Password not recognised - occassionally
Hi,
This has happened to me on 3 separate occassions times now so I’m almost certain this is not a coincidence…
I lock my screen (sometimes directly on the laptop keyboard, sometimes on the bluetooth keyboard), I come back some time later and enter my password and it tells me it’s not recognised. I double check and press the “reveal” button to see what I’ve typed and to make sure I haven’t got caps lock on. I confirm that my password is correct so I type it again a couple more times and still no success.
I then reboot and type in the same password again at the login screen and I can login! Has anyone else experienced this?
I see a lot of these recurring in the logs - probably not relevant though
(appimagelaunche) of user 1000 dumped core
From journalctl, I see several entries
Oct 21 21:32:08 john-msi unix_chkpwd[100691]: password check failed for user (john)
Oct 21 21:32:08 john-msi kcheckpass[87757]: pam_unix(kde:auth): authentication failure; logname= uid=1000 euid=1000 tty=:0 ruser= rhost= user=john
inxi -Fxz
System: Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A Desktop: KDE Plasma 5.19.5 Distro: Manjaro Linux
Machine: Type: Laptop System: Micro-Star product: GS63VR 7RF v: REV:1.0 serial:
Mobo: Micro-Star model: MS-16K2 v: REV:1.0 serial: UEFI: American Megatrends v: E16K2IMS.31B
date: 03/14/2018
Battery: ID-1: BAT1 charge: 53.0 Wh condition: 54.5/65.0 Wh (84%) model: MSI BIF0_9 status: Unknown
Device-1: hid-34:88:5d:f5:6e:9c-battery model: Keyboard K380 charge: N/A status: Discharging
CPU: Topology: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake rev: 9
L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44817
Speed: 1601 MHz min/max: 800/2800 MHz Core speeds (MHz): 1: 1600 2: 1600 3: 1600 4: 1600 5: 1600
6: 1600 7: 1600 8: 1600
Graphics: Device-1: Intel HD Graphics 630 vendor: Micro-Star MSI driver: i915 v: kernel bus ID: 00:02.0
Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] vendor: Micro-Star MSI driver: nvidia v: 450.80.02
bus ID: 01:00.0
Device-3: Acer NEC HD WebCam type: USB driver: uvcvideo bus ID: 1-11:5
Display: x11 server: X.Org 1.20.9 driver: modesetting,nvidia resolution: 1: 1920x1080 2: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.1.8 direct render: Yes
Audio: Device-1: Intel CM238 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1f.3
Sound Server: ALSA v: k5.8.16-2-MANJARO
Network: Device-1: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Micro-Star MSI driver: alx v: kernel
port: d000 bus ID: 3d:00.0
IF: enp61s0 state: up speed: 1000 Mbps duplex: full mac:
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: d000 bus ID: 3e:00.0
IF: wlp62s0 state: up mac:
Drives: Local Storage: total: 2.29 TiB used: 93.44 GiB (4.0%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: N/A size: 476.94 GiB
ID-2: /dev/sda vendor: Seagate model: ST2000LM003 HN-M201RAD size: 1.82 TiB
Partition: ID-1: / size: 1.47 TiB used: 77.43 GiB (5.1%) fs: ext4 dev: /dev/sda5
ID-2: /home size: 287.37 GiB used: 13.32 GiB (4.6%) fs: ext4 dev: /dev/dm-2
Swap: ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%) dev: /dev/dm-4
Sensors: System Temperatures: cpu: 62.0 C mobo: 27.8 C
Info: Processes: 276 Uptime: 13m Memory: 31.25 GiB used: 1.75 GiB (5.6%) Init: systemd Compilers: gcc: 10.2.0
Packages: 1268 Shell: Bash v: 5.0.18 inxi: 3.1.05
mhwd-kernel -li
$ cat mhwd-kernel_li.out
Currently running: 5.8.16-2-MANJARO (linux58)
  • linux414
  • linux58
I’m very new to Manjaro (2 weeks :blush:) and KDE (but have been a CentOs, Fedora user for the last 4 years). I have provided some system info. Please let me know if there is anything else I should provide or should be looking at.
Thanks,
Are you by any chance using a non-US keyboard and use letters in your password?
You can try a test and change your password to be numbers only to check if it has to do with keyboard layout…
If it does not happen while you have only numbers as password, then im sure others can help you further to configure the layout to be used…
Thanks for your response. I see where you’re going with that but I’m using a US keyboard.
Hello Jade1
I’am maybe a solution for you: Open System Settings and enter devices . Check the option Activate of the keyboard. I think to help.
Thanks for your response. I tried your suggestion. I saw a notice saying “keyboard configuration not optimal - fix it” I clicked on fix it…I’ll see how that goes…
I’ve got the same terrible problem! I am also a recent user and I already had 3 occasions when Manjaro didn’t want to authorize me into the system. I am pretty sure that the password was correct all times, since I made the password visible.
Here’s my journalctl log when it all happened:
-- Journal begins at Thu 2021-01-21 10:37:56 +04, ends at Sun 2021-04-11 17:52:56 +04. --
apr 11 17:21:26 buran13 dbus-daemon[512]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.30' (uid=1000 pid=1259 comm="/usr/lib/org_kde_powerdevil ") (using servicehelper)
apr 11 17:21:26 buran13 dbus-daemon[512]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
apr 11 17:21:26 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper: RRNotify_OutputProperty (ignored)
apr 11 17:21:26 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         Output:  67
apr 11 17:21:26 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         Property:  Backlight
apr 11 17:21:26 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         State (newValue, Deleted):  0
apr 11 17:21:26 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         Property:  BACKLIGHT
apr 11 17:21:27 buran13 audit[120276]: USER_AUTH pid=120276 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=failed'
apr 11 17:21:27 buran13 kernel: audit: type=1100 audit(1618147287.094:180): pid=120276 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=failed'
apr 11 17:21:27 buran13 unix_chkpwd[120276]: password check failed for user (soshial)
apr 11 17:21:27 buran13 kcheckpass[120274]: pam_unix(kde:auth): authentication failure; logname= uid=1000 euid=1000 tty=:0 ruser= rhost=  user=soshial
apr 11 17:21:27 buran13 dbus-daemon[512]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.393' (uid=1000 pid=120274 comm="kcheckpass -m classic -S 31 ")
apr 11 17:21:27 buran13 dbus-daemon[512]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
apr 11 17:21:27 buran13 kcheckpass[120274]: pam_systemd_home(kde:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
apr 11 17:21:30 buran13 kcheckpass[120290]: pam_unix(kde:auth): authentication failure; logname= uid=1000 euid=1000 tty=:0 ruser= rhost=  user=soshial
apr 11 17:21:30 buran13 dbus-daemon[512]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.394' (uid=1000 pid=120290 comm="kcheckpass -m classic -S 31 ")
apr 11 17:21:30 buran13 dbus-daemon[512]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
apr 11 17:21:30 buran13 kcheckpass[120290]: pam_systemd_home(kde:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
apr 11 17:21:35 buran13 audit[120305]: USER_AUTH pid=120305 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=failed'
apr 11 17:21:35 buran13 kernel: audit: type=1100 audit(1618147295.134:181): pid=120305 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=failed'
apr 11 17:21:35 buran13 unix_chkpwd[120305]: password check failed for user (soshial)
apr 11 17:21:35 buran13 kcheckpass[120303]: pam_unix(kde:auth): authentication failure; logname= uid=1000 euid=1000 tty=:0 ruser= rhost=  user=soshial
apr 11 17:21:35 buran13 dbus-daemon[512]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.395' (uid=1000 pid=120303 comm="kcheckpass -m classic -S 31 ")
apr 11 17:21:35 buran13 dbus-daemon[512]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
apr 11 17:21:35 buran13 kcheckpass[120303]: pam_systemd_home(kde:auth): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
apr 11 17:21:35 buran13 kcheckpass[120303]: pam_faillock(kde:auth): Consecutive login failures for user soshial account temporarily locked
apr 11 17:21:39 buran13 kscreenlocker_greet[119046]: file:///usr/share/plasma/look-and-feel/org.kde.breath2.desktop/contents/lockscreen/LockScreenUi.qml:53: ReferenceError: msg is not defined
apr 11 17:21:40 buran13 audit[120328]: USER_AUTH pid=120328 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 11 17:21:40 buran13 kernel: audit: type=1100 audit(1618147300.021:182): pid=120328 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 11 17:21:40 buran13 kcheckpass[120326]: Authentication failure for soshial (invoked by uid 1000)
apr 11 17:21:43 buran13 kscreenlocker_greet[119046]: file:///usr/share/plasma/look-and-feel/org.kde.breath2.desktop/contents/components/KeyboardLayoutButton.qml:43: TypeError: Cannot call method 'indexOf' of undefined
apr 11 17:21:44 buran13 kscreenlocker_greet[119046]: file:///usr/share/plasma/look-and-feel/org.kde.breath2.desktop/contents/components/KeyboardLayoutButton.qml:43: TypeError: Cannot call method 'indexOf' of undefined
