you.
If you mount the usb drive with fstab, the default async
will be used if sync is not explicitly called.
Nothing gets overwritten. There is fstab and there is udisks. Fstab is for static mounts and udisks mounts it automatically.
It is reliable. USB3 has theoretically bandwidth of 5Gb/s. Note: it is the hub. If you put 2 usb drives into the same hub it will divided. However… also the speed of the drive comes into play.
No, it is not. When using async the speed is ALWAYS not the real speed. So you have to decide yourself: Do you want that it is written just in time and unplug the thumb drive or do you want to use the cache. If the drive is always connected, then it would not make any difference, but if you need to use it just for a short time, then option sync is always preferable.
So end of story for me. You can do the hacky stuff with dirty pages, but the normal way is just using a mount option as I suggested.
I must adimit that I was wrong here when I see the results of my tiny test below.
Additionally here a simple test from my side:
100MB tempfile on exfat with async
$ mount -t exfat | cut -d" " -f1,5,6 | sed -r "s;\(.+,(|sync).+\);\\1;g"
/dev/sdf1 exfat
$ for x in $(seq 1 5); do export TIMEFORMAT='%3lR'; echo "$(time $(cp ~/tempfile /run/media/user/Ventoy && sync))" && rm -f /run/media/user/Ventoy/tempfile && sync && sleep 1 ; done
Results:
0m6,971s
0m6,837s
0m10,505s
0m8,418s
0m10,597s
Apply udev rule:
echo 'SUBSYSTEMS=="usb", SUBSYSTEM=="block", ENV{ID_FS_USAGE}=="filesystem", ENV{UDISKS_MOUNT_OPTIONS_DEFAULTS}+="sync", ENV{UDISKS_MOUNT_OPTIONS_ALLOW}+="sync"' | sudo tee /etc/udev/rules.d/99-usbsync.rules && sudo udevadm control --reload
Unplug and plugin the flash drive.
100MB tempfile on extfat with sync
$ mount -t exfat | cut -d" " -f1,5,6 | sed -r "s;\(.+,(|sync),.+\);\\1;g"
/dev/sdf1 exfat sync
Results:
0m45,387s
0m58,523s
0m59,260s
1m4,165s
1m2,894s
100MB tempfile on vfat with async
sudo rm -f /etc/udev/rules.d/99-usbsync.rules && sudo udevadm control --reload
$ mount -t vfat | grep -v sda1 | cut -d" " -f1,5,6
/dev/sdf1 vfat (rw,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro,uhelper=udisks2)
$ for x in $(seq 1 5); do export TIMEFORMAT='%3lR'; echo "$(time $(cp ~/tempfile /run/media/user/USB8GB/tempfile && sync))" && rm -f /run/media/user/USB8GB/tempfile && sync && sleep 1 ; done
Results:
0m20,836s
0m17,401s
0m9,607s
0m7,731s
0m9,598s
100MB tempfile on vfat with sync
/dev/sdf1 vfat (rw,nosuid,nodev,relatime,sync,uid=1000,gid=1000,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,showexec,utf8,flush,errors=remount-ro,uhelper=udisks2)
Results:
20m50,983s
16m11,129s
16m15,609s
16m18,828s
16m22,699s
100MB tempfile on ext2 with async
$ mount -t ext2 | cut -d" " -f1,5,6
/dev/sdf1 ext2 (rw,nosuid,nodev,relatime,errors=remount-ro,uhelper=udisks2)
$ for x in $(seq 1 5); do export TIMEFORMAT='%3lR'; echo "$(time $(cp ~/tempfile /run/media/user/USB8GB/tempfile && sync))" && rm -f /run/media/user/USB8GB/tempfile && sync && sleep 1 ;done
0m13,881s
0m9,270s
0m8,120s
0m8,574s
0m7,631s
100MB tempfile on ext2 with sync
/dev/sdf1 ext2 (rw,nosuid,nodev,relatime,sync,errors=remount-ro,uhelper=udisks2)
4m38,701s
3m58,476s
3m55,660s
4m5,261s
4m1,574s
What is my conclusion here? There is indeed a performance impact, but it depends on the file system aswell. Maybe on vfat the options flush
and sync
together have a negative effect here. exfat has the best results in sync and async mode (maybe f2fs will have similar results because it is also optimized for flash drives, but it is exotic on thumb drives). All of them have similar results (more or less), therefore no doubt: async is superior even if you don’t adjust the dirty pages.
The times also contains also the forced sync time after the copying.
I am against using the sync
option after seeing these real life results. Myself I will not promote that anymore, but adjusting dirty pages is also not ideal (at least for me), So I hope the kernel devs will find a solution, but in the while I can be aware of (as I have always been) and doing a sync command after copying something to the thumb drive.
