For a while pamac upgrade fails, because one AUR package (dropbox) has a compilation error. How could I still update the other packages until the error is solved?
Also a somehow related question: how could I update a single package (and its dependencies)?
You dont, unless you are trying for a partial-upgrade which is the same thing as broken.
On the other hand … pamac defaults to upgrading the AUR as well as regular packages, which should not be necessary unless you really mucked up the system with it heavily relying on core components provided from the AUR.
So, a normal system upgrade using pacman would not include that and should be safe…
sudo pacman -Syu
Though … your dropbox compilation(?) error is likely fixable as well.
I hope the dropbox issue will be fixable, though I tried to solve the issue maybe the 5th time in the last month. None seemed to work, and the error message is short, and now makes no sense to me. (PGP error, but dropbox’s key is imported)
Somewhere it makes sense what you wrote, but the fragility of this system is frightening. In my case I am confident that dropbox won’t break anything else.
Where should I look for the meaning the switches after the pamac command you wrote? It is written in many sites, what the combination should be used, but nothing more. It is not in the manual (man pamac), not in Manjaro wiki, and found little info by searching for it. I have a guess, what u and y is standing for, but it is unsettling feeling that I do not know where to look for such information.
I think you do not realize pamac and pacman are 2 different things.
man pacman
-S, --sync
Synchronize packages. Packages are installed directly from the
remote repositories, including all dependencies required to run the
packages. For example, pacman -S qt will download and install qt
and all the packages it depends on. If a package name exists in
more than one repository, the repository can be explicitly
specified to clarify the package to install: pacman -S testing/qt.
You can also specify version requirements: pacman -S "bash>=3.2".
Quotes are needed, otherwise the shell interprets ">" as
redirection to a file.
In addition to packages, groups can be specified as well. For
example, if gnome is a defined package group, then pacman -S gnome
will provide a prompt allowing you to select which packages to
install from a numbered list. The package selection is specified
using a space- and/or comma-separated list of package numbers.
Sequential packages may be selected by specifying the first and
last package numbers separated by a hyphen (-). Excluding packages
is achieved by prefixing a number or range of numbers with a caret
-y, --refresh
Download a fresh copy of the master package database from the
server(s) defined in pacman.conf(5). This should typically be used
each time you use --sysupgrade or -u. Passing two --refresh or -y
flags will force a refresh of all package databases, even if they
appear to be up-to-date.
-u, --sysupgrade
Upgrades all packages that are out-of-date. Each
currently-installed package will be examined and upgraded if a
newer package exists. A report of all packages to upgrade will be
presented, and the operation will not proceed without user
confirmation. Dependencies are automatically resolved at this level
and will be installed/upgraded if necessary.
Pass this option twice to enable package downgrades; in this case,
pacman will select sync packages whose versions do not match with
the local versions. This can be useful when the user switches from
a testing repository to a stable one.
Additional targets can also be specified manually, so that -Su foo
will do a system upgrade and install/upgrade the "foo" package in
the same operation.
You can unselect all and then select the one program you want to upgrade.
You can also just unselect the AUR program you don’t want to upgrade and then upgrade the rest and come back to the AUR program after. It is as simple as clicking the green check mark.
That could be the case… It is so easy to misread one, if the other name appeared just before.
When I moved to Manjaro, I read somewhere that I should not use pacman directly, but through pamac. Maybe that’s why I have not noticed the difference. Sorry.
Furthermore, the Manjaro wiki contains an overview of pamac (also called Add/Remove software). pamac is the default package manager of Manjaro. pamac can be used in two ways: as a graphical user interface (Pamac GUI) or as a command line interface (Pamac CLI).
