I have a strange situation where my machine wont post grub. It happens randomly and just restarting the machine seems to solve it. I have a z390 pro mobo, Boot logs seem clear. Other times grub is extremely slow.
The machine does not experience any hangs nor crashes and I seem to be affected just on boot/reboot. I have found similar reports. Ideas?
System: Kernel: 5.7.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=b841b317-5f27-4086-9390-595dff39a5c8 rw quiet apparmor=1 security=apparmor
udev.log_priority=3
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: Micro-Star model: Z390-A PRO (MS-7B98) v: 1.0 serial: <filter>
UEFI: American Megatrends v: 1.80 date: 12/25/2019
CPU: Topology: 6-Core model: Intel Core i5-9600K bits: 64 type: MCP arch: Kaby Lake family: 6
model-id: 9E (158) stepping: C (12) microcode: D6 L2 cache: 9216 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44412
Speed: 800 MHz min/max: 800/4700 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800
6: 800
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP:
disabled, RSB filling
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Graphics: Device-1: NVIDIA TU106 [GeForce RTX 2070] driver: nvidia v: 440.100
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f02
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: nvidia display ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.7x13.5")
s-diag: 693mm (27.3")
Monitor-1: DP-0 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
OpenGL: renderer: GeForce RTX 2070/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:a348
Device-2: NVIDIA TU106 High Definition Audio driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:10f9
Device-3: Logitech type: USB driver: snd-usb-audio,uvcvideo bus ID: 1-1.3:4
chip ID: 046d:085b serial: <filter>
Sound Server: ALSA v: k5.7.15-1-MANJARO
Network: Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e v: 3.2.6-k
port: efa0 bus ID: 00:1f.6 chip ID: 8086:15bc
Drives: Local Storage: total: 912.89 GiB used: 76.74 GiB (8.4%)
ID-1: /dev/sda vendor: Samsung model: SSD 840 EVO 500GB size: 465.76 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: DB6Q scheme: GPT
ID-2: /dev/sdb vendor: Kingston model: SA400S37480G size: 447.13 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 0102 scheme: GPT
Partition: ID-1: / raw size: 154.16 GiB size: 150.74 GiB (97.78%) used: 76.71 GiB (50.9%) fs: ext4
dev: /dev/sdb1
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 42.0 C mobo: N/A gpu: nvidia temp: 40 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 46%
Info: Processes: 268 Uptime: 3m Memory: 15.58 GiB used: 4.09 GiB (26.3%) Init: systemd v: 245
Compilers: gcc: 10.1.0 alt: 8/9 Packages: 1460 pacman: 1458 lib: 404 flatpak: 0 snap: 2
Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
P.S. I still cannot post links so I removed the https part.
