I just did a fresh install of Manjaro KDE 21.2rc1 testing branch and have been building up it slowly. I noticed earlier that when I went to install Vivaldi-Shapshot, Google-Chrome, and KSmoothDock I was only offered the build versions from AUR. All 3 have versions available through Pamac that do not have to be built. Is there a current issue with Pamac?
~ inxi -Faz ✔
Kernel: 5.15.8-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=ea27f534-1d62-4779-b2a5-542b6d58335f rw rootflags=subvol=@
quiet apparmor=1 security=apparmor udev.log_priority=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2423
date: 08/10/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2604 high: 3593 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3444 2: 3536
3: 2083 4: 2195 5: 2192 6: 2195 7: 3372 8: 3593 9: 2055 10: 2195 11: 2197
12: 2191 bogomips: 86271
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: eVga.com.
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 08:00.0
chip-ID: 10de:2187 class-ID: 0300
Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
loaded: nvidia resolution: <missing: xdpyinfo>
Device-1: NVIDIA TU116 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0a:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.15.8-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3 class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 20.82 TiB used: 11.36 TiB (54.6%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Seagate
model: XPG GAMMIX S11 Pro size: 476.94 GiB block-size: physical: 512 B
rev: 32B3T8EB temp: 31.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Patriot model: Viper M.2 VPN100
size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: ECFM22.6
temp: 30.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Seagate
model: Expansion HDD size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 1801 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate
model: ST8000AS0002-1NA17Z size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5980 serial: <filter> scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate
model: ST330006 51NS size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 7101 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 type: USB vendor: Seagate
model: ST3000DM 001-1E6166 size: 2.73 TiB block-size: physical: 4096 B
ID-7: /dev/sde maj-min: 8:64 type: USB vendor: PNY model: USB 3.0 FD
size: 115.38 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 238.17 GiB size: 238.17 GiB (100.00%)
used: 24.15 GiB (10.1%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 568 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 238.17 GiB size: 238.17 GiB (100.00%)
ID-4: /var/log raw-size: 238.17 GiB size: 238.17 GiB (100.00%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 44 C
Processes: 395 Uptime: 24m wakeups: 6 Memory: 31.33 GiB
used: 4.7 GiB (15.0%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1345 pacman: 1335 lib: 362 flatpak: 10 snap: 0
Shell: Zsh v: 5.8 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
