Hi, is there some way how to pause splash screen during boot?
I’ve tried to make some internet research, but nothing works - like pause/break button, scroll lock button… Maybe it must be enabled some how, but I don’t know how…
No, there is no way to do that.
Back in the single-core, single-user, single-tasking era of CP/M and MS-DOS, it was easy to stop the boot process by putting a PAUSE
in the startup script, but in the current era of multi-core, multi-user, multi-tasking this is not possible any more.
The boot process fires off a number of parallel tasks on multiple cores to ensure the boot process is finished as soon as possible, so pausing the boot process would be terribly complicated, so therefore this functionality doesn’t exist.
So what should you do then, you ask?
Well, that’s easy: once you’ve fully booted, you can just look at the boot processes output by using the journalctl
CLI:
journalctl --boot=0 --system --priority=2
Where:
--boot=0
-1
looks at the previous boot,-2
looks at 2 boots ago, …--system
--priority=2
for more information: man journalctl
Hi, thank you for explaining answer! Thats what I need
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
