Hi,
I’m having this weird problem where the pamac tab titles are not being rendered completely. The words (“Browse”, “Installed”, “Updates”) do not show completely.
I’m attaching the screenshot below.
My system information below:
$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.93-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=06d7363a-23c3-4c3d-97e3-3bc65484e084 ro quiet apparmor=1
Console: pty pts/2 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X513IA_KM513IA
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X513IA v: 1.0 serial: <filter>
UEFI: American Megatrends v: X513IA.300 date: 06/05/2020
ID-1: BAT0 charge: 9.9 Wh (29.4%) condition: 33.7/42.1 Wh (80.2%)
volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Discharging cycles: 496
RAM: total: 7.26 GiB used: 5.17 GiB (71.3%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: DIMM 0 size: 4 GiB speed: 3200 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: Hynix part-no: HMA851S6CJR6N-XN serial: N/A
Device-2: DIMM 0 size: 4 GiB speed: 3200 MT/s type: DDR4
total: 64 bits manufacturer: Samsung part-no: M471A5244CB0-CWE
serial: <filter>
Info: model: AMD Ryzen 7 4700U with Radeon Graphics socket: FP6 bits: 64
type: MCP arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600103
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/2000 boost: enabled
base/boost: 2000/4200 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
5: 1400 6: 1400 7: 1400 8: 1400 bogomips: 31952
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 03:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-3:3 chip-ID: 13d3:56a8 class-ID: 0e02 serial: <filter>
Display: server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.93-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 01:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
Device-2: ASIX AX88179 Gigabit Ethernet type: USB driver: ax88179_178a
bus-ID: 2-2:3 chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp3s0f3u2 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-2:2
Local Storage: total: 1.14 TiB used: 81.77 GiB (7.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFM256GDJTNG-8310A size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
rev: 80001C00 temp: 35.9 C scheme: GPT
SMART: yes health: PASSED on: 24d 14h cycles: 5,159
read-units: 51,603,854 [26.4 TB] written-units: 8,990,447 [4.60 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10SPZX-80Z10T2 family: Blue Mobile (SMR) size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 1A04 temp: 32 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 160d 4h cycles: 5157 Old-Age:
g-sense error rate: 402
ID-1: / raw-size: 52.2 GiB size: 51.13 GiB (97.95%) used: 23.63 GiB (46.2%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 06d7363a-23c3-4c3d-97e3-3bc65484e084
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 66.8 MiB (26.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: SYSTEM uuid: DA44-C033
ID-3: /home raw-size: 34.8 GiB size: 34 GiB (97.71%)
used: 27.13 GiB (79.8%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:6 label: N/A uuid: 941c21f5-3c1e-45ab-8989-ce9c68b0c218
ID-4: /run/timeshift/backup raw-size: 30 GiB size: 29.36 GiB (97.86%)
used: 29.34 GiB (99.9%) fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2 label: Manjaro-recovery
uuid: ab4be4b9-eb3d-43ea-a32c-8763e70be217
ID-1: swap-1 type: partition size: 11 GiB used: 1.61 GiB (14.6%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: feb7c417-87a9-413c-ae17-fb925a517a01
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 139.18 GiB fs: ntfs label: OS
uuid: DC20475720473832
ID-3: /dev/nvme0n1p7 maj-min: 259:7 size: 1.03 GiB fs: ntfs
label: RECOVERY uuid: E6BAAD46BAAD13D9
ID-4: /dev/sda1 maj-min: 8:1 size: 901.51 GiB fs: ntfs label: New Volume
uuid: 800C3F790C3F6974
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-4:5 info: No brand USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 2188:0ae1 class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 2-2:3 info: ASIX AX88179 Gigabit Ethernet type: Network
driver: ax88179_178a interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 496mA
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-2:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-2: 3-3:3 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 38.8 C mobo: 38.0 C gpu: amdgpu temp: 38.0 C
Fan Speeds (RPM): cpu: 0
Processes: 308 Uptime: 1d 4h 28m wakeups: 16 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1412
pacman: 1409 lib: 387 flatpak: 3 Shell: Zsh (sudo) v: 5.8
running-in: konsole inxi: 3.3.12
