R4VENJ
March 24, 2022, 7:28pm
#1
I wanted to make audio drivers all up to date and installed ALSA with the terminal,
After that PANON does not “listen” to anything…
Front Audio Jack still works, but Back Audio Jack does not work too.
Researched and found nothing looking like but I saw people asking some commands:
inxi -A
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
Device-2: AMD Family 17h/19h HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
pacmd list-sinks
1 sink(s) available.
* index: 0
driver: <module-alsa-card.c>
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: RUNNING
suspend cause: (none)
priority: 9039
volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 40.60 ms
max request: 6 KiB
max rewind: 6 KiB
monitor source: 0
sample spec: s16le 2ch 44100Hz
channel map: front-left,front-right
Stereo
used by: 1
linked by: 7
configured latency: 40.00 ms; range is 0.50 .. 1999.82 ms
card: 1 <alsa_card.pci-0000_06_00.6>
module: 7
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC887-VD Analog"
alsa.id = "ALC887-VD Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "1"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xfcc80000 irq 55"
device.bus_path = "pci-0000:06:00.6"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:06:00.6/sound/card1"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "15e3"
device.product.name = "Family 17h (Models 10h-1fh) HD Audio Controller"
device.string = "front:1"
device.buffering.buffer_size = "352768"
device.buffering.fragment_size = "176384"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Family 17h (Models 10h-1fh) HD Audio Controller Analog Stereo"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
ports:
analog-output-lineout: Line Out (priority 9000, latency offset 0 usec, available: yes)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: yes)
properties:
active port: <analog-output-headphones>
sudo mhwd -a pci nonfree 0403
Warning: No config found for device: 0000:06:00.6 (0403:1022:15e3) Multimedia controller AMD Family 17h (Models 10h-1fh) HD Audio Controller
Warning: No config found for device: 0000:06:00.1 (0403:1002:15de) Multimedia controller ATI Technologies Inc Raven/Raven2/Fenghuang HDMI/DP Audio Controller
sudo mhwd -a pci free 0403
Hello,
You know, after reading this
and this
0403 stands for what exactly?
It “sounded” (pun intended) like a prank post
First of, if there was an update to alsa, then other packages had update too. To make sure your system is updated, run:
sudo pacman-mirrors -f5 && sudo pacman -Syyu
or
pamac upgrade
Once is done, reboot the system. If you installed again the alsa, a reboot will be required too.
R4VENJ
March 24, 2022, 9:35pm
#3
Hahaha
Sorry, english is not my native language, it’s not a prank, I think I’m jsut rusty in it.
I read this:
First, you run:
mhwd -lh -d --pci
look for your audio device
then run:
sudo mhwd -a pci nonfree 0300 // replace 0300 with the pci number of the audio device
or
sudo mhwd -a pci free 0300 // replace 0300 with the pci number of the audio device
And I had this returning:
mhwd -lh -d --pci
06: PCI 207.0: 0604 PCI bridge (Normal decode)
SysFS ID: /devices/pci0000:00/0000:00:01.2/0000:01:00.2/0000:02:07.0
SysFS BusID: 0000:02:07.0
Hardware Class: bridge
Model: "AMD 300 Series Chipset PCIe Port"
Vendor: pci 0x1022 "AMD"
Device: pci 0x43b4 "300 Series Chipset PCIe Port"
SubVendor: pci 0x1b21 "ASMedia Technology Inc."
