I’m currently using Windows 10 because of some games and apps but I’d like to use Manjaro KDE. I have some experience with an old PC that I use to experimet. What I wanna ask is how to make my partitioning so only the OS (manjaro) and few games/apps to be in my ssd(250gb kingston) and the rest to be in my HDD (2tb WD Black). Basically home to be in my hdd but I can still download apps in my ssd. I hope you can understand what i want to say. I’m not sure how exactly to ask this question.
I suggest you throw everything on the SSD first. Then once it’s full, you’ll know exactly what directories you do not need on the SSD. Fix this at that point. 256G is plenty for a base install and a couple big games. If the games are through steam, you can create multiple game installation folders and move them between that.
Your HDD should be for stuff that you want to store for later. If you find that the data you put on that HDD is important and not just a bunch of downloads, get a second HDD and set that up as a mirror of the original HDD incase it fails. Get a dropbox account or whatever and upload your important files there.
I love Arch & Manjaro. I suggest when you have a moment, perhaps a weekend, to install Arch. Yes it takes time, but if you do it in a Virtual Machine, you will still be able to use your computer and can save your progress of the installation to come back later and wipe it via clean slate if you want. Why do I suggest that? Because it will teach you what’s under the hood of Manjaro of Arch of Linux and will get you used to finding answers to problems you didn’t even know you had via the best Linux wiki out there. There’s millions of videos, here’s my suggestion: https://www.youtube.com/watch?v=tVl-QNkopoE&list=PLT98CRl2KxKHjq4YVsHqp9BbfDhtImhrN
What I’m looking for is that I can kinda have 2 home directories. I want to be able to install csgo and some important apps for me in the ssd and the rest to be in the hdd. I’m not sure if that’s even possible
AFAIK, no. You can split your system with /root, /boot, /opt, etc, and have it in different places. And /home too. But /home is /home, I don’t think you can divide it more.
After, I guess you could put your /home in the HDD, install all you wish (or carefully install one thing at the time and tweak it first before install something else).
All speculation here
Then cut/paste the wanted folders, files, config files in the SSD and put back in the HDD the symlinks. Long, tedious and maybe not functional.
More simple (and it works, suggestion above maybe not) if you use intermediate software as Steam or Lutris, you can have your /home in HDD, and your Steam and Lutris libraries set to a folder within SSD.
Why not installing Linux completely on HDD, so the two bootloaders are also separated ?
Dividing two system on two data-carriers (SSD + HDD) mean that as soon one carrier is degraded two OS are degraded too. I wouldn’t do this, never, and for-all not with Windoof aside Linux.
