Hi, guys !! My PC is not booting up properly as it was doing this kernel update to Mikah from Lysia. I will Explain my problem in brief, below.
When I sit and try to turn on my PC, on the 1st Attempt, a blank screen appears in my Computer Screen, not even BIOS is showing up. Then, later in my 2nd or 3rd Attempt, my PC Boots up to Manjaro fine.
I record this observation of not just one instance of this occurrence, but 4 - 5 times, same incident has occurred. And also When my BIOS doesn’t boot up, a blank screen with a blinking cursor is observed, or sometimes, a light grey screen with the same blinking cursor, and nothing else.
I can’t understand what is going on here.
When I updated my PC from Lysia to Mikah, I actually used Package Manager. The Package Manager window got hung up after downloading 100%. Then after like 5 Minutes, it started to install and upgrade packages and run post-transaction hooks.
NOTE: I tried minimize and even exit the Package Manager Window, as soon as I felt that it just got hung at 100%. But, it completed the process without any errors, I assume as, it didn’t display me any errors.
Then, after I finishing my other tasks, I restarted my PC to check this new update. And thus, from there-forth, I have this problem.
My PC’s Information:
System: Kernel: 5.7.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0 Desktop: GNOME 3.36.4 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: FOXCONN model: A76GMV v: 1.0 serial: <filter> BIOS: American Megatrends v: 080014
date: 10/11/2011
CPU: Topology: Single Core model: AMD Sempron 145 bits: 64 type: UP arch: K10 rev: 3 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 5602
Speed: 800 MHz min/max: 800/2800 MHz Core speed (MHz): 1: 1600
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] RS780L [Radeon 3000] vendor: Foxconn driver: radeon v: kernel
bus ID: 01:05.0
Display: x11 server: X.org 1.20.8 driver: ati,radeon unloaded: modesetting resolution: <xdpyinfo missing>
OpenGL: renderer: AMD RS780 (DRM 2.50.0 / 5.7.14-1-MANJARO LLVM 10.0.1) v: 3.3 Mesa 20.1.5 direct render: Yes
Please and Kindly, help me with what is going on, how to fix this issue, and explain me why did this happen.
NOTE: I thought of share this info too, I downloaded Qt Creator with all it’s optional dependencies, before updating my PC.
