Pamac Update on Manjaro Sway
I’m running Manjaro Sway
I’m getting the following while doing sudo pamac update.
Apply transaction ? [y/N] y
Download of manjaro-sway-settings (15.3.1-34) started
Download of manjaro-sway-settings (15.3.1-34) finished
Download of wlsunset (0.3.0-1) started
Download of wlsunset (0.3.0-1) finished
Downloading manjaro-sway-settings (15.3.1-34)...
Downloading wlsunset (0.3.0-1)...
Checking keyring...
Checking integrity...
Error: manjaro-sway-settings:
    signature from "Jonas Strassel <info@jonas-strassel.de>" is unknown trust
Error: wlsunset:
Removing invalid files and retrying...
Resolving dependencies...
Checking inter-conflicts...
Checking keyring...
Error: wlsunset:
Error: Failed to commit transaction: invalid or corrupted package (PGP signature):
No sudo required.
Thx @cscs. I have been running the update with sudo for ages, don’t recall why though.
:+1:
pacman does require it for transactions, such as update:
sudo pacman -Syu
pamac on the other hand is all about convenience, so simple syntax is used and privileges are prompted.
…Maybe thats why? Anyhoo. Glad its all sorted. :slight_smile:
