Hello everyone!
I apologize in advance for my poor english.
I recently installed Manjaro KDE on my laptop to test the system and start getting to grips with the linux environment.
The installation was successful, no hitch. The problem arises when I try to start the machine: when I press the power button, the computer brings up the screen with the ASUS logo twice for about 8-10 seconds before reaching the login. In fact, to find myself in front of the login screen it takes me at least 28 seconds.
Is there any way to reduce this waiting time? Is it normal for me to see the screen with the Asus logo twice?
The link was actually provided to help you to find this command as well:
inxi -Fazy
and
cat /etc/default/grub
I think you can stop/disable/mask NetworkManager-wait-online.service which reduces the waiting time by ~7s but first I would like to see the output of the above commands.
GRUB_DEFAULT=saved
GRUB_TIMEOUT=10
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
I hope I gave you the information you needed!
Thanks for your time
