Pamac not updating - transaction_interface_daemon.vala:58
Just recently pamac stopped working on my system. I get this error:
** (pamac:16371): WARNING **: 07:23:22.426: transaction_interface_daemon.vala:58: failed to connect to dbus daemon: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer 'org.manjaro.pamac.daemon': startup job failed
Error: Daemon Error: trans_refresh: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer 'org.manjaro.pamac.daemon': startup job failed
Preparing...
Error: Daemon Error: get_authorization: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer 'org.manjaro.pamac.daemon': startup job failed
Error: Daemon Error: remove_authorization: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer 'org.manjaro.pamac.daemon': startup job failed
I seem to still be able to update with pacman and the flatpak updater. I tried refreshing my mirrors as well, but not sure what else to try. The same error occurs in the GUI and Terminal.
Here is some system information:
ManjaroLinux 24.1.2 Xahea
  Kernel: 6.1.112-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=116f6793-e788-48bc-a7c9-2b280f6a7a56 rw quiet
    cryptdevice=UUID=2a044984-b080-4a91-937f-5538c54e2bdc:luks-2a044984-b080-4a91-937f-5538c54e2bdc
    root=/dev/mapper/luks-2a044984-b080-4a91-937f-5538c54e2bdc apparmor=1
    security=apparmor
    resume=/dev/mapper/luks-8928dab2-de51-4503-bade-c085833eed34
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
  Type: Laptop System: TOSHIBA product: Satellite P50-C v: PSPT2A-00E001
    serial: <superuser required>
  Mobo: FF50 model: 06F3 v: Type2 - Board Version
    serial: <superuser required> part-nu: PSPT2A uuid: <superuser required>
    UEFI: INSYDE v: 1.20 date: 09/11/2015
  ID-1: BAT1 charge: 21.4 Wh (69.0%) condition: 31.0/44.1 Wh (70.4%)
    volts: 16.3 min: 14.8 model: Panasonic PA5195U-1BRS type: Li-ion serial: N/A
    status: charging cycles: 375
  System RAM: total: 8 GiB available: 7.6 GiB used: 5.23 GiB (68.9%)
  Array-1: capacity: 16 GiB slots: 4 modules: 1 EC: None
  Device-1: ChannelA-DIMM0 type: no module installed
  Device-2: ChannelA-DIMM1 type: no module installed
  Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 8 GiB
    speed: 1600 MT/s volts: curr: 1.35 min: 1.35 max: 2 width (bits): data: 64
    total: 64 manufacturer: Samsung part-no: M471B1G73DB0-YK0 serial: <filter>
  Device-4: ChannelB-DIMM1 type: no module installed
  Info: model: Intel Core i7-6500U bits: 64 type: MT MCP arch: Skylake
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x4E (78) stepping: 3 microcode: 0xF0
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 2834 min/max: 400/3100 scaling: driver: intel_pstate
    governor: powersave cores: 1: 2834 2: 2834 3: 2834 4: 2834 bogomips: 20810
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: gather_data_sampling status: Vulnerable: No microcode
    vulnerable
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Toshiba driver: i915
    v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
    empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
  Device-2: NVIDIA GM108M [GeForce 930M] vendor: Toshiba driver: N/A
    alternate: nouveau non-free: 550.xx+ status: current (as of 2024-09;
    EOL~2026-12-xx) arch: Maxwell code: GMxxx process: TSMC 28nm
    built: 2014-2019 pcie: gen: 3 speed: 8 GT/s lanes: 4 bus-ID: 01:00.0
    chip-ID: 10de:1346 class-ID: 0302
  Device-3: IMC Networks TOSHIBA Web Camera - HD driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 13d3:5652
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: LG Display 0x0470 built: 2014 res: 1920x1080
    hz: 60 dpi: 141 gamma: 1.2 chroma: red: x: 0.639 y: 0.345 green: x: 0.333
    y: 0.627 blue: x: 0.149 y: 0.051 white: x: 0.314 y: 0.329
    size: 345x194mm (13.58x7.64") diag: 396mm (15.6") ratio: 16:9
    modes: 1920x1080
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.0.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 520 (SKL GT2)
