I have successfully gotten pandoc-citeproc to run. I was able to find a deb’d version compiled with all the haskell includes, so this made the task much much simpler. I have three remaining issues that I am hoping I could get some help with.
Apologies for the long post. Here are the 3 pkgbuild files:
libbibutils7 (a dependency of pandoc-citeproc-bin):
# Generated by debtap
# Maintainer: codebreaker
# Contributor: codebreaker
pkgname=libbibutils7
pkgver=6.10
pkgrel=1
pkgdesc="Bibliography file converter, shared library. COPAC, EndNote refer, EndNote XML, Pubmed XML, ISI web of science, US Library of Congress MODS, RIS, and Word 2007 bibliography. This package contains the shared library doing most of the work"
arch=('aarch64')
url="https://sourceforge.net/projects/bibutils"
license=('GPL')
groups=('')
depends=('glibc>=2.17')
options=('!strip' '!emptydirs')
source=("http://ftp.br.debian.org/debian/pool/main/b/bibutils/libbibutils7_6.10-2_arm64.deb")
sha512sums=('2893c39edfffb75efc3dfabb5d679006ca7d660ba42ce10ca47cc91d9cd12e8af48f12ac9b7e79e42e5e8f156c55523402c596a35f94ae13877f40e11632ac7a')
package(){
# Extract package data
tar xf data.tar.xz -C "${pkgdir}"
install -D -m644 "/usr/share/doc/libbibutils7/copyright" "${pkgdir}/usr/share/licenses/${pkgname}/LICENSE"
pandoc-citeproc-data (a dependency of pandoc-citeproc-bin)
pkgname=libghc-pandoc-citeproc-data
pkgver=0.16.4.1
pkgrel=1
pkgdesc="Pandoc support for Citation Style Language - data files. Pandoc-citeproc is a Haskell implementation of the Citation Style Language (CSL). Pandoc-citeproc adds to pandoc, the famous Haskell text processing tool, a Bibtex like citation and bibliographic formatting and generation facility. CSL is an XML language for specifying citation and bibliographic style files in commercial products like Endnote or Reference Manager. This package contains the data files needed to use the library."
arch=('any')
url="https://github.com/jgm/pandoc-citeproc"
license=('GPL')
groups=('')
source=("http://ftp.br.debian.org/debian/pool/main/h/haskell-pandoc-citeproc/libghc-pandoc-citeproc-data_0.16.4.1-1_all.deb")
sha512sums=('c8542a2c62133acef391110c573bf8d378f598217d5cc3b19970832ed7b9f154eacfe1a460d792cb8810a40680635a33fad35a2152f91ee1cc5f219073127b7f')
package(){
# error on install saying the copyright file is not found, even though it is there
# install -D -m644 "/usr/share/doc/libghc-pandoc-citeproc-data/copyright" "${pkgdir}/usr/share/licenses/${pkgname}/LICENSE"
pandoc-citeproc-bin:
pkgname=pandoc-citeproc-bin
pkgver=0.16.4.1
pkgrel=1
pkgdesc="Pandoc support for Citation Style Language - tools. Pandoc-citeproc is a Haskell implementation of the Citation Style Language (CSL). Pandoc filter (pandoc >= 1.12), and also has a mode for converting bibliographic databases a YAML format suitable for inclusion in pandoc YAML metadata."
arch=('aarch64')
license=('GPL')
groups=('')
depends=('bibutils>=6.10' 'glibc>=2.29' 'gmp' 'icu>=67.1' 'libffi>=3.3' 'libghc-pandoc-citeproc-data>=0.16.4.1' 'libyaml' 'pcre' 'zlib>=1.1.4')
source=("http://ftp.br.debian.org/debian/pool/main/h/haskell-pandoc-citeproc/pandoc-citeproc_0.16.4.1-1+b1_arm64.deb")
sha512sums=('ffc730fa4fe23dee55c85b5302a8bb027e6a357094ee0fa24e8e9cdbe340a1a3431d024600e128746f247c1b13b32da05153a5ceab3bd6c10a44169b2309d489')
package(){
install -D -m644 "/usr/share/doc/pandoc-citeproc/copyright" "${pkgdir}/usr/share/licenses/${pkgname}/LICENSE"
The three remaining issues are:
- libghc-pandoc-citeproc-data: in the pkgbuild file, the following line in the package function generates an error:
install -D -m644 “/usr/share/doc/libghc-pandoc-citeproc-data/copyright” “${pkgdir}/usr/share/licenses/${pkgname}/LICENSE”
==> Starting package()…
install: cannot stat ‘/usr/share/doc/libghc-pandoc-citeproc-data/copyright’: No such file or directory
==> ERROR: A failure occurred in package().
Aborting…
This error occurs despite the fact that the file /usr/share/doc/libghc-pandoc-citeproc-data/copyright is present
- libbibutils: Installation finishes successfully, but the lib is not found afterwards. Two files (well, a file and a link) are installed:
/usr/lib/aarch64-linux-gnu/libbibutils.so.7
/usr/lib/aarch64-linux-gnu/libbibutils.so.7.0
but as I said, they are not found. If I copy these two files to /usr/lib and run ldconfig, they are found by the system and are usable.
- pandoc-citeproc-bin: When I run makepkg I get the following error:
$ makepkg
==> Making package: pandoc-citeproc-bin 0.16.4.1-1 (Fri 04 Sep 2020 12:50:57 PM EDT)
==> Checking runtime dependencies…
==> Missing dependencies:
-> bibutils>=6.10
==> Checking buildtime dependencies…
==> ERROR: Could not resolve all dependencies.
This occurs even if I have already installed libbibutils, and copied the lib files and run ldconfig as described above.
I would be grateful for any help on any of these issues is. So close!