SubDevice: pci 0x3306
Revision: 0x02
Driver: "pcieport"
IRQ: 34 (no events)
Module Alias: "pci:v00001022d000043B4sv00001B21sd00003306bc06sc04i00"
Attached to: #12 (PCI bridge)
07: PCI 08.0: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:08.0
SysFS BusID: 0000:00:08.0
Model: "AMD Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge"
Device: pci 0x1452 "Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge"
Module Alias: "pci:v00001022d00001452sv00000000sd00000000bc06sc00i00"
08: PCI 18.3: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:18.3
SysFS BusID: 0000:00:18.3
Model: "AMD Raven/Raven2 Device 24: Function 3"
Device: pci 0x15eb "Raven/Raven2 Device 24: Function 3"
Driver: "k10temp"
Driver Modules: "k10temp"
Module Alias: "pci:v00001022d000015EBsv00000000sd00000000bc06sc00i00"
Driver Info #0:
Driver Status: k10temp is active
Driver Activation Cmd: "modprobe k10temp"
09: PCI 01.2: 0604 PCI bridge (Normal decode)
SysFS BusID: 0000:00:01.2
Model: "AMD Raven/Raven2 PCIe GPP Bridge [6:0]"
Device: pci 0x15d3 "Raven/Raven2 PCIe GPP Bridge [6:0]"
SubVendor: pci 0x1022 "AMD"
SubDevice: pci 0x1234
Driver: "pcieport"
IRQ: 25 (no events)
Module Alias: "pci:v00001022d000015D3sv00001022sd00001234bc06sc04i00"
10: PCI 18.1: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:18.1
SysFS BusID: 0000:00:18.1
Model: "AMD Raven/Raven2 Device 24: Function 1"
Device: pci 0x15e9 "Raven/Raven2 Device 24: Function 1"
Module Alias: "pci:v00001022d000015E9sv00000000sd00000000bc06sc00i00"
11: PCI 01.0: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:01.0
SysFS BusID: 0000:00:01.0
12: PCI 100.2: 0604 PCI bridge (Normal decode)
SysFS BusID: 0000:01:00.2
Model: "AMD PCI bridge"
Device: pci 0x43b3
SubDevice: pci 0x0201
Revision: 0x02
Driver: "pcieport"
IRQ: 29 (no events)
Module Alias: "pci:v00001022d000043B3sv00001B21sd00000201bc06sc04i00"
Attached to: #9 (PCI bridge)
13: PCI 600.6: 0403 Audio device
SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:06:00.6
SysFS BusID: 0000:06:00.6
Hardware Class: sound
Model: "AMD Family 17h (Models 10h-1fh) HD Audio Controller"
Device: pci 0x15e3 "Family 17h (Models 10h-1fh) HD Audio Controller"
SubVendor: pci 0x1849 "ASRock Incorporation"
SubDevice: pci 0xd887
Driver: "snd_hda_intel"
Driver Modules: "snd_hda_intel"
Memory Range: 0xfcc80000-0xfcc87fff (rw,non-prefetchable)
IRQ: 55 (634330 events)
Module Alias: "pci:v00001022d000015E3sv00001849sd0000D887bc04sc03i00"
Driver Info #0:
Driver Status: snd_hda_intel is active
Driver Activation Cmd: "modprobe snd_hda_intel"
Attached to: #21 (PCI bridge)
14: PCI 14.3: 0601 ISA bridge
SysFS ID: /devices/pci0000:00/0000:00:14.3
SysFS BusID: 0000:00:14.3
Model: "AMD FCH LPC Bridge"
Device: pci 0x790e "FCH LPC Bridge"
SubDevice: pci 0x790e
Revision: 0x51
Module Alias: "pci:v00001022d0000790Esv00001022sd0000790Ebc06sc01i00"
15: PCI 100.0: 0c03 USB Controller (XHCI)
