I had just installed the linux 5.9 kernel and my pc is not booting since.When I changed my kernel back to 5.8 it is working fine can anybody pls tell me what is the problem.
Howdy!
Please boot into the kernel 5.8, then open a terminal and execute sudo mkinitcpio -P
followed by sudo update-grub
then reboot!
If it is not working, it might not be compatible, or missing a component.
Have a wonderful day, and welcome to this fabulous community!
Thanks it is working now i actually just needed to wait for the stable version to come out. The time I had installed the kernel it was experimental
The same thing happens to me, and I’m using the stable version. Have to revert back to 5.8.16 to get my system to boot again.
can you provide
inxi -Fza --no-host
System: Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.8-x86_64 root=UUID=bbaf9adf-08db-4471-b3f1-21de28fd3c95 rw
rootflags=subvol=@ quiet apparmor=1 security=apparmor udev.log_priority=3
Desktop: Cinnamon 4.6.7 tk: GTK 3.24.23 wm: Muffin dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: Z170I PRO GAMING v: Rev X.0x serial: UEFI: American Megatrends v: 3805
date: 05/16/2018
CPU: Topology: Quad Core model: Intel Core i5-6500 socket: LGA1151 bits: 64 type: MCP arch: Skylake-S family: 6
model-id: 5E (94) stepping: 3 microcode: D6 L1 cache: 256 KiB L2 cache: 6144 KiB L3 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 25610
Speed: 2517 MHz min/max: 800/3600 MHz base/boost: 3200/8300 volts: 1.0 V ext-clock: 100 MHz Core speeds (MHz):
1: 2257 2: 2300 3: 2170 4: 2271
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Type: srbds status: Vulnerable: No microcode
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Graphics: Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ZOTAC driver: nvidia v: 440.100 alternate: nouveau,nvidia_drm
bus ID: 01:00.0 chip ID: 10de:1c03
Display: server: 1.20.9 driver: nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.7x16.7") s-diag: 798mm (31.4")
Monitor-1: DP-0 res: 2560x1600 hz: 60 dpi: 101 size: 641x401mm (25.2x15.8") diag: 756mm (29.8")
OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100 direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:1f.3 chip ID: 8086:a170
Device-2: NVIDIA GP106 High Definition Audio vendor: ZOTAC driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 10de:10f1
Sound Server: ALSA v: k5.8.16-2-MANJARO
Network: Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: 3.2.6-k port: f000 bus ID: 00:1f.6
chip ID: 8086:15b8
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac:
Drives: Local Storage: total: 7.74 TiB used: 1.07 TiB (13.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLW512HMJP-00000 size: 476.94 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: rev: CXY7301Q scheme: GPT
ID-2: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: rev: 2B6Q scheme: MBR
ID-3: /dev/sdb vendor: Seagate model: ST4000DX001-1CE168 size: 3.64 TiB block size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s rotation: 5900 rpm serial: rev: CC44 scheme: GPT
ID-4: /dev/sdc vendor: Seagate model: ST3750640AS size: 698.64 GiB block size: physical: 512 B logical: 512 B
speed: 3.0 Gb/s serial: rev: K scheme: MBR
ID-5: /dev/sdd type: USB vendor: Seagate model: ST33000651AS size: 2.00 TiB block size: physical: 512 B
logical: 512 B rotation: 7200 rpm serial: rev: 0000 scheme: MBR
ID-6: /dev/sde type: USB model: 51AS size: 746.52 GiB block size: physical: 512 B logical: 512 B rotation: 7200 rpm
serial: N/A rev: 0000 scheme: MBR
Partition: ID-1: / raw size: 476.44 GiB size: 476.44 GiB (100.00%) used: 48.18 GiB (10.1%) fs: btrfs block size: 4096 B
dev: /dev/nvme0n1p2
ID-2: /home raw size: 476.44 GiB size: 476.44 GiB (100.00%) used: 48.18 GiB (10.1%) fs: btrfs block size: 4096 B
dev: /dev/nvme0n1p2
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 29.0 C mobo: N/A gpu: nvidia temp: 30 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
Info: Processes: 296 Uptime: 22h 09m Memory: 15.58 GiB used: 4.21 GiB (27.0%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: 1379 pacman: 1365 lib: 365 flatpak: 11 snap: 3 Shell: Bash (sudo) v: 5.0.18 running in: guake
inxi: 3.1.05
have you checked log in boot before ?
sudo journactl -b -1 -p4 ( b -2 boot before , etc ... )
Nope! Thanks, I will investigate further. This is the first time a new kernel won’t boot.
Hi,
I also have this same problem with the 5.9.1 kernel. This is specific to Manjaro as the same version boots OpenSUSE Tumbleweed normally.
Cheers
DrT
I read somewhere that Nvidia drivers won’t work with kernel 5.9. You’ll get a black screen at boot.Nvidia will come with new drivers mid-November. I guess that’s the issue for me at least. Just have to wait until Manjaro implement the new Nvidia drivers.
