Pamac-QT - a new QT5-UI for libalpm
pamac
qt5
#62
I’m sorry. I was too busy to work on this project last two weeks so I didn’t implemented much. I’ll share what I have done shortly.
#64
Sure, no pressure. Sharing the code might help the project when able to review your work.
#65
Here it is: https://gitlab.com/LordTermor/pamac-qt-draft
But it’s really just a draft. There is some unnecessary code in it, no structure etc.
#66
Is your project public ? I can’t view it.
#67
Fixed.
Forgot to click “Save changes” button :grinning:
#68
I’ve created a PKGBUILD. However, it seems some files are still missing to be installed properly. @LordTermor: which files do we need to be installed where? Also I assume Breeze theme is currently fixed in this preview …
# Maintainer: Artyom Grinyov (LordTermor)
pkgbase=pamac-qt
pkgname=('pamac-qt')
_pkgver=0.1
pkgver=0.1
pkgrel=1
_commit=2fd25c1044a2d9a6719b8f9b2b94c60932edfd77
pkgdesc="A QT5 frontend for libalpm"
arch=('i686' 'x86_64')
url="https://gitlab.manjaro.org/applications/pamac-qt"
license=('GPL3')
depends=('pamac' 'qt5-base' 'qt5-quickcontrols2')
makedepends=('git')
options=(!emptydirs)
source=(#"pamac-$pkgver-$pkgrel.tar.gz::$url/-/archive/v$_pkgver/$pkgname-v$_pkgver.tar.gz")
        "pamac-$pkgver-$pkgrel.tar.gz::$url/-/archive/$_commit/$pkgname-$_commit.tar.gz")
sha256sums=('a12628f5e4672aa9535e8c01d4005948da4429ac6c66cb417c04f3e8d68f2e17')
build() {
  cd "$srcdir/$pkgname-$_commit"
  qmake-qt5 -makefile Pamac-Qt.pro
  make -j $jc
package_pamac-qt() {
  make INSTALL_ROOT=${pkgdir} install
  mkdir -p ${pkgdir}/usr/bin
  mv ${pkgdir}/opt/Pamac-Qt/bin/Pamac-Qt ${pkgdir}/usr/bin/pamac-qt
  chmod a+x ${pkgdir}/usr/bin/pamac-qt
# vim:set ts=2 sw=2 et:
#69
:+1:
the only note : in AlpmPackagesModel.cpp Ko…Mo its 1000 ; 1024 is (before 2000) “old” format Kio…Mio . pamac use 1000
#70
Feel free to modify it on our gitlab. I granted you the needed developer rights.
#71
At this point shouldn’t the description read “A Qt5 frontend for libpamac”?
#72
What will happen to the GTK3 Pamac if QT5 Pamac exists? Will it get dropped or still maintained?
#73
What files are missing? This PKGBUILD works for me fine.
I have not figured out how to set the QML style. Looks like we can use qqc2-desktop-style from the KDE but it depends on their Kirigami framework and I don’t know if we technically can make use of it without using the Kirigami in the pamac-qt.
#74
If you read the topic, it is clear that this is targeted for the kde users and other qt based DE’s, gtk3+ version will remain intact.
#75
From reading the threads I was under the impression the idea was to ship the qt version with qt-based environments and the gtk version with the gtk-based environments.
EDIT: I was 5 seconds too slow. :smile:
#76
Excuse me if I’m incorrect on this, but for Lxqt users the KDE dependencies should not be excessive or it will bloat what needs to be a light OS for old hardware. KDE is my main environment, but I think Lxqt users should also be considered when creating the Qt version. Just my opinion.
#77
Right now there is nothing KDE-specific in the code.
#78
Will you give an access to me?
BTW: It looks like Qt has this feature built-in since 5.10 so this function can be dropped.
#79
I didn’t say it had kde dependencies, but yeah your correction is actually true, hell if you don’t want to use the gtk3+ version i think you should be able to do it i any DE.
#80
Sure, simply register to the gitlab version and I grant you the needed access.
#81
Already done. Do I need to do something else?
#82
I’m still working on it from time to time (although I don’t have free time at all right now and I have some serious life troubles sadly)
