Pamac-manager segfaults
Hi,
I am running Manjaro KDE, Linux kernel 5.4.100 on an AMD CPU and ASRock motherboard.
For over a month now, my Manjaro KDE’s system tray has not been showing the pamac-manager icon (and the relevant notification in case there are updates available). I tried to run pamac-manager from the command line, but it leads to a segmentation fault.
Any ideas how can this be fixed ?
Thanks & The strace is logged below:
execve("/usr/bin/pamac-manager", ["pamac-manager"], 0x7ffeb505aff0 /* 60 vars */) = 0
brk(NULL)                               = 0x5570eec78000
arch_prctl(0x3001 /* ARCH_??? */, 0x7ffdf5561150) = -1 EINVAL (Invalid argument)
readlink("/proc/self/exe", "/usr/bin/pamac-manager", 4096) = 22
access("/etc/ld.so.preload", R_OK)      = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/bin/glibc-hwcaps/x86-64-v3/libpamac.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/usr/bin/glibc-hwcaps/x86-64-v3", 0x7ffdf5560370, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/bin/glibc-hwcaps/x86-64-v2/libpamac.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/usr/bin/glibc-hwcaps/x86-64-v2", 0x7ffdf5560370, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/bin/tls/x86_64/x86_64/libpamac.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/usr/bin/tls/x86_64/x86_64", 0x7ffdf5560370, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/bin/tls/x86_64/libpamac.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/usr/bin/tls/x86_64", 0x7ffdf5560370, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/bin/tls/libpamac.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/usr/bin/tls", 0x7ffdf5560370, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/bin/x86_64/x86_64/libpamac.so", O_RDONLY|O_CLOEXEC) = -1 ENOTDIR (Not a directory)
newfstatat(AT_FDCWD, "/usr/bin/x86_64/x86_64", 0x7ffdf5560370, 0) = -1 ENOTDIR (Not a directory)
openat(AT_FDCWD, "/usr/bin/x86_64/libpamac.so", O_RDONLY|O_CLOEXEC) = -1 ENOTDIR (Not a directory)
newfstatat(AT_FDCWD, "/usr/bin/x86_64", {st_mode=S_IFREG|0755, st_size=22856, ...}, 0) = 0
openat(AT_FDCWD, "/usr/bin/libpamac.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/usr/bin", {st_mode=S_IFDIR|0755, st_size=143360, ...}, 0) = 0
openat(AT_FDCWD, "/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=197984, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 197984, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7f91bba37000
close(3)                                = 0
openat(AT_FDCWD, "/usr/lib/libpamac.so", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \200\1\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=4640584, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91bba35000
mmap(NULL, 718760, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91bb985000
mmap(0x7f91bb99d000, 454656, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x18000) = 0x7f91bb99d000
mmap(0x7f91bba0c000, 143360, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x87000) = 0x7f91bba0c000
mmap(0x7f91bba2f000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa9000) = 0x7f91bba2f000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libpamac-gtk.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libpamac-gtk.so", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 `\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=523224, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 102616, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91bb96b000
mprotect(0x7f91bb971000, 73728, PROT_NONE) = 0
mmap(0x7f91bb971000, 40960, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7f91bb971000
mmap(0x7f91bb97b000, 28672, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x10000) = 0x7f91bb97b000
mmap(0x7f91bb983000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x17000) = 0x7f91bb983000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libgtk-3.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libgtk-3.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0  \10\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=7836048, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 7859248, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91bb1ec000
mprotect(0x7f91bb26e000, 7233536, PROT_NONE) = 0
mmap(0x7f91bb26e000, 3502080, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x82000) = 0x7f91bb26e000
mmap(0x7f91bb5c5000, 3727360, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3d9000) = 0x7f91bb5c5000
mmap(0x7f91bb954000, 73728, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x767000) = 0x7f91bb954000
mmap(0x7f91bb966000, 19504, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f91bb966000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libgdk-3.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libgdk-3.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \240\2\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=1018160, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 1023648, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91bb0f2000
mprotect(0x7f91bb11c000, 811008, PROT_NONE) = 0
mmap(0x7f91bb11c000, 495616, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2a000) = 0x7f91bb11c000
mmap(0x7f91bb195000, 311296, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa3000) = 0x7f91bb195000
mmap(0x7f91bb1e2000, 40960, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xef000) = 0x7f91bb1e2000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libgdk_pixbuf-2.0.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libgdk_pixbuf-2.0.so.0", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=145088, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 147808, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91bb0cd000
mprotect(0x7f91bb0d3000, 118784, PROT_NONE) = 0
mmap(0x7f91bb0d3000, 81920, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7f91bb0d3000
mmap(0x7f91bb0e7000, 32768, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1a000) = 0x7f91bb0e7000
mmap(0x7f91bb0f0000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x22000) = 0x7f91bb0f0000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libgio-2.0.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libgio-2.0.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 p\3\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=1805392, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 1815176, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91baf11000
mprotect(0x7f91baf48000, 1552384, PROT_NONE) = 0
mmap(0x7f91baf48000, 1032192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x37000) = 0x7f91baf48000
mmap(0x7f91bb044000, 516096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x133000) = 0x7f91bb044000
mmap(0x7f91bb0c3000, 32768, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1b1000) = 0x7f91bb0c3000
mmap(0x7f91bb0cb000, 4744, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f91bb0cb000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libgobject-2.0.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libgobject-2.0.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \340\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=354216, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91baf0f000
mmap(NULL, 359344, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91baeb7000
mmap(0x7f91baec5000, 188416, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe000) = 0x7f91baec5000
mmap(0x7f91baef3000, 98304, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3c000) = 0x7f91baef3000
mmap(0x7f91baf0b000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x53000) = 0x7f91baf0b000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libglib-2.0.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libglib-2.0.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\320\1\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=1256856, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 1262312, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91bad82000
mprotect(0x7f91bad9f000, 1134592, PROT_NONE) = 0
mmap(0x7f91bad9f000, 573440, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1d000) = 0x7f91bad9f000
mmap(0x7f91bae2b000, 557056, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa9000) = 0x7f91bae2b000
mmap(0x7f91baeb4000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x131000) = 0x7f91baeb4000
mmap(0x7f91baeb6000, 744, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f91baeb6000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libsoup-2.4.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libsoup-2.4.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \320\1\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=649760, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 654280, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91bace2000
mprotect(0x7f91bacff000, 512000, PROT_NONE) = 0
mmap(0x7f91bacff000, 348160, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1d000) = 0x7f91bacff000
mmap(0x7f91bad54000, 159744, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x72000) = 0x7f91bad54000
mmap(0x7f91bad7c000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x99000) = 0x7f91bad7c000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`|\2\0\0\0\0\0"..., 832) = 832
pread64(3, "\6\0\0\0\4\0\0\0@\0\0\0\0\0\0\0@\0\0\0\0\0\0\0@\0\0\0\0\0\0\0"..., 784, 64) = 784
pread64(3, "\4\0\0\0@\0\0\0\5\0\0\0GNU\0\2\0\0\300\4\0\0\0\3\0\0\0\0\0\0\0"..., 80, 848) = 80
pread64(3, "\4\0\0\0\24\0\0\0\3\0\0\0GNU\0T\246\344\4\347\334\35\347\301CJ\0\267\261\2552"..., 68, 928) = 68
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=2154488, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 1884632, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91bab15000
mmap(0x7f91bab3b000, 1359872, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x26000) = 0x7f91bab3b000
mmap(0x7f91bac87000, 311296, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x172000) = 0x7f91bac87000
mmap(0x7f91bacd3000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1bd000) = 0x7f91bacd3000
mmap(0x7f91bacd9000, 33240, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f91bacd9000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libalpm.so.12", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libalpm.so.12", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 p\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=223592, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 226168, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91baadd000
mmap(0x7f91baae4000, 143360, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x7f91baae4000
mmap(0x7f91bab07000, 49152, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2a000) = 0x7f91bab07000
mmap(0x7f91bab13000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x35000) = 0x7f91bab13000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libm.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260\363\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=1327568, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 1327128, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba998000
mprotect(0x7f91ba9a7000, 1261568, PROT_NONE) = 0
mmap(0x7f91ba9a7000, 634880, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xf000) = 0x7f91ba9a7000
mmap(0x7f91baa42000, 622592, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xaa000) = 0x7f91baa42000
mmap(0x7f91baadb000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x142000) = 0x7f91baadb000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libjson-glib-1.0.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libjson-glib-1.0.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \220\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=169816, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91ba996000
mmap(NULL, 172472, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba96b000
mprotect(0x7f91ba974000, 131072, PROT_NONE) = 0
mmap(0x7f91ba974000, 86016, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9000) = 0x7f91ba974000
mmap(0x7f91ba989000, 40960, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1e000) = 0x7f91ba989000
mmap(0x7f91ba994000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x28000) = 0x7f91ba994000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libappstream-glib.so.8", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libappstream-glib.so.8", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 p\1\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=433064, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 436008, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba900000
