Pamac Will not launch
I was updating a few items in the pamac manager today, while doing some other things, anyways my desktop freaked out, started breaking, I hard reset it, and now pamac won’t launch and gives me this
“Launching add/remove software (Failed)”
"The name org.manjaro.pamac.manager was not provided by any .service files "
Yes I have tried restarting, I appreciate any help.
Likely you will want to look at your logs to see where the interrupt happened:
less /var/log/pacman.log
What happens if you run pacman?
sudo pacman -Syu
You may want to reinstall some packages, ex:
sudo pacman -Syu libpamac pamac-cli pamac-gtk
Please report any errors or pertinent output.
Do you see any errors when launched from terminal?
pamac-manager
It’s not a good idea to do updates with many other apps open. It can cause incompatibilities between the running programs and newly updated libraries. That can lead to crashes like the one you experienced today.
it does nothing when launched from terminal
I tried to reinstall, but it told me it couldn’t due to conflicting files, past that i saw a bunch of ^@^@^@^@ in the console with a white background, unsure of what that means, but i also found
ldconfig: File /usr/lib/libpamac.so.11.5 is empty, n
ot checked.
[2023-04-17T16:58:38-0500] [ALPM-SCRIPTLET] ldconfig: File /usr/lib/libpamac-gtk.so is empty, not checked.
[2023-04-17T16:58:38-0500] [ALPM-SCRIPTLET] ldconfig: File /usr/lib/libpamac-flatpak.so is empty, not checked.
[2023-04-17T16:58:38-0500] [ALPM-SCRIPTLET] ldconfig: File /usr/lib/libpamac.so.11 is empty, not checked.
[2023-04-17T16:58:38-0500] [ALPM-SCRIPTLET] ldconfig: File /usr/lib/libpamac-flatpak.so.11.5 is empty, not checked.
[2023-04-17T16:58:38-0500] [ALPM-SCRIPTLET] ldconfig: File /usr/lib/libpamac.so is empty, not checked.
[2023-04-17T16:58:38-0500] [ALPM-SCRIPTLET] ldconfig: File /usr/lib/libpamac-flatpak.so.11 is empty, not checked.
Idk if those mean anything or of help.
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
So you can try again with overwrite (normally avoid this. use with caution)
sudo pacman -Syu libpamac pamac-cli pamac-gtk --overwrite='/usr/lib/libpamac*'
(without the full output/logs its hard to know what all needs to be replaced … but we can start there … I am loathe to simply suggest “overwrite=‘*’”)
Aren’t the libraries being used by running programs copied to memory? So overwriting the file shouldn’t affect the running code?
idk but i guess it makes sense why, I was doing stuff on steam while it was updating so i think it did interfere and screw it up
This is the output I got when I put that in
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
warning: libpamac-11.5.2-3 is up to date -- reinstalling
warning: pamac-cli-10.5.0-2 is up to date -- reinstalling
warning: pamac-gtk-10.5.0-2 is up to date -- reinstalling
resolving dependencies...
