Pamac won't open from icon in start menu -- new installation of Manjaro KDE
I just downloaded Manjaro KDE. I am able to open pamac from the cmd line but unable to open it from the icon. How can I fix this? Thank you!
Hello, you need to click on it and from that dropdown menu it shows up, you select Package Manager entry.
Anyway, you should perform a full update, even tho is new install:
sudo pacman-mirrors -f && sudo pacman -Syyu
reboot after that and then things should be more coherent.
