Hi, since system update from 2020-12-30 I have problem with pamac (version 10.0.4.-2) updates:
updates are often not showing automatically
I think that this is connected with problem, than also database is not download / update automatically
I even tried to delete database manually, then load manually, which leads to show some updates
3a. I didn’t made update and tried to restart pc
3b. after restart again, no update - I have to load database manually to show them off
of course, that everything is installed and setted up right way
So, do any have some idea, how to resolve this out please? Or it’s some bug in pamac?
Also, does anyone know if is pamac-qt ready to use as primary packages gui?
I had the same problem too not too long ago with updates not showing in Pamac. I can suggest checking if you have Software Mode box checked. It is under the menu on the upper right corner of Pamac GUI. I had updates not showing until I refreshed my mirrors, checked the Software Mode box, refreshed the mirrors again and used the terminal as @Frenchy and @cjean suggested.
Thank all for trying to help. But I think, that there is some misunderstanding. I can update system with pacman, also I can update system with pamac. Problem is, that pamac not finding updates automatically, I have to manually load database every time when I restart PC.
I’ve done some internet research and it seems that this is some bug in pamac (as @ Citroen wrote) which appears only in some systems - I think KDE related.
OK, no problem. I’ve just seen the link on the Pamac issue. And it does, as you’ve pointed out, seem to be specific to Pamac.
For my part, the bug seems to have ironed itself out, since my Chromium update came through yesterday. I shall definitely be watching this space though.
i get a notice about available updates but after restarting the PC they are gone and i have to refresh the database to get them to show.
i think it’s similar to what is said here.