apr 11 17:21:49 buran13 kscreenlocker_greet[119046]: qt.virtualkeyboard: InputContext::sendKeyClick(): no focus to send key click - QGuiApplication::focusWindow() is: KQuickAddons::QuickViewSharedEngine(0x556cf586c990)
apr 11 17:21:50 buran13 kscreenlocker_greet[119046]: qt.virtualkeyboard: InputContext::sendKeyClick(): no focus to send key click - QGuiApplication::focusWindow() is: KQuickAddons::QuickViewSharedEngine(0x556cf586c990)
apr 11 17:22:01 buran13 kscreenlocker_greet[119046]: file:///usr/share/plasma/look-and-feel/org.kde.breath2.desktop/contents/lockscreen/LockScreenUi.qml:53: ReferenceError: msg is not defined
apr 11 17:22:01 buran13 kscreenlocker_greet[119046]: file:///usr/share/plasma/look-and-feel/org.kde.breath2.desktop/contents/lockscreen/LockScreenUi.qml:0: ReferenceError: msg is not defined
apr 11 17:22:02 buran13 audit[120378]: USER_AUTH pid=120378 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 11 17:22:02 buran13 kcheckpass[120376]: Authentication failure for soshial (invoked by uid 1000)
apr 11 17:22:02 buran13 kernel: audit: type=1100 audit(1618147322.028:183): pid=120378 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 11 17:22:23 buran13 kscreenlocker_greet[119046]: file:///usr/share/plasma/look-and-feel/org.kde.breath2.desktop/contents/lockscreen/LockScreenUi.qml:0: ReferenceError: msg is not defined
apr 11 17:22:23 buran13 audit[120437]: USER_AUTH pid=120437 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 11 17:22:23 buran13 kcheckpass[120435]: Authentication failure for soshial (invoked by uid 1000)
apr 11 17:22:23 buran13 kernel: audit: type=1100 audit(1618147343.664:184): pid=120437 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 11 17:22:38 buran13 kscreenlocker_greet[119046]: file:///usr/share/plasma/look-and-feel/org.kde.breath2.desktop/contents/lockscreen/LockScreenUi.qml:0: ReferenceError: msg is not defined
apr 11 17:22:38 buran13 audit[120494]: USER_AUTH pid=120494 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 11 17:22:38 buran13 kernel: audit: type=1100 audit(1618147358.441:185): pid=120494 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 11 17:22:38 buran13 kcheckpass[120492]: Authentication failure for soshial (invoked by uid 1000)
apr 11 17:22:57 buran13 kscreenlocker_greet[119046]: file:///usr/share/plasma/look-and-feel/org.kde.breath2.desktop/contents/lockscreen/LockScreenUi.qml:0: ReferenceError: msg is not defined
apr 11 17:22:57 buran13 audit[120544]: USER_AUTH pid=120544 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 11 17:22:57 buran13 kcheckpass[120542]: Authentication failure for soshial (invoked by uid 1000)
apr 11 17:22:57 buran13 kernel: audit: type=1100 audit(1618147377.391:186): pid=120544 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 11 17:23:06 buran13 kscreenlocker_greet[119046]: file:///usr/share/plasma/look-and-feel/org.kde.breath2.desktop/contents/components/KeyboardLayoutButton.qml:43: TypeError: Cannot call method 'indexOf' of undefined
apr 11 17:23:21 buran13 kscreenlocker_greet[119046]: file:///usr/share/plasma/look-and-feel/org.kde.breath2.desktop/contents/lockscreen/LockScreenUi.qml:0: ReferenceError: msg is not defined
apr 11 17:23:21 buran13 audit[120616]: USER_AUTH pid=120616 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 11 17:23:21 buran13 kcheckpass[120614]: Authentication failure for soshial (invoked by uid 1000)
apr 11 17:23:21 buran13 kernel: audit: type=1100 audit(1618147401.155:187): pid=120616 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 11 17:25:54 buran13 dbus-daemon[512]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.30' (uid=1000 pid=1259 comm="/usr/lib/org_kde_powerdevil ") (using servicehelper)
apr 11 17:25:54 buran13 dbus-daemon[512]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
apr 11 17:25:54 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper: RRNotify_OutputProperty (ignored)
apr 11 17:25:54 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         Output:  67
apr 11 17:25:54 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         Property:  Backlight
apr 11 17:25:54 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         State (newValue, Deleted):  0
apr 11 17:25:54 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         Property:  BACKLIGHT
apr 11 17:27:09 buran13 dbus-daemon[512]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.30' (uid=1000 pid=1259 comm="/usr/lib/org_kde_powerdevil ") (using servicehelper)
apr 11 17:27:09 buran13 dbus-daemon[512]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
apr 11 17:27:09 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper: RRNotify_OutputProperty (ignored)
apr 11 17:27:09 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         Output:  67
