I ran into an issue with pamac after a game crash that killed X. When running pamac update
as my regular login user I started getting the “Authentication Failed” error.
After searching through some of the pamac code, systemd stuff, and info about dbus and polkit I realized there error was related to this pamac code on github:
…/src/system_daemon.vala#L272
In particular, the authorization check for org.manjaro.pamac.commit
but from there couldn’t figure out what was causing the error.
Later, on the manjaro forum, I found two posts that have been auto-closed:
…/t/authentication-failed-with-pamac/37868
and
…/t/pamac-authentication-failure/41280/3
Both refer to the users having a proc
mounting entry in /etc/fstab
with specific hardening settings. I do not have this in my fstab, however I noticed in the first of the two post that user “Whathe” mentioned adding his user to the proc
group may be a solution.
I tested this out and it does indeed fix the issue.
My concern then was introducing an unnecessarily increased attack surface to the proc
group. So I removed my user from the proc
group and tested pamac update
again in yet a new session. The update worked so I assume that this exercise removed some sort of confused state introduced during the crash I mentioned at the beginning of this post.
Wanted to log this here so that others that see the posts I mentioned, who also don’t have proc
mounts in their fstab may find the solution more easily while not keeping their users added to the proc
group.