mprotect(0x7f91ba917000, 323584, PROT_NONE) = 0
mmap(0x7f91ba917000, 212992, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x17000) = 0x7f91ba917000
mmap(0x7f91ba94b000, 106496, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4b000) = 0x7f91ba94b000
mmap(0x7f91ba966000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x65000) = 0x7f91ba966000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libgmodule-2.0.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libgmodule-2.0.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \20\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=14064, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 16512, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba8fb000
mmap(0x7f91ba8fc000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x7f91ba8fc000
mmap(0x7f91ba8fd000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91ba8fd000
mmap(0x7f91ba8fe000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91ba8fe000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libpthread.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libpthread.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\300\200\0\0\0\0\0\0"..., 832) = 832
pread64(3, "\4\0\0\0@\0\0\0\5\0\0\0GNU\0\2\0\0\300\4\0\0\0\3\0\0\0\0\0\0\0"..., 80, 792) = 80
pread64(3, "\4\0\0\0\24\0\0\0\3\0\0\0GNU\0\362\31\276gD\247\336\310\337\r\250\255\2518<\266"..., 68, 872) = 68
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=154032, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 131440, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba8da000
mmap(0x7f91ba8e1000, 61440, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x7f91ba8e1000
mmap(0x7f91ba8f0000, 20480, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x16000) = 0x7f91ba8f0000
mmap(0x7f91ba8f5000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1a000) = 0x7f91ba8f5000
mmap(0x7f91ba8f7000, 12656, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f91ba8f7000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libpangocairo-1.0.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libpangocairo-1.0.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 P\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=63296, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 65720, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba8c9000
mprotect(0x7f91ba8ce000, 40960, PROT_NONE) = 0
mmap(0x7f91ba8ce000, 28672, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5000) = 0x7f91ba8ce000
mmap(0x7f91ba8d5000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc000) = 0x7f91ba8d5000
mmap(0x7f91ba8d8000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe000) = 0x7f91ba8d8000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libpango-1.0.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libpango-1.0.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \360\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=329480, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 332488, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba877000
mprotect(0x7f91ba886000, 258048, PROT_NONE) = 0
mmap(0x7f91ba886000, 159744, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xf000) = 0x7f91ba886000
mmap(0x7f91ba8ad000, 94208, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x36000) = 0x7f91ba8ad000
mmap(0x7f91ba8c5000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4d000) = 0x7f91ba8c5000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libharfbuzz.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libharfbuzz.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\240\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=863968, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91ba875000
mmap(NULL, 866744, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba7a1000
mprotect(0x7f91ba7ab000, 819200, PROT_NONE) = 0
mmap(0x7f91ba7ab000, 606208, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa000) = 0x7f91ba7ab000
mmap(0x7f91ba83f000, 208896, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9e000) = 0x7f91ba83f000
mmap(0x7f91ba873000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xd1000) = 0x7f91ba873000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libcairo.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libcairo.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0  \1\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=1166680, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 1173424, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba682000
mmap(0x7f91ba694000, 860160, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x12000) = 0x7f91ba694000
mmap(0x7f91ba766000, 217088, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe4000) = 0x7f91ba766000
mmap(0x7f91ba79b000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x118000) = 0x7f91ba79b000
mmap(0x7f91ba7a0000, 1968, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f91ba7a0000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libpangoft2-1.0.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libpangoft2-1.0.so.0", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=91832, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 94544, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba66a000
mprotect(0x7f91ba671000, 61440, PROT_NONE) = 0
mmap(0x7f91ba671000, 40960, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x7f91ba671000
mmap(0x7f91ba67b000, 16384, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x11000) = 0x7f91ba67b000
mmap(0x7f91ba680000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x15000) = 0x7f91ba680000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libfontconfig.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libfontconfig.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \200\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=300736, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 303744, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba61f000
mprotect(0x7f91ba627000, 262144, PROT_NONE) = 0
mmap(0x7f91ba627000, 159744, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8000) = 0x7f91ba627000
mmap(0x7f91ba64e000, 98304, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2f000) = 0x7f91ba64e000
mmap(0x7f91ba667000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x47000) = 0x7f91ba667000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libfreetype.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libfreetype.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \320\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=861880, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 864272, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba54b000
mprotect(0x7f91ba558000, 782336, PROT_NONE) = 0
mmap(0x7f91ba558000, 548864, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xd000) = 0x7f91ba558000
mmap(0x7f91ba5de000, 229376, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x93000) = 0x7f91ba5de000
mmap(0x7f91ba617000, 32768, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xcb000) = 0x7f91ba617000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libfribidi.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libfribidi.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0  \0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=120632, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 123040, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba52c000
mmap(0x7f91ba52e000, 20480, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91ba52e000
mmap(0x7f91ba533000, 90112, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x7f91ba533000
mmap(0x7f91ba549000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1c000) = 0x7f91ba549000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libcairo-gobject.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libcairo-gobject.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 @\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=42520, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91ba52a000
mmap(NULL, 45336, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba51e000
mprotect(0x7f91ba522000, 20480, PROT_NONE) = 0
mmap(0x7f91ba522000, 8192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x7f91ba522000
mmap(0x7f91ba524000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7f91ba524000
mmap(0x7f91ba527000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8000) = 0x7f91ba527000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libatk-1.0.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libatk-1.0.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \260\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=161480, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 165048, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba4f5000
mmap(0x7f91ba500000, 57344, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xb000) = 0x7f91ba500000
mmap(0x7f91ba50e000, 49152, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x19000) = 0x7f91ba50e000
mmap(0x7f91ba51a000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x24000) = 0x7f91ba51a000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libepoxy.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libepoxy.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \340\5\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=1246560, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 1249160, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba3c4000
mmap(0x7f91ba422000, 421888, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5e000) = 0x7f91ba422000
mmap(0x7f91ba489000, 380928, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc5000) = 0x7f91ba489000
mmap(0x7f91ba4e6000, 61440, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x121000) = 0x7f91ba4e6000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libXi.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libXi.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 0\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=71464, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 73864, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba3b1000
mmap(0x7f91ba3b4000, 45056, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f91ba3b4000
mmap(0x7f91ba3bf000, 12288, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe000) = 0x7f91ba3bf000
mmap(0x7f91ba3c2000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x10000) = 0x7f91ba3c2000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libX11.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libX11.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \300\1\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=1308752, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 1312968, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba270000
mmap(0x7f91ba28c000, 565248, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1c000) = 0x7f91ba28c000
mmap(0x7f91ba316000, 606208, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa6000) = 0x7f91ba316000
mmap(0x7f91ba3aa000, 28672, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x139000) = 0x7f91ba3aa000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libatk-bridge-2.0.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libatk-bridge-2.0.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\300\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=214816, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 218072, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba23a000
mmap(0x7f91ba246000, 94208, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc000) = 0x7f91ba246000
mmap(0x7f91ba25d000, 61440, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x23000) = 0x7f91ba25d000
mmap(0x7f91ba26c000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x31000) = 0x7f91ba26c000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libXfixes.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libXfixes.so.3", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=30248, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91ba238000
mmap(NULL, 32824, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba22f000
mprotect(0x7f91ba231000, 20480, PROT_NONE) = 0
mmap(0x7f91ba231000, 12288, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91ba231000
