It seems that it doesn’t do the same as Windows. Is there an application that does this?
cat <archive>.001 <archive>.002 … > archive.<whatever_extension>
Make sure that unrar
and libunrar
are installed, then you can unzip it via the entry in the context menu. however, I do not know what zip to install.
