glmark2-es2-wayland scores improved significantly on Manjaro-Arm-KDE with the latest Update in Unstable Branch - to linux-khadas-5.18.12-1.
Manjaro-Arm-KDE-linux-khadas glmark2-es2-wayland score of 1595 to 1617.
Prior to this upgrade Manjaro-Arm-KDE-linux-khadas-5.18.5-1 glmark2-es2-wayland scores ranges 532 to 570.
Now it scored higher than Manjaro-Arm-Gnome-linux-khadas-5.18.12-1 (Gnome 42.2 Stable Branch) score ranges from 1500 to 1550.
Date: 2022-07-22
Manjaro-Arm-KDE-linux-khadas-5.18.12-1 Plasma 5.25.3-1
Governor=performance Newly installed linux-khadas-5.18.12-1 Kernel
glmark2-es2-wayland score of 1617.
With linux-khadas-5.18.5-1 (prior to upgrade/update) glmark2-es2-wayland scores 532-570 only.
Interesting.
[jfl@jfl-mnjro ~]$ glmark2-es2-wayland
glmark2 2021.02
OpenGL Information
GL_VENDOR: Panfrost
GL_RENDERER: Mali-G52 (Panfrost)
GL_VERSION: OpenGL ES 3.1 Mesa 22.1.3
[build] use-vbo=false: FPS: 1123 FrameTime: 0.890 ms
[build] use-vbo=true: FPS: 2273 FrameTime: 0.440 ms
[texture] texture-filter=nearest: FPS: 2601 FrameTime: 0.384 ms
[texture] texture-filter=linear: FPS: 2593 FrameTime: 0.386 ms
[texture] texture-filter=mipmap: FPS: 2727 FrameTime: 0.367 ms
[shading] shading=gouraud: FPS: 1691 FrameTime: 0.591 ms
[shading] shading=blinn-phong-inf: FPS: 1678 FrameTime: 0.596 ms
[shading] shading=phong: FPS: 1346 FrameTime: 0.743 ms
[shading] shading=cel: FPS: 1355 FrameTime: 0.738 ms
[bump] bump-render=high-poly: FPS: 797 FrameTime: 1.255 ms
[bump] bump-render=normals: FPS: 3369 FrameTime: 0.297 ms
[bump] bump-render=height: FPS: 3241 FrameTime: 0.309 ms
[effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 1177 FrameTime: 0.850 ms
[effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 416 FrameTime: 2.404 ms
[pulsar] light=false:quads=5:texture=false: FPS: 2969 FrameTime: 0.337 ms
[desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4: FPS: 388 FrameTime: 2.577 ms
[desktop] effect=shadow:windows=4: FPS: 1465 FrameTime: 0.683 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 245 FrameTime: 4.082 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=subdata: FPS: 247 FrameTime: 4.049 ms
[buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 303 FrameTime: 3.300 ms
[ideas] speed=duration: FPS: 763 FrameTime: 1.311 ms
[jellyfish] <default>: FPS: 1103 FrameTime: 0.907 ms
[terrain] <default>: FPS: 57 FrameTime: 17.544 ms
[shadow] <default>: FPS: 688 FrameTime: 1.453 ms
[refract] <default>: FPS: 122 FrameTime: 8.197 ms
[conditionals] fragment-steps=0:vertex-steps=0: FPS: 2453 FrameTime: 0.408 ms
[conditionals] fragment-steps=5:vertex-steps=0: FPS: 2388 FrameTime: 0.419 ms
[conditionals] fragment-steps=0:vertex-steps=5: FPS: 2403 FrameTime: 0.416 ms
[function] fragment-complexity=low:fragment-steps=5: FPS: 2438 FrameTime: 0.410 ms
[function] fragment-complexity=medium:fragment-steps=5: FPS: 2021 FrameTime: 0.495 ms
[loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 2419 FrameTime: 0.413 ms
[loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 2427 FrameTime: 0.412 ms
[loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 2076 FrameTime: 0.482 ms
glmark2 Score: 1617