mmap(0x7f91ba234000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5000) = 0x7f91ba234000
mmap(0x7f91ba236000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7f91ba236000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/librt.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\2207\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=39408, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 43520, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba224000
mmap(0x7f91ba227000, 16384, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f91ba227000
mmap(0x7f91ba22b000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x7f91ba22b000
mmap(0x7f91ba22d000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8000) = 0x7f91ba22d000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libxkbcommon.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libxkbcommon.so.0", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=276224, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 278544, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba1df000
mmap(0x7f91ba1e4000, 126976, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5000) = 0x7f91ba1e4000
mmap(0x7f91ba203000, 122880, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x24000) = 0x7f91ba203000
mmap(0x7f91ba221000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x41000) = 0x7f91ba221000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libwayland-client.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libwayland-client.so.0", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=68048, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 70440, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba1cd000
mmap(0x7f91ba1d3000, 24576, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7f91ba1d3000
mmap(0x7f91ba1d9000, 12288, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc000) = 0x7f91ba1d9000
mmap(0x7f91ba1dc000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe000) = 0x7f91ba1dc000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libwayland-cursor.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libwayland-cursor.so.0", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=30496, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 32976, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba1c4000
mmap(0x7f91ba1c5000, 8192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x7f91ba1c5000
mmap(0x7f91ba1c7000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f91ba1c7000
mmap(0x7f91ba1c8000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f91ba1c8000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libwayland-egl.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libwayland-egl.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=13856, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 16400, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba1bf000
mmap(0x7f91ba1c0000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x7f91ba1c0000
mmap(0x7f91ba1c1000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91ba1c1000
mmap(0x7f91ba1c2000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91ba1c2000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libXext.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libXext.so.6", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=80776, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91ba1bd000
mmap(NULL, 83768, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba1a8000
mmap(0x7f91ba1ac000, 45056, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x7f91ba1ac000
mmap(0x7f91ba1b7000, 16384, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xf000) = 0x7f91ba1b7000
mmap(0x7f91ba1bb000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x12000) = 0x7f91ba1bb000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libXcursor.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libXcursor.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=42600, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 45096, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba19c000
mmap(0x7f91ba19f000, 20480, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f91ba19f000
mmap(0x7f91ba1a4000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8000) = 0x7f91ba1a4000
mmap(0x7f91ba1a6000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9000) = 0x7f91ba1a6000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libXdamage.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libXdamage.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=13928, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 16440, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba197000
mmap(0x7f91ba198000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x7f91ba198000
mmap(0x7f91ba199000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91ba199000
mmap(0x7f91ba19a000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91ba19a000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libXcomposite.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libXcomposite.so.1", O_RDONLY|O_CLOEXEC) = 3
mmap(NULL, 16440, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba192000
mmap(0x7f91ba193000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x7f91ba193000
mmap(0x7f91ba194000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91ba194000
mmap(0x7f91ba195000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91ba195000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libXrandr.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libXrandr.so.2", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=46808, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 49320, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba185000
mmap(0x7f91ba187000, 28672, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91ba187000
mmap(0x7f91ba18e000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9000) = 0x7f91ba18e000
mmap(0x7f91ba190000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa000) = 0x7f91ba190000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libXinerama.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libXinerama.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=14048, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 16552, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba180000
mmap(0x7f91ba181000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x7f91ba181000
mmap(0x7f91ba182000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91ba182000
mmap(0x7f91ba183000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91ba183000
close(3)                                = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91ba17e000
openat(AT_FDCWD, "/usr/bin/libz.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libz.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=100096, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 102416, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba164000
mprotect(0x7f91ba167000, 86016, PROT_NONE) = 0
mmap(0x7f91ba167000, 57344, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f91ba167000
mmap(0x7f91ba175000, 24576, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x11000) = 0x7f91ba175000
mmap(0x7f91ba17c000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x17000) = 0x7f91ba17c000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libmount.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libmount.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=379496, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 382408, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba106000
mprotect(0x7f91ba112000, 323584, PROT_NONE) = 0
mmap(0x7f91ba112000, 245760, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc000) = 0x7f91ba112000
mmap(0x7f91ba14e000, 73728, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x48000) = 0x7f91ba14e000
mmap(0x7f91ba161000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5a000) = 0x7f91ba161000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libresolv.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libresolv.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20G\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=92496, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 104608, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba0ec000
mprotect(0x7f91ba0f0000, 73728, PROT_NONE) = 0
mmap(0x7f91ba0f0000, 57344, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x7f91ba0f0000
mmap(0x7f91ba0fe000, 12288, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x12000) = 0x7f91ba0fe000
mmap(0x7f91ba102000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x15000) = 0x7f91ba102000
mmap(0x7f91ba104000, 6304, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f91ba104000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libffi.so.7", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libffi.so.7", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@ \0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=42960, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 46376, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba0e0000
mmap(0x7f91ba0e2000, 24576, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91ba0e2000
mmap(0x7f91ba0e8000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8000) = 0x7f91ba0e8000
mmap(0x7f91ba0ea000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9000) = 0x7f91ba0ea000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libpcre.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libpcre.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=460544, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 463112, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba06e000
mmap(0x7f91ba070000, 327680, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91ba070000
mmap(0x7f91ba0c0000, 122880, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x52000) = 0x7f91ba0c0000
mmap(0x7f91ba0de000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6f000) = 0x7f91ba0de000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libgssapi_krb5.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libgssapi_krb5.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \300\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=344088, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 346976, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91ba019000
mprotect(0x7f91ba025000, 286720, PROT_NONE) = 0
mmap(0x7f91ba025000, 229376, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc000) = 0x7f91ba025000
mmap(0x7f91ba05d000, 53248, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x44000) = 0x7f91ba05d000
mmap(0x7f91ba06b000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x51000) = 0x7f91ba06b000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libxml2.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libxml2.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \340\2\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=1487712, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91ba017000
mmap(NULL, 1495304, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9ea9000
mmap(0x7f91b9ed7000, 954368, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2e000) = 0x7f91b9ed7000
mmap(0x7f91b9fc0000, 307200, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x117000) = 0x7f91b9fc0000
mmap(0x7f91ba00b000, 40960, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x161000) = 0x7f91ba00b000
mmap(0x7f91ba015000, 4360, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f91ba015000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libsqlite3.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libsqlite3.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0` \2\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=1297968, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 1302072, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9d6b000
mmap(0x7f91b9d8d000, 901120, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x22000) = 0x7f91b9d8d000
mmap(0x7f91b9e69000, 225280, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xfe000) = 0x7f91b9e69000
mmap(0x7f91b9ea0000, 36864, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x134000) = 0x7f91b9ea0000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libpsl.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libpsl.so.5", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=71272, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 73744, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9d58000
mmap(0x7f91b9d5a000, 8192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91b9d5a000
mmap(0x7f91b9d5c000, 53248, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x7f91b9d5c000
mmap(0x7f91b9d69000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x10000) = 0x7f91b9d69000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libbrotlidec.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libbrotlidec.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=50792, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 53264, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9d4a000
mmap(0x7f91b9d4b000, 32768, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x7f91b9d4b000
mmap(0x7f91b9d53000, 12288, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9000) = 0x7f91b9d53000
mmap(0x7f91b9d56000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xb000) = 0x7f91b9d56000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libgpgme.so.11", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libgpgme.so.11", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=326416, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 328968, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9cf9000
mmap(0x7f91b9d00000, 212992, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x7f91b9d00000
mmap(0x7f91b9d34000, 77824, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3b000) = 0x7f91b9d34000
mmap(0x7f91b9d47000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4d000) = 0x7f91b9d47000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libgpg-error.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libgpg-error.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@P\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=153560, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 156112, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9cd2000
mprotect(0x7f91b9cd7000, 131072, PROT_NONE) = 0
mmap(0x7f91b9cd7000, 86016, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5000) = 0x7f91b9cd7000
mmap(0x7f91b9cec000, 40960, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1a000) = 0x7f91b9cec000
mmap(0x7f91b9cf7000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x24000) = 0x7f91b9cf7000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libassuan.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libassuan.so.0", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=79864, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91b9cd0000
mmap(NULL, 82272, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9cbb000
mmap(0x7f91b9cbf000, 40960, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x7f91b9cbf000
mmap(0x7f91b9cc9000, 20480, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe000) = 0x7f91b9cc9000
mmap(0x7f91b9cce000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x12000) = 0x7f91b9cce000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libarchive.so.13", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libarchive.so.13", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\2000\1\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=792408, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 796848, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9bf8000
mprotect(0x7f91b9c0b000, 700416, PROT_NONE) = 0
mmap(0x7f91b9c0b000, 536576, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x13000) = 0x7f91b9c0b000
mmap(0x7f91b9c8e000, 159744, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x96000) = 0x7f91b9c8e000
mmap(0x7f91b9cb6000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xbd000) = 0x7f91b9cb6000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libcurl.so.4", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=623872, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 627320, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9b5e000
mprotect(0x7f91b9b6c000, 548864, PROT_NONE) = 0
mmap(0x7f91b9b6c000, 425984, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe000) = 0x7f91b9b6c000
mmap(0x7f91b9bd4000, 118784, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x76000) = 0x7f91b9bd4000
mmap(0x7f91b9bf2000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x93000) = 0x7f91b9bf2000
mmap(0x7f91b9bf7000, 632, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f91b9bf7000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libcrypto.so.1.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libcrypto.so.1.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0p\7\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=2986824, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 3006384, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9880000
mmap(0x7f91b98f6000, 1724416, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x76000) = 0x7f91b98f6000
mmap(0x7f91b9a9b000, 593920, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x21b000) = 0x7f91b9a9b000
mmap(0x7f91b9b2c000, 188416, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2ab000) = 0x7f91b9b2c000
mmap(0x7f91b9b5a000, 16304, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f91b9b5a000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libuuid.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libuuid.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=30616, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 32792, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9877000
mmap(0x7f91b9879000, 16384, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91b9879000
mmap(0x7f91b987d000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7f91b987d000
mmap(0x7f91b987e000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7f91b987e000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libyaml-0.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libyaml-0.so.2", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=132712, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 135184, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9855000
mmap(0x7f91b9857000, 106496, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91b9857000
mmap(0x7f91b9871000, 16384, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1c000) = 0x7f91b9871000
mmap(0x7f91b9875000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1f000) = 0x7f91b9875000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libstemmer.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libstemmer.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \20\3\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=628720, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91b9853000
mmap(NULL, 631040, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b97b8000
mprotect(0x7f91b97e9000, 180224, PROT_NONE) = 0
mmap(0x7f91b97e9000, 118784, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x31000) = 0x7f91b97e9000
mmap(0x7f91b9806000, 57344, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4e000) = 0x7f91b9806000
mmap(0x7f91b9815000, 253952, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5c000) = 0x7f91b9815000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libdl.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\20\"\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=22704, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 24720, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b97b1000
mmap(0x7f91b97b3000, 8192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91b97b3000
mmap(0x7f91b97b5000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x7f91b97b5000
mmap(0x7f91b97b6000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x7f91b97b6000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libthai.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libthai.so.0", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=40752, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 43152, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b97a6000
mmap(0x7f91b97a8000, 16384, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91b97a8000
mmap(0x7f91b97ac000, 12288, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7f91b97ac000
mmap(0x7f91b97af000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8000) = 0x7f91b97af000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libgraphite2.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libgraphite2.so.3", O_RDONLY|O_CLOEXEC) = 3
mmap(NULL, 147472, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9781000
mmap(0x7f91b9784000, 106496, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f91b9784000
mmap(0x7f91b979e000, 20480, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1d000) = 0x7f91b979e000
mmap(0x7f91b97a3000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x21000) = 0x7f91b97a3000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libpng16.so.16", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libpng16.so.16", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=218808, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 221200, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b974a000
mmap(0x7f91b9750000, 147456, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7f91b9750000
mmap(0x7f91b9774000, 45056, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2a000) = 0x7f91b9774000
mmap(0x7f91b977f000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x34000) = 0x7f91b977f000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libXrender.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libXrender.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=46968, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91b9748000
mmap(NULL, 49488, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b973b000
mmap(0x7f91b973d000, 28672, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91b973d000
mmap(0x7f91b9744000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9000) = 0x7f91b9744000
mmap(0x7f91b9746000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa000) = 0x7f91b9746000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libxcb.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libxcb.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=165648, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 168200, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9711000
mmap(0x7f91b971d000, 77824, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc000) = 0x7f91b971d000
mmap(0x7f91b9730000, 36864, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1f000) = 0x7f91b9730000
mmap(0x7f91b9739000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x27000) = 0x7f91b9739000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libxcb-render.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libxcb-render.so.0", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=59120, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 61480, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9701000
mprotect(0x7f91b9707000, 32768, PROT_NONE) = 0
mmap(0x7f91b9707000, 20480, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7f91b9707000
mmap(0x7f91b970c000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xb000) = 0x7f91b970c000
mmap(0x7f91b970f000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xd000) = 0x7f91b970f000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libxcb-shm.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libxcb-shm.so.0", O_RDONLY|O_CLOEXEC) = 3
mmap(NULL, 16424, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b96fc000
mmap(0x7f91b96fd000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x7f91b96fd000
mmap(0x7f91b96fe000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91b96fe000
mmap(0x7f91b96ff000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91b96ff000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libpixman-1.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libpixman-1.so.0", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=681768, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 684376, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9654000
mmap(0x7f91b965f000, 532480, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xb000) = 0x7f91b965f000
mmap(0x7f91b96e1000, 73728, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8d000) = 0x7f91b96e1000
mmap(0x7f91b96f3000, 36864, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9e000) = 0x7f91b96f3000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libexpat.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libexpat.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=186040, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 188432, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9625000
mprotect(0x7f91b9629000, 163840, PROT_NONE) = 0
mmap(0x7f91b9629000, 118784, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x7f91b9629000
mmap(0x7f91b9646000, 40960, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x21000) = 0x7f91b9646000
mmap(0x7f91b9651000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2b000) = 0x7f91b9651000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libbz2.so.1.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libbz2.so.1.0", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=74448, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91b9623000
mmap(NULL, 76840, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9610000
mmap(0x7f91b9612000, 53248, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91b9612000
mmap(0x7f91b961f000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xf000) = 0x7f91b961f000
mmap(0x7f91b9621000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x10000) = 0x7f91b9621000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libdbus-1.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libdbus-1.so.3", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=341912, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 344752, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b95bb000
mmap(0x7f91b95c9000, 192512, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe000) = 0x7f91b95c9000
mmap(0x7f91b95f8000, 86016, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3d000) = 0x7f91b95f8000
mmap(0x7f91b960d000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x51000) = 0x7f91b960d000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libatspi.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libatspi.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \0\1\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=219072, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 222272, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9584000
mmap(0x7f91b9594000, 86016, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x10000) = 0x7f91b9594000
mmap(0x7f91b95a9000, 53248, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x25000) = 0x7f91b95a9000
mmap(0x7f91b95b6000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x31000) = 0x7f91b95b6000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libblkid.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libblkid.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\220\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=326600, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 329512, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9533000
mprotect(0x7f91b953c000, 274432, PROT_NONE) = 0
mmap(0x7f91b953c000, 204800, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x9000) = 0x7f91b953c000
mmap(0x7f91b956e000, 65536, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3b000) = 0x7f91b956e000
mmap(0x7f91b957f000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4b000) = 0x7f91b957f000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libkrb5.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libkrb5.so.3", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 0\2\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=936256, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 939296, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b944d000
mmap(0x7f91b9470000, 430080, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x23000) = 0x7f91b9470000
mmap(0x7f91b94d9000, 299008, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8c000) = 0x7f91b94d9000
mmap(0x7f91b9522000, 69632, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xd4000) = 0x7f91b9522000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libk5crypto.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91b944b000
openat(AT_FDCWD, "/usr/lib/libk5crypto.so.3", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=194456, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 200560, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b941a000
mmap(0x7f91b941f000, 114688, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5000) = 0x7f91b941f000
mmap(0x7f91b943b000, 53248, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x21000) = 0x7f91b943b000
mmap(0x7f91b9448000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2d000) = 0x7f91b9448000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libcom_err.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libcom_err.so.2", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=18184, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 20648, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9414000
mmap(0x7f91b9416000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91b9416000
mmap(0x7f91b9417000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f91b9417000
mmap(0x7f91b9418000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f91b9418000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libkrb5support.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libkrb5support.so.0", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=55264, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 57992, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9405000
mmap(0x7f91b9408000, 28672, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f91b9408000
mmap(0x7f91b940f000, 12288, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa000) = 0x7f91b940f000
mmap(0x7f91b9412000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc000) = 0x7f91b9412000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libkeyutils.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libkeyutils.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=22200, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 24592, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b93fe000
mmap(0x7f91b9400000, 8192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91b9400000
mmap(0x7f91b9402000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x7f91b9402000
mmap(0x7f91b9403000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x7f91b9403000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libicuuc.so.68", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libicuuc.so.68", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 P\6\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=2012960, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 2023984, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b920f000
mmap(0x7f91b9274000, 966656, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x65000) = 0x7f91b9274000
mmap(0x7f91b9360000, 557056, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x151000) = 0x7f91b9360000
mmap(0x7f91b93e8000, 81920, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1d8000) = 0x7f91b93e8000
mmap(0x7f91b93fc000, 4656, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f91b93fc000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/liblzma.so.5", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/liblzma.so.5", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=157456, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 159760, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b91e7000
mprotect(0x7f91b91ea000, 143360, PROT_NONE) = 0
mmap(0x7f91b91ea000, 94208, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f91b91ea000
mmap(0x7f91b9201000, 45056, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1a000) = 0x7f91b9201000
mmap(0x7f91b920d000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x25000) = 0x7f91b920d000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libunistring.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libunistring.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \20\1\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=1574712, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91b91e5000
mmap(NULL, 1579272, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9063000
mmap(0x7f91b9074000, 217088, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x11000) = 0x7f91b9074000
mmap(0x7f91b90a9000, 1273856, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x46000) = 0x7f91b90a9000
mmap(0x7f91b91e0000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x17c000) = 0x7f91b91e0000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libidn2.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libidn2.so.0", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=128696, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 131096, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9042000
mmap(0x7f91b9044000, 16384, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91b9044000
mmap(0x7f91b9048000, 102400, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7f91b9048000
mmap(0x7f91b9061000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1e000) = 0x7f91b9061000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libbrotlicommon.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libbrotlicommon.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=136888, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 139280, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b901f000
mmap(0x7f91b9020000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x7f91b9020000
mmap(0x7f91b9021000, 126976, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91b9021000
mmap(0x7f91b9040000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x20000) = 0x7f91b9040000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libacl.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libacl.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=38704, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 41120, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b9014000
mmap(0x7f91b9016000, 20480, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91b9016000
mmap(0x7f91b901b000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x7f91b901b000
mmap(0x7f91b901d000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8000) = 0x7f91b901d000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libzstd.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libzstd.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=890560, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 892984, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b8f39000
mprotect(0x7f91b8f45000, 839680, PROT_NONE) = 0
mmap(0x7f91b8f45000, 761856, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc000) = 0x7f91b8f45000
mmap(0x7f91b8fff000, 73728, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc6000) = 0x7f91b8fff000
mmap(0x7f91b9012000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xd8000) = 0x7f91b9012000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/liblz4.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/liblz4.so.1", O_RDONLY|O_CLOEXEC) = 3
mmap(NULL, 139280, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b8f16000
mmap(0x7f91b8f19000, 110592, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f91b8f19000
mmap(0x7f91b8f34000, 12288, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1e000) = 0x7f91b8f34000
mmap(0x7f91b8f37000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x20000) = 0x7f91b8f37000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libnghttp2.so.14", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91b8f14000
openat(AT_FDCWD, "/usr/lib/libnghttp2.so.14", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=173848, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 176240, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b8ee8000
mprotect(0x7f91b8eed000, 143360, PROT_NONE) = 0
mmap(0x7f91b8eed000, 86016, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5000) = 0x7f91b8eed000
mmap(0x7f91b8f02000, 53248, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1a000) = 0x7f91b8f02000
mmap(0x7f91b8f10000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x27000) = 0x7f91b8f10000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libssh2.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libssh2.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 p\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=256144, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 258552, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b8ea8000
mmap(0x7f91b8eaf000, 167936, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x7f91b8eaf000
mmap(0x7f91b8ed8000, 53248, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x30000) = 0x7f91b8ed8000
mmap(0x7f91b8ee5000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3c000) = 0x7f91b8ee5000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libssl.so.1.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libssl.so.1.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \320\1\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=589504, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 592240, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b8e17000
mmap(0x7f91b8e34000, 315392, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1d000) = 0x7f91b8e34000
mmap(0x7f91b8e81000, 106496, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6a000) = 0x7f91b8e81000
mmap(0x7f91b8e9b000, 53248, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x83000) = 0x7f91b8e9b000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libdatrie.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libdatrie.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=34488, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 36880, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b8e0d000
mmap(0x7f91b8e0f000, 16384, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91b8e0f000
mmap(0x7f91b8e13000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7f91b8e13000
mmap(0x7f91b8e15000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x7f91b8e15000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libXau.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libXau.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\20\0\0\0\0\0\0"..., 832) = 832
mmap(NULL, 16424, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b8e08000
mmap(0x7f91b8e09000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x7f91b8e09000
mmap(0x7f91b8e0a000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91b8e0a000
mmap(0x7f91b8e0b000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91b8e0b000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libXdmcp.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libXdmcp.so.6", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=26216, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91b8e06000
mmap(NULL, 28688, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b8dfe000
mmap(0x7f91b8e00000, 8192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91b8e00000
mmap(0x7f91b8e02000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x7f91b8e02000
mmap(0x7f91b8e04000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5000) = 0x7f91b8e04000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libsystemd.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libsystemd.so.0", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@0\1\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=737960, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 742672, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b8d48000
mmap(0x7f91b8d5b000, 487424, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x13000) = 0x7f91b8d5b000
mmap(0x7f91b8dd2000, 155648, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8a000) = 0x7f91b8dd2000
mmap(0x7f91b8df8000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xaf000) = 0x7f91b8df8000
mmap(0x7f91b8dfd000, 1296, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f91b8dfd000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libicudata.so.68", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libicudata.so.68", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0\20\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=28574360, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 28577792, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b7207000
mmap(0x7f91b8d47000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1b3f000) = 0x7f91b8d47000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@`\t\0\0\0\0\0"..., 832) = 832
pread64(3, "\4\0\0\0\24\0\0\0\3\0\0\0GNU\0\t\4\347D\323S,\261]Q\30B+DZ\232"..., 36, 800) = 36
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=20947728, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 1951744, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b702a000
mprotect(0x7f91b70c0000, 1269760, PROT_NONE) = 0
mmap(0x7f91b70c0000, 966656, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x96000) = 0x7f91b70c0000
mmap(0x7f91b71ac000, 299008, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x182000) = 0x7f91b71ac000
mmap(0x7f91b71f6000, 57344, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1cb000) = 0x7f91b71f6000
mmap(0x7f91b7204000, 10240, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f91b7204000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=593928, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 103144, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b7010000
mmap(0x7f91b7013000, 69632, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f91b7013000
mmap(0x7f91b7024000, 16384, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14000) = 0x7f91b7024000
mmap(0x7f91b7028000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x17000) = 0x7f91b7028000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libattr.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libattr.so.1", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=22216, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91b700e000
mmap(NULL, 24600, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b7007000
mmap(0x7f91b7009000, 8192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f91b7009000
mmap(0x7f91b700b000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x7f91b700b000
mmap(0x7f91b700c000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x7f91b700c000
close(3)                                = 0
openat(AT_FDCWD, "/usr/bin/libgcrypt.so.20", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libgcrypt.so.20", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\360\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=1246864, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 1250424, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b6ed5000
mprotect(0x7f91b6ee4000, 1150976, PROT_NONE) = 0
mmap(0x7f91b6ee4000, 880640, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xf000) = 0x7f91b6ee4000
mmap(0x7f91b6fbb000, 266240, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe6000) = 0x7f91b6fbb000
mmap(0x7f91b6ffd000, 36864, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x127000) = 0x7f91b6ffd000
mmap(0x7f91b7006000, 1144, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f91b7006000
close(3)                                = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91b6ed3000
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91b6ed1000
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91b6ecf000
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91b6ecd000
mmap(NULL, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91b6eca000
arch_prctl(ARCH_SET_FS, 0x7f91b6eca9c0) = 0
mprotect(0x7f91bacd3000, 12288, PROT_READ) = 0
mprotect(0x7f91b9cf7000, 4096, PROT_READ) = 0
mprotect(0x7f91b6ffd000, 12288, PROT_READ) = 0
mprotect(0x7f91b700c000, 4096, PROT_READ) = 0
mprotect(0x7f91b7028000, 4096, PROT_READ) = 0
mprotect(0x7f91baadb000, 4096, PROT_READ) = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f91b6ec8000
mprotect(0x7f91b71f6000, 53248, PROT_READ) = 0
mprotect(0x7f91b8d47000, 4096, PROT_READ) = 0
mprotect(0x7f91ba8f5000, 4096, PROT_READ) = 0
mprotect(0x7f91ba22d000, 4096, PROT_READ) = 0
mprotect(0x7f91b920d000, 4096, PROT_READ) = 0
mprotect(0x7f91b9012000, 4096, PROT_READ) = 0
mprotect(0x7f91b8f37000, 4096, PROT_READ) = 0
mprotect(0x7f91b8df8000, 16384, PROT_READ) = 0
mprotect(0x7f91b8e04000, 4096, PROT_READ) = 0
mprotect(0x7f91b8e0b000, 4096, PROT_READ) = 0
mprotect(0x7f91b8e15000, 4096, PROT_READ) = 0
mprotect(0x7f91b97b6000, 4096, PROT_READ) = 0
mprotect(0x7f91b9b2c000, 180224, PROT_READ) = 0
mprotect(0x7f91b8e9b000, 36864, PROT_READ) = 0
mprotect(0x7f91ba17c000, 4096, PROT_READ) = 0
mprotect(0x7f91b8ee5000, 8192, PROT_READ) = 0
mprotect(0x7f91b8f10000, 12288, PROT_READ) = 0
mprotect(0x7f91b901d000, 4096, PROT_READ) = 0
mprotect(0x7f91b9040000, 4096, PROT_READ) = 0
mprotect(0x7f91b91e0000, 16384, PROT_READ) = 0
mprotect(0x7f91b9061000, 4096, PROT_READ) = 0
mprotect(0x7f91b93e8000, 77824, PROT_READ) = 0
mprotect(0x7f91b9403000, 4096, PROT_READ) = 0
mprotect(0x7f91ba102000, 4096, PROT_READ) = 0
mprotect(0x7f91b9412000, 4096, PROT_READ) = 0
mprotect(0x7f91b9418000, 4096, PROT_READ) = 0
mprotect(0x7f91b9448000, 8192, PROT_READ) = 0
mprotect(0x7f91b9522000, 61440, PROT_READ) = 0
mprotect(0x7f91b957f000, 16384, PROT_READ) = 0
mprotect(0x7f91ba0de000, 4096, PROT_READ) = 0
mprotect(0x7f91baeb4000, 4096, PROT_READ) = 0
mprotect(0x7f91ba0ea000, 4096, PROT_READ) = 0
mprotect(0x7f91baf0b000, 12288, PROT_READ) = 0
mprotect(0x7f91b9739000, 4096, PROT_READ) = 0
mprotect(0x7f91ba3aa000, 12288, PROT_READ) = 0
mprotect(0x7f91b960d000, 8192, PROT_READ) = 0
mprotect(0x7f91b95b6000, 16384, PROT_READ) = 0
mprotect(0x7f91b9621000, 4096, PROT_READ) = 0
mprotect(0x7f91b9651000, 8192, PROT_READ) = 0
mprotect(0x7f91b96f3000, 32768, PROT_READ) = 0
mprotect(0x7f91b96ff000, 4096, PROT_READ) = 0
mprotect(0x7f91b970f000, 4096, PROT_READ) = 0
mprotect(0x7f91b9746000, 4096, PROT_READ) = 0
mprotect(0x7f91b977f000, 4096, PROT_READ) = 0
mprotect(0x7f91b97a3000, 8192, PROT_READ) = 0
mprotect(0x7f91b97af000, 4096, PROT_READ) = 0
mprotect(0x7f91b9815000, 249856, PROT_READ) = 0
mprotect(0x7f91b9875000, 4096, PROT_READ) = 0
mprotect(0x7f91b987e000, 4096, PROT_READ) = 0
mprotect(0x7f91ba06b000, 8192, PROT_READ) = 0
mprotect(0x7f91b9d69000, 4096, PROT_READ) = 0
mprotect(0x7f91b9bf2000, 12288, PROT_READ) = 0
mprotect(0x7f91b9cb6000, 16384, PROT_READ) = 0
mprotect(0x7f91b9cce000, 4096, PROT_READ) = 0
mprotect(0x7f91b9d47000, 4096, PROT_READ) = 0
mprotect(0x7f91b9d56000, 4096, PROT_READ) = 0
mprotect(0x7f91b9ea0000, 24576, PROT_READ) = 0
mprotect(0x7f91ba00b000, 36864, PROT_READ) = 0
mprotect(0x7f91ba161000, 8192, PROT_READ) = 0
mprotect(0x7f91ba1bb000, 4096, PROT_READ) = 0
mprotect(0x7f91ba183000, 4096, PROT_READ) = 0
mprotect(0x7f91ba190000, 4096, PROT_READ) = 0
mprotect(0x7f91ba195000, 4096, PROT_READ) = 0
mprotect(0x7f91ba236000, 4096, PROT_READ) = 0
mprotect(0x7f91ba19a000, 4096, PROT_READ) = 0
mprotect(0x7f91ba1a6000, 4096, PROT_READ) = 0
mprotect(0x7f91ba1c2000, 4096, PROT_READ) = 0
mprotect(0x7f91ba1dc000, 8192, PROT_READ) = 0
mprotect(0x7f91ba1c8000, 4096, PROT_READ) = 0
mprotect(0x7f91ba221000, 8192, PROT_READ) = 0
mprotect(0x7f91ba51a000, 12288, PROT_READ) = 0
mprotect(0x7f91ba26c000, 8192, PROT_READ) = 0
mprotect(0x7f91ba3c2000, 4096, PROT_READ) = 0
mprotect(0x7f91ba4e6000, 32768, PROT_READ) = 0
mprotect(0x7f91ba873000, 4096, PROT_READ) = 0
mprotect(0x7f91ba617000, 28672, PROT_READ) = 0
mprotect(0x7f91ba667000, 8192, PROT_READ) = 0
mprotect(0x7f91ba79b000, 16384, PROT_READ) = 0
mprotect(0x7f91ba527000, 8192, PROT_READ) = 0
mprotect(0x7f91ba549000, 4096, PROT_READ) = 0
mprotect(0x7f91ba8fe000, 4096, PROT_READ) = 0
mprotect(0x7f91bb0c3000, 28672, PROT_READ) = 0
mprotect(0x7f91ba8c5000, 12288, PROT_READ) = 0
mprotect(0x7f91ba680000, 4096, PROT_READ) = 0
mprotect(0x7f91ba8d8000, 4096, PROT_READ) = 0
mprotect(0x7f91bb0f0000, 4096, PROT_READ) = 0
mprotect(0x7f91bad7c000, 20480, PROT_READ) = 0
mprotect(0x7f91ba966000, 12288, PROT_READ) = 0
mprotect(0x7f91ba994000, 4096, PROT_READ) = 0
mprotect(0x7f91bab13000, 4096, PROT_READ) = 0
mprotect(0x7f91bb1e2000, 32768, PROT_READ) = 0
mprotect(0x7f91bb954000, 65536, PROT_READ) = 0
mprotect(0x7f91bba2f000, 20480, PROT_READ) = 0
mprotect(0x7f91bb983000, 4096, PROT_READ) = 0
mprotect(0x5570ed0e6000, 8192, PROT_READ) = 0
mprotect(0x7f91bba97000, 8192, PROT_READ) = 0
munmap(0x7f91bba37000, 197984)          = 0
set_tid_address(0x7f91b6ecac90)         = 1989
set_robust_list(0x7f91b6ecaca0, 24)     = 0
rt_sigaction(SIGRTMIN, {sa_handler=0x7f91ba8e1b70, sa_mask=[], sa_flags=SA_RESTORER|SA_SIGINFO, sa_restorer=0x7f91ba8ed960}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {sa_handler=0x7f91ba8e1c10, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART|SA_SIGINFO, sa_restorer=0x7f91ba8ed960}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