SysFS ID: /devices/pci0000:00/0000:00:01.2/0000:01:00.0
SysFS BusID: 0000:01:00.0
Hardware Class: usb controller
Model: "AMD USB Controller"
Device: pci 0x43bc
SubDevice: pci 0x1142
Revision: 0x02
Driver: "xhci_hcd"
Driver Modules: "xhci_pci"
Memory Range: 0xfcea0000-0xfcea7fff (rw,non-prefetchable)
IRQ: 30 (no events)
Module Alias: "pci:v00001022d000043BCsv00001B21sd00001142bc0Csc03i30"
Driver Info #0:
Driver Status: xhci_pci is active
Driver Activation Cmd: "modprobe xhci_pci"
16: PCI 206.0: 0604 PCI bridge (Normal decode)
SysFS ID: /devices/pci0000:00/0000:00:01.2/0000:01:00.2/0000:02:06.0
SysFS BusID: 0000:02:06.0
Revision: 0x02
Driver: "pcieport"
IRQ: 32 (no events)
17: PCI 700.0: 0106 SATA controller (AHCI 1.0)
SysFS ID: /devices/pci0000:00/0000:00:08.2/0000:07:00.0
SysFS BusID: 0000:07:00.0
Hardware Class: storage
Model: "AMD FCH SATA Controller [AHCI mode]"
Device: pci 0x7901 "FCH SATA Controller [AHCI mode]"
SubDevice: pci 0x7901
Revision: 0x61
Driver: "ahci"
Driver Modules: "ahci"
Memory Range: 0xfcf00000-0xfcf007ff (rw,non-prefetchable)
IRQ: 38 (no events)
Module Alias: "pci:v00001022d00007901sv00001022sd00007901bc01sc06i01"
Attached to: #32 (PCI bridge)
18: PCI 18.6: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:18.6
SysFS BusID: 0000:00:18.6
Model: "AMD Raven/Raven2 Device 24: Function 6"
Device: pci 0x15ee "Raven/Raven2 Device 24: Function 6"
Module Alias: "pci:v00001022d000015EEsv00000000sd00000000bc06sc00i00"
19: PCI 600.2: 1080 Encryption controller
SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:06:00.2
SysFS BusID: 0000:06:00.2
Hardware Class: unknown
Model: "AMD Family 17h (Models 10h-1fh) Platform Security Processor"
Device: pci 0x15df "Family 17h (Models 10h-1fh) Platform Security Processor"
SubDevice: pci 0x15df
Driver: "ccp"
Driver Modules: "ccp"
Memory Range: 0xfcb00000-0xfcbfffff (rw,non-prefetchable)
Memory Range: 0xfcc8c000-0xfcc8dfff (rw,non-prefetchable)
IRQ: 37 (no events)
Module Alias: "pci:v00001022d000015DFsv00001022sd000015DFbc10sc80i00"
Driver Info #0:
Driver Status: ccp is active
Driver Activation Cmd: "modprobe ccp"
20: PCI 00.0: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:00.0
SysFS BusID: 0000:00:00.0
Model: "AMD Raven/Raven2 Root Complex"
Device: pci 0x15d0 "Raven/Raven2 Root Complex"
SubDevice: pci 0x15d0
Module Alias: "pci:v00001022d000015D0sv00001022sd000015D0bc06sc00i00"
21: PCI 08.1: 0604 PCI bridge (Normal decode)
SysFS BusID: 0000:00:08.1
Model: "AMD Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A"
Device: pci 0x15db "Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A"
SubDevice: pci 0x0000
Driver: "pcieport"
IRQ: 26 (no events)
Module Alias: "pci:v00001022d000015DBsv00001022sd00000000bc06sc04i00"
22: PCI 18.4: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:18.4
SysFS BusID: 0000:00:18.4
Model: "AMD Raven/Raven2 Device 24: Function 4"
Device: pci 0x15ec "Raven/Raven2 Device 24: Function 4"
