Papirus Icon for KDE (panel)
Hi!
I'm kind of a newbie on Manjaro KDE (switched from Elementary OS) and I'm trying to combine the Papirus Icon theme (dark one) with the Breeze Dark global theme. The icons are updated for applications, the only problem that I have is that the icons on the panel on the bottom of the screen (the bottom panel, if I'm referring to it correctly) are not updating (the only that seems to be updated is the sound icon). Is there any way I can fix this?
Additional detalis: I tried rebooting and/or logging off, but with no use. Also, I did applied the global theme with the "Use desktop layout from theme".
Thanks!
For that you need a Plasma Style theme (that contains the panel icons) like Arc, Materia or Matchama-Color. Those are made using Papirus icons.