prlimit64(0, RLIMIT_STACK, NULL, {rlim_cur=8192*1024, rlim_max=RLIM64_INFINITY}) = 0
brk(NULL)                               = 0x5570eec78000
brk(0x5570eec99000)                     = 0x5570eec99000
futex(0x7f91baeb6068, FUTEX_WAKE_PRIVATE, 2147483647) = 0
brk(0x5570eecba000)                     = 0x5570eecba000
openat(AT_FDCWD, "/usr/lib/gio/modules", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 3
newfstatat(3, "", {st_mode=S_IFDIR|0755, st_size=4096, ...}, AT_EMPTY_PATH) = 0
newfstatat(AT_FDCWD, "/usr/lib/gio/modules/giomodule.cache", {st_mode=S_IFREG|0644, st_size=304, ...}, 0) = 0
openat(AT_FDCWD, "/usr/lib/gio/modules/giomodule.cache", O_RDONLY) = 4
newfstatat(4, "", {st_mode=S_IFREG|0644, st_size=304, ...}, AT_EMPTY_PATH) = 0
read(4, "libdconfsettings.so: gsettings-b"..., 304) = 304
close(4)                                = 0
getdents64(3, 0x5570eeca2a10 /* 10 entries */, 32768) = 384
newfstatat(AT_FDCWD, "/usr/lib/gio/modules/libgiolibproxy.so", {st_mode=S_IFREG|0755, st_size=18024, ...}, 0) = 0
newfstatat(AT_FDCWD, "/usr/lib/gio/modules/libdconfsettings.so", {st_mode=S_IFREG|0755, st_size=50872, ...}, 0) = 0
newfstatat(AT_FDCWD, "/usr/lib/gio/modules/libgvfsdbus.so", {st_mode=S_IFREG|0755, st_size=198608, ...}, 0) = 0
newfstatat(AT_FDCWD, "/usr/lib/gio/modules/libgiognutls.so", {st_mode=S_IFREG|0755, st_size=116464, ...}, 0) = 0
newfstatat(AT_FDCWD, "/usr/lib/gio/modules/libgioremote-volume-monitor.so", {st_mode=S_IFREG|0755, st_size=104120, ...}, 0) = 0
newfstatat(AT_FDCWD, "/usr/lib/gio/modules/libgiognomeproxy.so", {st_mode=S_IFREG|0755, st_size=22120, ...}, 0) = 0
newfstatat(AT_FDCWD, "/usr/lib/gio/modules/libgioopenssl.so", {st_mode=S_IFREG|0755, st_size=116464, ...}, 0) = 0
getdents64(3, 0x5570eeca2a10 /* 0 entries */, 32768) = 0
close(3)                                = 0
access("/.flatpak-info", F_OK)          = -1 ENOENT (No such file or directory)
futex(0x7f91b97b7048, FUTEX_WAKE_PRIVATE, 2147483647) = 0
openat(AT_FDCWD, "/usr/lib/gio/modules/libgvfsdbus.so", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \240\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=198608, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 201464, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b6e96000
mmap(0x7f91b6ea0000, 110592, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa000) = 0x7f91b6ea0000
mmap(0x7f91b6ebb000, 40960, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x25000) = 0x7f91b6ebb000
mmap(0x7f91b6ec5000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2e000) = 0x7f91b6ec5000
close(3)                                = 0
openat(AT_FDCWD, "/usr/lib/gvfs/glibc-hwcaps/x86-64-v3/libgvfscommon.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/usr/lib/gvfs/glibc-hwcaps/x86-64-v3", 0x7ffdf555f8d0, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/gvfs/glibc-hwcaps/x86-64-v2/libgvfscommon.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/usr/lib/gvfs/glibc-hwcaps/x86-64-v2", 0x7ffdf555f8d0, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/gvfs/tls/x86_64/x86_64/libgvfscommon.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/usr/lib/gvfs/tls/x86_64/x86_64", 0x7ffdf555f8d0, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/gvfs/tls/x86_64/libgvfscommon.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/usr/lib/gvfs/tls/x86_64", 0x7ffdf555f8d0, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/gvfs/tls/libgvfscommon.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/usr/lib/gvfs/tls", 0x7ffdf555f8d0, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/gvfs/x86_64/x86_64/libgvfscommon.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/usr/lib/gvfs/x86_64/x86_64", 0x7ffdf555f8d0, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/gvfs/x86_64/libgvfscommon.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "/usr/lib/gvfs/x86_64", 0x7ffdf555f8d0, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/gvfs/libgvfscommon.so", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 0\1\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=263864, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 266936, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f91b6e54000
mprotect(0x7f91b6e67000, 163840, PROT_NONE) = 0
mmap(0x7f91b6e67000, 106496, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x13000) = 0x7f91b6e67000
mmap(0x7f91b6e81000, 53248, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2d000) = 0x7f91b6e81000
mmap(0x7f91b6e8f000, 28672, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3a000) = 0x7f91b6e8f000
close(3)                                = 0
mprotect(0x7f91b6e8f000, 24576, PROT_READ) = 0
mprotect(0x7f91b6ec5000, 8192, PROT_READ) = 0
gettid()                                = 1989
sched_getattr(1989, {size=56, sched_policy=SCHED_OTHER, sched_flags=0, sched_nice=0, sched_priority=0, sched_runtime=0, sched_deadline=0, sched_period=0, sched_util_min=0, sched_util_max=1024}, 56, 0) = 0
sched_setattr(1989, {size=56, sched_policy=SCHED_OTHER, sched_flags=0, sched_nice=0, sched_priority=0, sched_runtime=0, sched_deadline=0, sched_period=0, sched_util_min=0, sched_util_max=1024}, 0) = 0
rt_sigprocmask(SIG_SETMASK, ~[RTMIN RT_1], [], 8) = 0
eventfd2(0, EFD_CLOEXEC|EFD_NONBLOCK)   = 3
write(3, "\1\0\0\0\0\0\0\0", 8)         = 8
futex(0x7f91baeb6264, FUTEX_WAKE_PRIVATE, 2147483647) = 0
getpid()                                = 1989
gettid()                                = 1989
mmap(NULL, 8392704, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f91b6653000
mprotect(0x7f91b6654000, 8388608, PROT_READ|PROT_WRITE) = 0
rt_sigprocmask(SIG_BLOCK, ~[], ~[KILL STOP RTMIN RT_1], 8) = 0
clone(child_stack=0x7f91b6e52c70, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tid=[1990], tls=0x7f91b6e53640, child_tidptr=0x7f91b6e53910) = 1990
rt_sigprocmask(SIG_SETMASK, ~[KILL STOP RTMIN RT_1], NULL, 8) = 0
rt_sigprocmask(SIG_SETMASK, [], NULL, 8) = 0
futex(0x5570eecaded0, FUTEX_WAKE_PRIVATE, 1) = 1
rt_sigaction(SIGPIPE, {sa_handler=SIG_IGN, sa_mask=[PIPE], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f91bab51f80}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0
eventfd2(0, EFD_CLOEXEC|EFD_NONBLOCK)   = 4
write(4, "\1\0\0\0\0\0\0\0", 8)         = 8
brk(0x5570eecdb000)                     = 0x5570eecdb000
socket(AF_UNIX, SOCK_STREAM|SOCK_CLOEXEC, 0) = 5
fcntl(5, F_GETFL)                       = 0x2 (flags O_RDWR)
fcntl(5, F_SETFL, O_RDWR|O_NONBLOCK)    = 0
connect(5, {sa_family=AF_UNIX, sun_path="/run/user/1000/bus"}, 110) = 0
getpid()                                = 1989
geteuid()                               = 1000
getegid()                               = 1001
getpid()                                = 1989
geteuid()                               = 1000
getegid()                               = 1001
sendmsg(5, {msg_name=NULL, msg_namelen=0, msg_iov=[{iov_base="\0", iov_len=1}], msg_iovlen=1, msg_control=[{cmsg_len=28, cmsg_level=SOL_SOCKET, cmsg_type=SCM_CREDENTIALS, cmsg_data={pid=1989, uid=1000, gid=1001}}], msg_controllen=32, msg_flags=0}, MSG_NOSIGNAL) = 1
sendto(5, "AUTH\r\n", 6, MSG_NOSIGNAL, NULL, 0) = 6
recvfrom(5, "REJECTED EXTERNAL\r\n", 4096, 0, NULL, NULL) = 19
sendto(5, "AUTH EXTERNAL 31303030\r\n", 24, MSG_NOSIGNAL, NULL, 0) = 24
recvfrom(5, "OK c1c6c7c53e0fbd14e2ae77f86044f"..., 4096, 0, NULL, NULL) = 37
sendto(5, "NEGOTIATE_UNIX_FD\r\n", 19, MSG_NOSIGNAL, NULL, 0) = 19
recvfrom(5, "AGREE_UNIX_FD\r\n", 4096, 0, NULL, NULL) = 15
sendto(5, "BEGIN\r\n", 7, MSG_NOSIGNAL, NULL, 0) = 7
eventfd2(0, EFD_CLOEXEC|EFD_NONBLOCK)   = 6
write(6, "\1\0\0\0\0\0\0\0", 8)         = 8
mmap(NULL, 8392704, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f91b5e52000
mprotect(0x7f91b5e53000, 8388608, PROT_READ|PROT_WRITE) = 0
rt_sigprocmask(SIG_BLOCK, ~[], [], 8)   = 0
clone(child_stack=0x7f91b6651c70, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tid=[1991], tls=0x7f91b6652640, child_tidptr=0x7f91b6652910) = 1991
futex(0x5570eecbf770, FUTEX_WAKE_PRIVATE, 1) = 1
eventfd2(0, EFD_CLOEXEC|EFD_NONBLOCK)   = 7
write(7, "\1\0\0\0\0\0\0\0", 8)         = 8
futex(0x5570eecbf380, FUTEX_WAKE_PRIVATE, 1) = 1
futex(0x5570eecb5038, FUTEX_WAKE_PRIVATE, 1) = 1
poll([{fd=7, events=POLLIN}], 1, 25000) = 1 ([{fd=7, revents=POLLIN}])
read(7, "\1\0\0\0\0\0\0\0", 16)         = 8
futex(0x5570eecbfc20, FUTEX_WAKE_PRIVATE, 2147483647) = 0
close(7)                                = 0
rt_sigaction(SIGPIPE, {sa_handler=SIG_IGN, sa_mask=[PIPE], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f91bab51f80}, {sa_handler=SIG_IGN, sa_mask=[PIPE], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f91bab51f80}, 8) = 0
futex(0x5570eecc5fd0, FUTEX_WAKE_PRIVATE, 1) = 1
poll([{fd=7, events=POLLIN}], 1, 0)     = 1 ([{fd=7, revents=POLLIN}])
futex(0x5570eecc5fe0, FUTEX_WAKE_PRIVATE, 2147483647) = 0
close(7)                                = 0
futex(0x5570eecc6750, FUTEX_WAKE_PRIVATE, 2147483647) = 0
close(7)                                = 0
openat(AT_FDCWD, "/usr/lib/gvfs/modules", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/charset.alias", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/gconv/gconv-modules.cache", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/gconv/gconv-modules", O_RDONLY|O_CLOEXEC) = 7
newfstatat(7, "", {st_mode=S_IFREG|0644, st_size=56353, ...}, AT_EMPTY_PATH) = 0
read(7, "# GNU libc iconv configuration.\n"..., 4096) = 4096
read(7, "B1002//\tJUS_I.B1.002//\nmodule\tJU"..., 4096) = 4096
read(7, "\tISO-IR-110//\t\tISO-8859-4//\nalia"..., 4096) = 4096
read(7, "\t\t\tISO-8859-14//\nalias\tISO_8859-"..., 4096) = 4096
read(7, "DIC-ES//\nalias\tEBCDICES//\t\tEBCDI"..., 4096) = 4096
read(7, "CDIC-CP-ES//\t\tIBM284//\nalias\tCSI"..., 4096) = 4096
read(7, "\t\tIBM863//\nalias\tOSF1002035F//\t\t"..., 4096) = 4096
read(7, "937//\t\tIBM937//\nmodule\tIBM937//\t"..., 4096) = 4096
brk(0x5570eecfc000)                     = 0x5570eecfc000
read(7, "UJIS//\t\t\tEUC-JP//\nmodule\tEUC-JP/"..., 4096) = 4096
read(7, "lias\tISO2022CN//\t\tISO-2022-CN//\n"..., 4096) = 4096
read(7, "O_5427-EXT//\nalias\tISO_5427EXT//"..., 4096) = 4096
read(7, "ost\nmodule\tMAC-SAMI//\t\tINTERNAL\t"..., 4096) = 4096
read(7, "112//\t\tINTERNAL\t\tIBM1112\t\t1\nmodu"..., 4096) = 4096
read(7, "s\tCP9448//\t\tIBM9448//\nalias\tCSIB"..., 4096) = 3105
read(7, "", 4096)                       = 0
close(7)                                = 0
futex(0x7f91bacd84dc, FUTEX_WAKE_PRIVATE, 2147483647) = 0
statx(AT_FDCWD, "/etc/pacman.conf", AT_STATX_SYNC_AS_STAT|AT_SYMLINK_NOFOLLOW|AT_NO_AUTOMOUNT, STATX_ALL, {stx_mask=STATX_ALL, stx_attributes=0, stx_mode=S_IFREG|0644, stx_size=3293, ...}) = 0
openat(AT_FDCWD, "/etc/pacman.conf", O_RDONLY) = 7
statx(7, "", AT_STATX_SYNC_AS_STAT|AT_EMPTY_PATH, STATX_TYPE, {stx_mask=STATX_ALL, stx_attributes=0, stx_mode=S_IFREG|0644, stx_size=3293, ...}) = 0
read(7, "#\n# /etc/pacman.conf\n#\n# See the"..., 4096) = 3293
uname({sysname="Linux", nodename="bourne-2dent2ty", ...}) = 0
statx(AT_FDCWD, "/etc/pacman.d/mirrorlist", AT_STATX_SYNC_AS_STAT|AT_SYMLINK_NOFOLLOW|AT_NO_AUTOMOUNT, STATX_ALL, {stx_mask=STATX_ALL, stx_attributes=0, stx_mode=S_IFREG|0644, stx_size=899, ...}) = 0
openat(AT_FDCWD, "/etc/pacman.d/mirrorlist", O_RDONLY) = 8
statx(8, "", AT_STATX_SYNC_AS_STAT|AT_EMPTY_PATH, STATX_TYPE, {stx_mask=STATX_ALL, stx_attributes=0, stx_mode=S_IFREG|0644, stx_size=899, ...}) = 0
read(8, "##\n## Manjaro Linux default mirr"..., 4096) = 899
read(8, "", 4096)                       = 0
close(8)                                = 0
close(8)                                = 0
close(8)                                = 0
close(8)                                = 0
close(7)                                = 0
newfstatat(AT_FDCWD, "libpamac-snap.so", 0x7ffdf5560c80, 0) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "libpamac-snap.so.so", 0x7ffdf5560c80, 0) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "libpamac-snap.so.la", 0x7ffdf5560c80, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/bin/libpamac-snap.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 7
newfstatat(7, "", {st_mode=S_IFREG|0644, st_size=197984, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 197984, PROT_READ, MAP_PRIVATE, 7, 0) = 0x7f91bba37000
close(7)                                = 0
openat(AT_FDCWD, "/usr/lib/libpamac-snap.so", O_RDONLY|O_CLOEXEC) = 7
read(7, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 @\0\0\0\0\0\0"..., 832) = 832
newfstatat(7, "", {st_mode=S_IFREG|0755, st_size=371952, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 69976, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 7, 0) = 0x7f91b5e40000
mprotect(0x7f91b5e44000, 49152, PROT_NONE) = 0
mmap(0x7f91b5e44000, 32768, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x4000) = 0x7f91b5e44000
mmap(0x7f91b5e4c000, 12288, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0xc000) = 0x7f91b5e4c000
mmap(0x7f91b5e50000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0xf000) = 0x7f91b5e50000
close(7)                                = 0
openat(AT_FDCWD, "/usr/bin/libsnapd-glib.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libsnapd-glib.so.1", O_RDONLY|O_CLOEXEC) = 7
read(7, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \360\0\0\0\0\0\0"..., 832) = 832
newfstatat(7, "", {st_mode=S_IFREG|0755, st_size=405920, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 329192, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 7, 0) = 0x7f91b5def000
mprotect(0x7f91b5dfe000, 258048, PROT_NONE) = 0
mmap(0x7f91b5dfe000, 172032, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0xf000) = 0x7f91b5dfe000
mmap(0x7f91b5e28000, 81920, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x39000) = 0x7f91b5e28000
mmap(0x7f91b5e3d000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x4d000) = 0x7f91b5e3d000
close(7)                                = 0
mprotect(0x7f91b5e3d000, 8192, PROT_READ) = 0
mprotect(0x7f91b5e50000, 4096, PROT_READ) = 0
newfstatat(AT_FDCWD, "libpamac-flatpak.so", 0x7ffdf5560c80, 0) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "libpamac-flatpak.so.so", 0x7ffdf5560c80, 0) = -1 ENOENT (No such file or directory)
newfstatat(AT_FDCWD, "libpamac-flatpak.so.la", 0x7ffdf5560c80, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/bin/libpamac-flatpak.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
close(7)                                = 0
openat(AT_FDCWD, "/usr/lib/libpamac-flatpak.so", O_RDONLY|O_CLOEXEC) = 7
read(7, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 P\0\0\0\0\0\0"..., 832) = 832
newfstatat(7, "", {st_mode=S_IFREG|0755, st_size=79544, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 82328, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 7, 0) = 0x7f91b5dda000
mprotect(0x7f91b5ddf000, 57344, PROT_NONE) = 0
mmap(0x7f91b5ddf000, 36864, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x5000) = 0x7f91b5ddf000
mmap(0x7f91b5de8000, 16384, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0xe000) = 0x7f91b5de8000
mmap(0x7f91b5ded000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x12000) = 0x7f91b5ded000
close(7)                                = 0
openat(AT_FDCWD, "/usr/bin/libflatpak.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libflatpak.so.0", O_RDONLY|O_CLOEXEC) = 7
read(7, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \300\1\0\0\0\0\0"..., 832) = 832
newfstatat(7, "", {st_mode=S_IFREG|0755, st_size=933664, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 937912, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 7, 0) = 0x7f91b5cf5000
mmap(0x7f91b5d11000, 602112, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x1c000) = 0x7f91b5d11000
mmap(0x7f91b5da4000, 184320, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0xaf000) = 0x7f91b5da4000
mmap(0x7f91b5dd1000, 36864, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0xdb000) = 0x7f91b5dd1000
close(7)                                = 0
openat(AT_FDCWD, "/usr/bin/libdconf.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libdconf.so.1", O_RDONLY|O_CLOEXEC) = 7
newfstatat(7, "", {st_mode=S_IFREG|0755, st_size=63160, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 65776, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 7, 0) = 0x7f91b5ce4000
mprotect(0x7f91b5ce8000, 45056, PROT_NONE) = 0
mmap(0x7f91b5ce8000, 28672, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x4000) = 0x7f91b5ce8000
mmap(0x7f91b5cef000, 12288, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0xb000) = 0x7f91b5cef000
mmap(0x7f91b5cf3000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0xe000) = 0x7f91b5cf3000
close(7)                                = 0
openat(AT_FDCWD, "/usr/bin/libseccomp.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libseccomp.so.2", O_RDONLY|O_CLOEXEC) = 7
read(7, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0  \0\0\0\0\0\0"..., 832) = 832
newfstatat(7, "", {st_mode=S_IFREG|0755, st_size=136968, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 139392, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 7, 0) = 0x7f91b5cc1000
mmap(0x7f91b5cc3000, 65536, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x2000) = 0x7f91b5cc3000
mmap(0x7f91b5cd3000, 61440, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x12000) = 0x7f91b5cd3000
mmap(0x7f91b5ce2000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x20000) = 0x7f91b5ce2000
close(7)                                = 0
openat(AT_FDCWD, "/usr/bin/libostree-1.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libostree-1.so.1", O_RDONLY|O_CLOEXEC) = 7
read(7, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \220\1\0\0\0\0\0"..., 832) = 832
newfstatat(7, "", {st_mode=S_IFREG|0755, st_size=800800, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 804256, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 7, 0) = 0x7f91b5bfc000
mprotect(0x7f91b5c15000, 688128, PROT_NONE) = 0
mmap(0x7f91b5c15000, 520192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x19000) = 0x7f91b5c15000
mmap(0x7f91b5c94000, 163840, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x98000) = 0x7f91b5c94000
mmap(0x7f91b5cbd000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0xc0000) = 0x7f91b5cbd000
close(7)                                = 0
openat(AT_FDCWD, "/usr/bin/libavahi-common.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libavahi-common.so.3", O_RDONLY|O_CLOEXEC) = 7
read(7, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 0\0\0\0\0\0\0"..., 832) = 832
newfstatat(7, "", {st_mode=S_IFREG|0755, st_size=51248, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 53840, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 7, 0) = 0x7f91b5bee000
mmap(0x7f91b5bf1000, 24576, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x3000) = 0x7f91b5bf1000
mmap(0x7f91b5bf7000, 12288, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x9000) = 0x7f91b5bf7000
mmap(0x7f91b5bfa000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0xb000) = 0x7f91b5bfa000
close(7)                                = 0
openat(AT_FDCWD, "/usr/bin/libavahi-client.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libavahi-client.so.3", O_RDONLY|O_CLOEXEC) = 7
newfstatat(7, "", {st_mode=S_IFREG|0755, st_size=75712, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 78104, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 7, 0) = 0x7f91b5bda000
mprotect(0x7f91b5bde000, 57344, PROT_NONE) = 0
mmap(0x7f91b5bde000, 36864, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x4000) = 0x7f91b5bde000
mmap(0x7f91b5be7000, 16384, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0xd000) = 0x7f91b5be7000
mmap(0x7f91b5bec000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x11000) = 0x7f91b5bec000
close(7)                                = 0
openat(AT_FDCWD, "/usr/bin/libavahi-glib.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/lib/libavahi-glib.so.1", O_RDONLY|O_CLOEXEC) = 7
read(7, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \20\0\0\0\0\0\0"..., 832) = 832
newfstatat(7, "", {st_mode=S_IFREG|0755, st_size=14000, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 16552, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 7, 0) = 0x7f91b5bd5000
mmap(0x7f91b5bd6000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x1000) = 0x7f91b5bd6000
mmap(0x7f91b5bd7000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x2000) = 0x7f91b5bd7000
mmap(0x7f91b5bd8000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 7, 0x2000) = 0x7f91b5bd8000
close(7)                                = 0
mprotect(0x7f91b5bfa000, 4096, PROT_READ) = 0
mprotect(0x7f91b5bd8000, 4096, PROT_READ) = 0
mprotect(0x7f91b5bec000, 4096, PROT_READ) = 0
mprotect(0x7f91b5cbd000, 12288, PROT_READ) = 0
mprotect(0x7f91b5ce2000, 4096, PROT_READ) = 0
mprotect(0x7f91b5cf3000, 4096, PROT_READ) = 0
mprotect(0x7f91b5dd1000, 28672, PROT_READ) = 0
mprotect(0x7f91b5ded000, 4096, PROT_READ) = 0
close(8)                                = 0
close(8)                                = 0
close(8)                                = 0
close(8)                                = 0
close(7)                                = 0
statx(AT_FDCWD, "/etc/pamac.conf", AT_STATX_SYNC_AS_STAT|AT_SYMLINK_NOFOLLOW|AT_NO_AUTOMOUNT, STATX_ALL, {stx_mask=STATX_ALL, stx_attributes=0, stx_mode=S_IFREG|0644, stx_size=1176, ...}) = 0
openat(AT_FDCWD, "/etc/pamac.conf", O_RDONLY) = 7
statx(7, "", AT_STATX_SYNC_AS_STAT|AT_EMPTY_PATH, STATX_TYPE, {stx_mask=STATX_ALL, stx_attributes=0, stx_mode=S_IFREG|0644, stx_size=1176, ...}) = 0
read(7, "### Pamac configuration file\n\n##"..., 4096) = 1176
close(7)                                = 0
brk(0x5570eed1d000)                     = 0x5570eed1d000
newfstatat(AT_FDCWD, "/etc/resolv.conf", {st_mode=S_IFREG|0644, st_size=253, ...}, 0) = 0
statx(AT_FDCWD, "/var/lib/flatpak", AT_STATX_SYNC_AS_STAT|AT_SYMLINK_NOFOLLOW|AT_NO_AUTOMOUNT, STATX_ALL, {stx_mask=STATX_ALL, stx_attributes=0, stx_mode=S_IFDIR|0755, stx_size=4096, ...}) = 0
rt_sigaction(SIGPIPE, NULL, {sa_handler=SIG_IGN, sa_mask=[PIPE], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f91bab51f80}, 8) = 0
sysinfo({uptime=137, loads=[36608, 13984, 4928], totalram=16718983168, freeram=13827264512, sharedram=80588800, bufferram=213753856, totalswap=17280528384, freeswap=17280528384, procs=603, totalhigh=0, freehigh=0, mem_unit=1}) = 0
statx(AT_FDCWD, "/var/lib/flatpak/repo", AT_STATX_SYNC_AS_STAT|AT_SYMLINK_NOFOLLOW|AT_NO_AUTOMOUNT, STATX_ALL, {stx_mask=STATX_ALL, stx_attributes=0, stx_mode=S_IFDIR|0755, stx_size=4096, ...}) = 0
openat(AT_FDCWD, "/proc/sys/kernel/random/boot_id", O_RDONLY) = 7
newfstatat(7, "", {st_mode=S_IFREG|0444, st_size=0, ...}, AT_EMPTY_PATH) = 0
fcntl(7, F_GETFL)                       = 0x8000 (flags O_RDONLY|O_LARGEFILE)
read(7, "97acb8d7-696d-41ba-a3d3-3ff46a0b"..., 4096) = 37
read(7, "", 3072)                       = 0
close(7)                                = 0
openat(AT_FDCWD, "/var/lib/flatpak/repo", O_RDONLY|O_NOCTTY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 7
fstat(7, {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
openat(7, "objects", O_RDONLY|O_NOCTTY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 8
faccessat2(8, ".", W_OK, 0)             = -1 ENOSYS (Function not implemented)
faccessat(8, ".", W_OK)                 = -1 EACCES (Permission denied)
fstat(8, {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
openat(7, "tmp", O_RDONLY|O_NOCTTY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 9
newfstatat(AT_FDCWD, "/ostree/repo", 0x7ffdf55609f0, 0) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/usr/share/locale/locale.alias", O_RDONLY) = 10
newfstatat(10, "", {st_mode=S_IFREG|0644, st_size=2998, ...}, AT_EMPTY_PATH) = 0
read(10, "# Locale name alias data base.\n#"..., 4096) = 2998
read(10, "", 4096)                      = 0
close(10)                               = 0
openat(7, "config", O_RDONLY|O_NOCTTY|O_CLOEXEC) = 10
fstat(10, {st_mode=S_IFREG|0644, st_size=396, ...}) = 0
read(10, "[core]\nrepo_version=1\nmode=bare-"..., 396) = 396
read(10, "", 396)                       = 0
close(10)                               = 0
getuid()                                = 1000
mkdir("/home/bourne/.cache/flatpak/system-cache", 0755) = -1 EEXIST (File exists)
newfstatat(AT_FDCWD, "/home/bourne/.cache/flatpak/system-cache", {st_mode=S_IFDIR|0755, st_size=4096, ...}, 0) = 0
openat(AT_FDCWD, "/home/bourne/.cache/flatpak/system-cache", O_RDONLY|O_NOCTTY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 10
getuid()                                = 1000
openat(AT_FDCWD, "/etc/flatpak/remotes.d", O_RDONLY|O_NONBLOCK|O_CLOEXEC|O_DIRECTORY) = 11
newfstatat(11, "", {st_mode=S_IFDIR|0755, st_size=4096, ...}, AT_EMPTY_PATH) = 0
getdents64(11, 0x5570eed0bdd0 /* 3 entries */, 32768) = 88
getdents64(11, 0x5570eed0bdd0 /* 0 entries */, 32768) = 0
close(11)                               = 0
--- SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=0x36} ---
+++ killed by SIGSEGV (core dumped) +++