    device-ID: 8086:1916 memory: 3.71 GiB unified: yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Toshiba
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
    snd_sof_pci_intel_skl bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
  API: ALSA v: k6.1.112-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.5 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
  Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
    vendor: Toshiba driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
  Device-1: luks-2a044984-b080-4a91-937f-5538c54e2bdc maj-min: 254:0
    type: LUKS dm: dm-0 size: 223.79 GiB
  Components:
  p-1: sda2 maj-min: 8:2 size: 223.79 GiB
  Device-2: luks-8928dab2-de51-4503-bade-c085833eed34 maj-min: 254:1
    type: LUKS dm: dm-1 size: 8.8 GiB
  Components:
  p-1: sda3 maj-min: 8:3 size: 8.8 GiB
  Local Storage: total: 232.89 GiB used: 187.8 GiB (80.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: BB6Q scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUB0N rev: TB04
    dev-links: cdrom
  ID-1: / raw-size: 223.79 GiB size: 219.21 GiB (97.96%)
    used: 186.2 GiB (84.9%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-2a044984-b080-4a91-937f-5538c54e2bdc label: N/A
    uuid: 116f6793-e788-48bc-a7c9-2b280f6a7a56
    used: 440 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: 2B3C-BF64
  ID-1: swap-1 type: partition size: 8.8 GiB used: 1.59 GiB (18.1%)
    priority: -2 dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-8928dab2-de51-4503-bade-c085833eed34 label: swap
    uuid: 93852b8f-275c-487f-bb25-ebc2e0c91d08
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-2:5 info: Logitech M-UAS144 [LS1 Laser Mouse] type: mouse
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 046d:c062 class-ID: 0301
  Device-2: 1-7:3 info: IMC Networks TOSHIBA Web Camera - HD type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 13d3:5652 class-ID: 0e02
    serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 45.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: 1830 pm: pacman pkgs: 1783 libs: 440 tools: pamac pm: flatpak
    pkgs: 47
    1: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 238
  1: cpu: 300% command: ps pid: 16754 mem: 3.58 MiB (0.0%)
  2: cpu: 6.7% command: firefox pid: 15962 mem: 294.0 MiB (3.7%)
  3: cpu: 6.0% command: freetube pid: 11738 mem: 343.9 MiB (4.4%)
  4: cpu: 5.8% command: firefox pid: 16032 mem: 304.1 MiB (3.9%)
  5: cpu: 1.4% command: freetube pid: 11711 mem: 131.1 MiB (1.6%)
  Memory top: 5 of 238
  1: mem: 411.6 MiB (5.2%) command: firefox pid: 4202 cpu: 0.2%
  2: mem: 343.9 MiB (4.4%) command: freetube pid: 11738 cpu: 6.0%
  3: mem: 333.6 MiB (4.2%) command: firefox pid: 4409 cpu: 0.0%
  4: mem: 304.1 MiB (3.9%) command: firefox pid: 16032 cpu: 5.8%
  5: mem: 294.0 MiB (3.7%) command: firefox pid: 15962 cpu: 6.7%
  Processes: 238 Power: uptime: 8d 21h 37m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 7 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 3.03 GiB
    services: org_kde_powerdevil,upowerd Init: systemd v: 256
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.36
Thanks!
How long has this issue been occurring? Have you rebooted since you last ran an update?
It happened a couple of weeks ago. Sorry I forgot to mention, yes I also tried rebooting and doing a shut down/power on. I had a look through the forums for issues with a similar error but a reboot hasn’t fixed it in my case unfortunately.
Any other ideas?
You might check something like
sudo pacman -Qqk
Sorry I was away for a few days. I just tried running that command but it gives no output. Should it?
No output is good.
Please try;
sudo pacman -Syu libpamac
That’s fixed it, thanks a lot! The pacman command did a system upgrade of a bunch of packages too, then I ran pamac and it upgraded a couple of AUR things. Now if I re-run pamac it says there’s nothing to do - no errors. Thanks again :slight_smile:
