As the title says, the Pamac tray widget stays red for a long time after installing all the updates. Is it just me and my installation or is this normal behavior?
It depends on how you installed the updates. If you updated via the command line, then the notifier will have no knowledge of that.
Usually you can right-click the widget and choose “Check updates”, which should remedy the problem.
Update is within the Pamac GUI. Right clicking on the widget only gives me the options:
- Package manager (which opens the GUI)
- Quit
Try opening the pamac
GUI via the widget and then refresh the mirrors.
Refreshing mirrors solved it. Thanks!
Will report back in case it happens with another update.