apr 11 17:27:09 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         Property:  Backlight
apr 11 17:27:09 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         State (newValue, Deleted):  0
apr 11 17:27:09 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         Property:  BACKLIGHT
apr 11 17:28:24 buran13 dbus-daemon[512]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.30' (uid=1000 pid=1259 comm="/usr/lib/org_kde_powerdevil ") (using servicehelper)
apr 11 17:28:24 buran13 dbus-daemon[512]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
apr 11 17:28:24 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper: RRNotify_OutputProperty (ignored)
apr 11 17:28:24 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         Output:  67
apr 11 17:28:24 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         Property:  Backlight
apr 11 17:28:24 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         State (newValue, Deleted):  0
apr 11 17:28:25 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper: RRNotify_OutputProperty (ignored)
apr 11 17:28:25 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         Output:  67
apr 11 17:28:25 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         Property:  BACKLIGHT
apr 11 17:28:25 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         State (newValue, Deleted):  0
apr 11 17:28:39 buran13 dbus-daemon[512]: [system] Activating service name='org.kde.powerdevil.backlighthelper' requested by ':1.30' (uid=1000 pid=1259 comm="/usr/lib/org_kde_powerdevil ") (using servicehelper)
apr 11 17:28:39 buran13 dbus-daemon[512]: [system] Successfully activated service 'org.kde.powerdevil.backlighthelper'
apr 11 17:28:39 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper: RRNotify_OutputProperty (ignored)
apr 11 17:28:39 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         Output:  67
apr 11 17:28:39 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         Property:  Backlight
apr 11 17:28:39 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         State (newValue, Deleted):  0
apr 11 17:28:40 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper: RRNotify_OutputProperty (ignored)
apr 11 17:28:40 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         Output:  67
apr 11 17:28:40 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         Property:  BACKLIGHT
apr 11 17:28:40 buran13 kscreen_backend_launcher[1320]: kscreen.xcb.helper:         State (newValue, Deleted):  0
apr 11 17:28:53 buran13 kscreenlocker_greet[119046]: file:///usr/share/plasma/look-and-feel/org.kde.breath2.desktop/contents/lockscreen/LockScreenUi.qml:0: ReferenceError: msg is not defined
apr 11 17:28:53 buran13 audit[121421]: USER_AUTH pid=121421 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 11 17:28:53 buran13 kcheckpass[121419]: Authentication failure for soshial (invoked by uid 1000)
apr 11 17:28:53 buran13 kernel: audit: type=1100 audit(1618147733.889:188): pid=121421 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 11 17:29:38 buran13 kscreenlocker_greet[119046]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
apr 11 17:29:44 buran13 kscreenlocker_greet[119046]: file:///usr/share/plasma/look-and-feel/org.kde.breath2.desktop/contents/lockscreen/LockScreenUi.qml:0: ReferenceError: msg is not defined
apr 11 17:29:44 buran13 audit[121536]: USER_AUTH pid=121536 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 11 17:29:44 buran13 kcheckpass[121534]: Authentication failure for soshial (invoked by uid 1000)
apr 11 17:29:44 buran13 kernel: audit: type=1100 audit(1618147784.926:189): pid=121536 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 11 17:29:53 buran13 kscreenlocker_greet[119046]: file:///usr/share/plasma/look-and-feel/org.kde.breath2.desktop/contents/lockscreen/LockScreenUi.qml:0: ReferenceError: msg is not defined
apr 11 17:29:53 buran13 audit[121562]: USER_AUTH pid=121562 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 11 17:29:53 buran13 kcheckpass[121560]: Authentication failure for soshial (invoked by uid 1000)
apr 11 17:29:53 buran13 kernel: audit: type=1100 audit(1618147793.729:190): pid=121562 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="soshial" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
apr 11 17:29:58 buran13 sddm[542]: Adding new display on vt 2 ...
apr 11 17:29:58 buran13 sddm[542]: Loading theme configuration from ""
apr 11 17:29:58 buran13 sddm[542]: Display server starting...
apr 11 17:29:58 buran13 sddm[542]: Adding cookie to "/var/run/sddm/{8e5d8e0e-d649-4a2b-a5b0-ae8887965167}"
apr 11 17:29:58 buran13 sddm[542]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /var/run/sddm/{8e5d8e0e-d649-4a2b-a5b0-ae8887965167} -noreset -displayfd 18