Module Alias: "pci:v00001022d000015ECsv00000000sd00000000bc06sc00i00"
23: PCI 600.0: 0300 VGA compatible controller (VGA)
SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:06:00.0
SysFS BusID: 0000:06:00.0
Hardware Class: graphics card
Model: "ATI Picasso"
Vendor: pci 0x1002 "ATI Technologies Inc"
Device: pci 0x15d8 "Picasso"
SubVendor: pci 0x1002 "ATI Technologies Inc"
SubDevice: pci 0x15d8
Revision: 0xcc
Driver: "amdgpu"
Driver Modules: "amdgpu"
Memory Range: 0xe0000000-0xefffffff (ro,non-prefetchable)
Memory Range: 0xf0000000-0xf01fffff (ro,non-prefetchable)
I/O Ports: 0xe000-0xe0ff (rw)
Memory Range: 0xfcc00000-0xfcc7ffff (rw,non-prefetchable)
Memory Range: 0x000c0000-0x000dffff (rw,non-prefetchable,disabled)
IRQ: 56 (no events)
I/O Port: 0x00 (rw)
Module Alias: "pci:v00001002d000015D8sv00001002sd000015D8bc03sc00i00"
Driver Info #0:
Driver Status: amdgpu is active
Driver Activation Cmd: "modprobe amdgpu"
24: PCI 18.2: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:18.2
SysFS BusID: 0000:00:18.2
Model: "AMD Raven/Raven2 Device 24: Function 2"
Device: pci 0x15ea "Raven/Raven2 Device 24: Function 2"
Module Alias: "pci:v00001022d000015EAsv00000000sd00000000bc06sc00i00"
25: PCI 500.0: 0200 Ethernet controller
SysFS ID: /devices/pci0000:00/0000:00:01.2/0000:01:00.2/0000:02:07.0/0000:05:00.0
SysFS BusID: 0000:05:00.0
Hardware Class: network
Model: "Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller"
Vendor: pci 0x10ec "Realtek Semiconductor Co., Ltd."
Device: pci 0x8168 "RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller"
SubDevice: pci 0x8168 "Motherboard (one of many)"
Revision: 0x15
Driver: "r8169"
Driver Modules: "r8169"
Device File: enp5s0
I/O Ports: 0xf000-0xf0ff (rw)
Memory Range: 0xfcd04000-0xfcd04fff (rw,non-prefetchable)
Memory Range: 0xfcd00000-0xfcd03fff (rw,non-prefetchable)
IRQ: 33 (no events)
HW Address: a8:a1:59:40:96:56
Permanent HW Address: a8:a1:59:40:96:56
Link detected: yes
Module Alias: "pci:v000010ECd00008168sv00001849sd00008168bc02sc00i00"
Driver Info #0:
Driver Status: r8169 is active
Driver Activation Cmd: "modprobe r8169"
Attached to: #6 (PCI bridge)
26: PCI 18.0: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:18.0
SysFS BusID: 0000:00:18.0
Model: "AMD Raven/Raven2 Device 24: Function 0"
Device: pci 0x15e8 "Raven/Raven2 Device 24: Function 0"
Module Alias: "pci:v00001022d000015E8sv00000000sd00000000bc06sc00i00"
27: PCI 100.1: 0106 SATA controller (AHCI 1.0)
SysFS ID: /devices/pci0000:00/0000:00:01.2/0000:01:00.1
SysFS BusID: 0000:01:00.1
Model: "AMD SATA controller"
Device: pci 0x43b8
SubDevice: pci 0x1062
Revision: 0x02
Driver: "ahci"
Memory Range: 0xfce80000-0xfce9ffff (rw,non-prefetchable)
Memory Range: 0xfce00000-0xfce7ffff (ro,non-prefetchable,disabled)
IRQ: 36 (422781 events)
Module Alias: "pci:v00001022d000043B8sv00001B21sd00001062bc01sc06i01"
