hey I just wanted to report that the pamac remove --orphans command will remove gdm which will result in having no graphical login manager until you login and reinstall it by doing pamac install gdm or sudo pacman -S gdm
I had this happen on two machines after I wanted to remove packages I no longer needed and it shouldn’t be removing gdm
Yeah exactly that’s how it should be and it shouldn’t be removing core desktop packages. I’ll have to check a families machine as I also did it and make sure GDM is installed.
Yeah that’s true tho I installed Manjaro Gnome itself and didn’t specifically install the desktop on it’s own so that’s pretty odd. I hope I have helped catch an issue before it affects anyone.
