Hello.
I have tried to write a post in the Pamac forum, but I am not allowed to do so. why?
The thing is that Pamac (in the latest version of Manjaro with the latest version of Gnome) only shows me 21 applications!
Thank you.
missing package database?
sudo pacman -Syyu
That forum category is for the Manjaro developers working on Pamac. Hint: it sits under the #development category.
Those are the Featured applications. Make a different selection in the drop-down list and you’ll get more titles.
Thanks.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