28: PCI 18.7: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:18.7
SysFS BusID: 0000:00:18.7
Model: "AMD Raven/Raven2 Device 24: Function 7"
Device: pci 0x15ef "Raven/Raven2 Device 24: Function 7"
Module Alias: "pci:v00001022d000015EFsv00000000sd00000000bc06sc00i00"
29: PCI 600.3: 0c03 USB Controller (XHCI)
SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:06:00.3
SysFS BusID: 0000:06:00.3
Model: "AMD Raven2 USB 3.1"
Device: pci 0x15e5 "Raven2 USB 3.1"
SubDevice: pci 0x7914
Driver: "xhci_hcd"
Memory Range: 0xfca00000-0xfcafffff (rw,non-prefetchable)
IRQ: 44 (no events)
Module Alias: "pci:v00001022d000015E5sv00001022sd00007914bc0Csc03i30"
Driver Info #0:
30: PCI 14.0: 0c05 SMBus
SysFS ID: /devices/pci0000:00/0000:00:14.0
SysFS BusID: 0000:00:14.0
Model: "AMD FCH SMBus Controller"
Device: pci 0x790b "FCH SMBus Controller"
SubDevice: pci 0x790b
Revision: 0x61
Driver: "piix4_smbus"
Driver Modules: "i2c_piix4"
Module Alias: "pci:v00001022d0000790Bsv00001022sd0000790Bbc0Csc05i00"
Driver Info #0:
Driver Status: i2c_piix4 is active
Driver Activation Cmd: "modprobe i2c_piix4"
Driver Info #1:
Driver Status: sp5100_tco is active
Driver Activation Cmd: "modprobe sp5100_tco"
31: PCI 204.0: 0604 PCI bridge (Normal decode)
SysFS ID: /devices/pci0000:00/0000:00:01.2/0000:01:00.2/0000:02:04.0
SysFS BusID: 0000:02:04.0
Revision: 0x02
Driver: "pcieport"
IRQ: 31 (no events)
32: PCI 08.2: 0604 PCI bridge (Normal decode)
SysFS BusID: 0000:00:08.2
Model: "AMD Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus B"
Device: pci 0x15dc "Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus B"
Driver: "pcieport"
IRQ: 27 (no events)
Module Alias: "pci:v00001022d000015DCsv00001022sd00000000bc06sc04i00"
33: PCI 18.5: 0600 Host bridge
SysFS ID: /devices/pci0000:00/0000:00:18.5
SysFS BusID: 0000:00:18.5
Model: "AMD Raven/Raven2 Device 24: Function 5"
Device: pci 0x15ed "Raven/Raven2 Device 24: Function 5"
Module Alias: "pci:v00001022d000015EDsv00000000sd00000000bc06sc00i00"
34: PCI 600.1: 0403 Audio device
SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:06:00.1
SysFS BusID: 0000:06:00.1
Model: "ATI Raven/Raven2/Fenghuang HDMI/DP Audio Controller"
Device: pci 0x15de "Raven/Raven2/Fenghuang HDMI/DP Audio Controller"
SubDevice: pci 0x15de
Memory Range: 0xfcc88000-0xfcc8bfff (rw,non-prefetchable)
IRQ: 54 (519 events)
Module Alias: "pci:v00001002d000015DEsv00001002sd000015DEbc04sc03i00"
Driver Info #0:
I ran your suggestions.
also tried this:
killall -9 pulseaudio
pulseaudio --start
Gonna Reboot
Nope… Did not work
Oh! I realized I wrote wrong… It’s not PAMAC… I meant the widget PANON, it stopped working, that’s why I said it is not “listening” to anything… it is working but like there was no sound for it to interact with.
No worries.
The MHWD does not have a different driver for audio. Yours should work, as all is done via ALSA and PuleseAudio or PipeWire server.
Share inxi -Fazy
from terminal.