Packages (3) libpamac-11.5.2-3  pamac-cli-10.5.0-2  pamac-gtk-10.5.0-2
Total Installed Size:  4.40 MiB
:: Proceed with installation? [Y/n] y
(3/3) checking keys in keyring                            [###############################] 100%
(3/3) checking package integrity                          [###############################] 100%
(3/3) loading package files                               [###############################] 100%
(3/3) checking for file conflicts                         [###############################] 100%
error: failed to commit transaction (conflicting files)
libpamac: /etc/dbus-1/system.d/org.manjaro.pamac.daemon.conf exists in filesystem
libpamac: /usr/bin/dependency-checker exists in filesystem
libpamac: /usr/bin/outdated-checker exists in filesystem
libpamac: /usr/bin/pamac-daemon exists in filesystem
libpamac: /usr/include/pamac.h exists in filesystem
libpamac: /usr/lib/girepository-1.0/Pamac-11.typelib exists in filesystem
libpamac: /usr/lib/pkgconfig/pamac.pc exists in filesystem
libpamac: /usr/lib/systemd/system/pamac-cleancache.service exists in filesystem
libpamac: /usr/lib/systemd/system/pamac-cleancache.timer exists in filesystem
libpamac: /usr/lib/systemd/system/pamac-daemon.service exists in filesystem
libpamac: /usr/lib/systemd/system/pamac-mirrorlist.service exists in filesystem
libpamac: /usr/lib/systemd/system/pamac-mirrorlist.timer exists in filesystem
libpamac: /usr/share/dbus-1/system-services/org.manjaro.pamac.daemon.service exists in filesystem
libpamac: /usr/share/gir-1.0/Pamac-11.gir exists in filesystem
libpamac: /usr/share/locale/af/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/ar/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/ast/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/az/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/az_AZ/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/be/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/bg/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/bn/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/bs/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/ca/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/ca@valencia/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/co/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/cs/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/cy/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/da/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/de/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/de_AT/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/de_CH/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/de_DE/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/el/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/el_GR/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/en_GB/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/en_ee/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/eo/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/es/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/es_419/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/es_AR/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/es_ES/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/es_MX/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/es_SV/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/et/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/eu/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/fa/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/fa_IR/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/fi/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/fo/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/fr/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/gl/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/gl_ES/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/gug_PY/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/he/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/he_IL/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/hi/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/hi_IN/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/hr/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/hr_HR/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/hu/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/id/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/ie/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/is/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/is_IS/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/it/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/it_IT/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/ja/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/ka/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/kab/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/kk/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/ko/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/lt/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/ml/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/ms/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/nb/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/ne/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/ne_NP/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/nl/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/nl_BE/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/nl_NL/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/nn/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/or/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/pl/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/pl_PL/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/pt/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/pt_BR/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/pt_PT/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/ro/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/ru/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/si/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/sk/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/sl/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/sl_SI/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/sq/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/sq_AL/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/sr/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/sr@latin/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/sr_RS/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/sr_RS@latin/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/sv/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/sw/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/ta/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/tr/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/uk/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/ur_PK/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/uz/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/vi/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/zh/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/zh_CN/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/locale/zh_TW/LC_MESSAGES/pamac.mo exists in filesystem
libpamac: /usr/share/mime/packages/x-alpm-package.xml exists in filesystem
libpamac: /usr/share/polkit-1/actions/org.manjaro.pamac.policy exists in filesystem
libpamac: /usr/share/vala/vapi/pamac.vapi exists in filesystem
pamac-cli: /usr/bin/pamac exists in filesystem
pamac-cli: /usr/share/bash-completion/completions/pamac exists in filesystem
pamac-cli: /usr/share/fish/vendor_completions.d/pamac.fish exists in filesystem
pamac-cli: /usr/share/man/man5/pamac.conf.5.gz exists in filesystem
pamac-cli: /usr/share/man/man8/pamac.8.gz exists in filesystem
pamac-cli: /usr/share/zsh/site-functions/_pamac exists in filesystem
pamac-gtk: /etc/xdg/autostart/pamac-tray-budgie.desktop exists in filesystem
pamac-gtk: /etc/xdg/autostart/pamac-tray.desktop exists in filesystem
pamac-gtk: /usr/bin/pamac-installer exists in filesystem
pamac-gtk: /usr/bin/pamac-manager exists in filesystem
pamac-gtk: /usr/bin/pamac-tray exists in filesystem
pamac-gtk: /usr/include/pamac-gtk.h exists in filesystem
pamac-gtk: /usr/lib/systemd/system/pamac-offline-upgrade.service exists in filesystem
pamac-gtk: /usr/share/applications/org.manjaro.pamac.manager.desktop exists in filesystem
pamac-gtk: /usr/share/applications/pamac-installer.desktop exists in filesystem
pamac-gtk: /usr/share/dbus-1/services/org.manjaro.pamac.manager.service exists in filesystem
pamac-gtk: /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/README.md exists in filesystem
pamac-gtk: /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/extension.js exists in filesystem
pamac-gtk: /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/metadata.json exists in filesystem
pamac-gtk: /usr/share/gnome-shell/extensions/pamac-updates@manjaro.org/stylesheet.css exists in filesystem
pamac-gtk: /usr/share/gnome-shell/search-providers/org.manjaro.pamac.manager.search-provider.ini exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/16x16/apps/system-software-install.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/32x32/apps/system-software-install.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/48x48/apps/system-software-install.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/scalable/actions/view-sidebar-end-symbolic.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/scalable/actions/view-sidebar-start-symbolic.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/scalable/emblems/globe-symbolic.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/scalable/status/installed-check.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/scalable/status/pamac-tray-no-update.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/scalable/status/pamac-tray-update.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/scalable/status/software-install-symbolic.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/scalable/status/software-remove-symbolic.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/scalable/status/software-select-symbolic.svg exists in filesystem
pamac-gtk: /usr/share/icons/hicolor/scalable/status/software-update-symbolic.svg exists in filesystem
pamac-gtk: /usr/share/vala/vapi/pamac-gtk.vapi exists in filesystem
Please format logs by surrounding them with triple backticks ```
Like so:
log output lines
more log output lines
Since you have a functional package manager in pacman,
And in order to avoid using a glob* with overwrite,
You can just uninstall, wipe out possibly faulty cache, and reinstall:
sudo pacman -Rn pamac-gtk pamac-cli libpamac
paccache -rvk0 pamac-gtk pamac-cli libpamac
I should also encourage you again to look at /var/log/pacman.log to see where the interrupt occurred, and which packages may be affected.
I got this, when putting in the first command
checking dependencies…
:: removing libpamac breaks dependency ‘libpamac>=11’ required by manjaro-application-utility
:: removing pamac-cli breaks dependency ‘pamac-cli’ required by manjaro-application-utility
:: removing pamac-gtk breaks dependency ‘pamac-gtk’ required by manjaro-application-utility
:: removing pamac-gtk breaks dependency ‘pamac-gtk>=9.5.12’ required by pamac-tray-icon-plasma
:: removing libpamac breaks dependency ‘libpamac’ required by python-manjaro-sdk
also looked through logs,
[2023-04-17T16:58:34-0500] [PACMAN] Running ‘pacman -S extra/gtk3’
[2023-04-17T16:58:38-0500] [ALPM] running ‘00-timeshift-autosnap.hook’…
[2023-04-17T16:58:38-0500] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosna
p in /etc/timeshift-autosnap.conf set to TRUE.
[2023-04-17T16:58:38-0500] [ALPM] transaction started
[2023-04-17T16:58:38-0500] [ALPM] reinstalled gtk3 (1:3.24.37-1)
[2023-04-17T16:58:38-0500] [ALPM-SCRIPTLET] ldconfig: File /usr/lib/libpamac.so.11.5 is empty, n
ot checked.
t checked.
, not checked.
checked.
empty, not checked.
ecked.
pty, not checked.
does this help?
Also note the difference between backticks, apostrophes, and quotation marks:
Er… dont usually use these flags … but in order to not go back and forth for 6 messages…
sudo pacman -Rddn pamac-gtk pamac-cli libpamac
put in the commands, the first two went through ok, however the third one resulted in this
libpamac: /usr/lib/libpamac.so exists in filesystem
libpamac: /usr/lib/libpamac.so.11 exists in filesystem
libpamac: /usr/lib/libpamac.so.11.5 exists in filesystem
pamac-gtk: /usr/lib/libpamac-gtk.so exists in filesystem
And the last one I suppose you can use overwrite
sudo pacman -Syu libpamac pamac-cli pamac-gtk --overwrite '/usr/*','/etc/dbus-1/system.d/*'
that had errors too, I think im just gonna backup my files and reset my manjaro, I guess pamac is just dead now
Which errors?
A Linux system is always repairable. However, it depends on how much effort you want to put in.
If you have a reasonable backup, a new installation seems the better approach.
