On my Manjaro Cinnamon, Pamac does not show an icon in the notification area anymore. I guess this happened after update 2022-06-12, but I am not really sure.
What I have checked and done so far:
- Update Notifier ist enabled, command is sh -c “GDK_BACKEND=x11 pamac-tray”
- pamac-tray is running
- No errors listed in ~/.xsession-errors
- Disabling / Enabling check for updates in Pamac didn’t help
- Killing pamac tray and restart from shell didn’t help, neither “GDK_BACKEND=x11 pamac-tray” nor “pamac-tray”
There is no output when starting pamac-tray manually, even no error message. On another system, also with Cinnamon, which does not have this issue, starting pamac-tray gives some output messages, i. e. the updates found.
I have no idea what the reason could be, nor if it is an issue of Cinnamon or Pamac.