Panon also should work, but needs to be build (better from AUR) once your system is fully updated. Then in the settings you must chose the proper back-end. Exemple from mine:
R4VENJ
March 25, 2022, 12:29pm
#5
bogdancovaciu:
inxi -Fazy
inxi -Fazy
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=fefb540f-4d03-43b1-8f6a-ab61175f5ab6 rw quiet apparmor=1
security=apparmor resume=UUID=8470d4d2-bac8-4d52-9b7a-fcbcea759056
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.3 tk: Qt v: 5.15.3 info: latte-dock
wm: kwin_wayland vt: 2 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: A320M-HDV R4.0
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: P4.00
date: 07/16/2020
Info: model: AMD Athlon 3000G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
L1: 192 KiB desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3011 high: 3134 min/max: 1600/3500 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2980 2: 3101
3: 2830 4: 3134 bogomips: 27959
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: HDMI-A-2 empty: DP-1,HDMI-A-1 bus-ID: 06:00.0 chip-ID: 1002:15d8
class-ID: 0300
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
alternate: fbdev,vesa gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-2 res: 1440x900 size: N/A modes: N/A
OpenGL: renderer: AMD Radeon Vega 3 Graphics (RAVEN2 DRM 3.42.0
5.15.28-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.7 direct render: Yes
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 06:00.1
chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 06:00.6
chip-ID: 1022:15e3 class-ID: 0403
Sound Server-4: PipeWire v: 0.3.48 running: yes
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros AR9271 802.11n type: USB driver: ath9k_htc
bus-ID: 1-2:2 chip-ID: 0cf3:9271 class-ID: ff00 serial: <filter>
IF: wlp1s0f0u2 state: up mac: <filter>
Local Storage: total: 1.42 TiB used: 155.94 GiB (10.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS545032B9A300
size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: C60F scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 model: Pichau Gaming PG256X size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 435 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 61K1 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: SanDisk model: SSD PLUS 240GB
type: SSD serial: <filter> rev: 04RL scheme: MBR
ID-5: /dev/sde maj-min: 8:64 type: USB vendor: Seagate
model: ST500LT012-9WS142 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 0056 scheme: MBR
ID-1: / raw-size: 214.77 GiB size: 210.34 GiB (97.94%)
used: 47.43 GiB (22.6%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49
dev: /dev/sdd2 maj-min: 8:50
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 39.0 C
Processes: 251 Uptime: 3m wakeups: 0 Memory: 5.72 GiB used: 2.8 GiB (49.0%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1
Packages: 1557 pacman: 1520 lib: 384 flatpak: 22 snap: 15 Shell: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.14
More info:
I found something.
The Back Jack doesn’t work IF the Front Jack is plugged in.
I swapped the devices and the result is the same (the ports are what determines not the devices):
One device in the back works
One device in the front works
Two devices… no matter what is the order of plugging 'em in, just the front one works (when I change to the line out (back) in settings, all mute, when I change to the headphones (front), this one works.
Panon doesn’t work either of those configurations (even when a device is reproducing sound)
Panon has the PulseAudio, PortAudio, and Fifo back-end options.
Tried all back-end checkboxes/back-end/input combinations and none work.
Tried several native and downloaded Visual Effects and none work.
In settings I have:
Inactive Cards:
Raven/Raven2/Fenghuang HDMI/DP Audio Controller - Profile OFF (off is the only option)
HDMI… makes me think it’s just my monitor, but sharing this information anyway, in case I’m wrong.
Edit 1: About the Inactive Cards:
Unplugging my monitor and plugging a TV (that actually has audio output) the “Inactive Cards” section vanishes as expected… The TV output works fine with one or two devices plugged.
OPTION 1 - Family 17th (Models 10h-1fh) HD Audio Controller Analog Stereo
-------------Line Out [[[Works IF there is no front jack plugged
-------------Headphones [[[Always Work
OPTION 2 - TV [[[Always Work
Edit 2: Tried to uninstall and install again the Panon… Before, it presented itself as a frozen visual effect (even new widgets, no matter the effect) Now it is message:
Error: Failed to load the visual effect. Please choose another visual effect in the configuration dialog.
Tried several back-end/visual effects combinations, nothing works.
System updates using pamac
or pacman
package managers should include the latest available linux audio drivers
If ALSA has been reinstalled, ALSA audio settings were probably reset to default
Please post more information about ALSA audio settings
amixer --card=1
Audio output to rear jack sockets is usually muted in ALSA by Auto-Mute Mode if an audio jack is plugged in to front headphone jack socket
This command will disable auto-muting of rear audio jacks
amixer --card=1 sset 'Auto-Mute Mode' Disabled
Additional changes may be needed to unmute and set optimal audio level for outputs to Headphones or Line Out
