mirto
1
Hi all,
in the last three days trying a pamac upgrade gives me the error : “Failed to synchronize AUR database”
What can I do?
Here the command log:
~ LANG=C sudo pamac upgrade 126 ✘
[sudo] password for mirto:
Warning: Building packages as dynamic user
Warning: Setting build directory to /var/cache/pamac
Preparing...
Nothing to do.
cscs
2
First off never use sudo
with pamac.
Second, to use the AUR with pamac you should employ the --aur
flag .
Third, you may wish to add --force-refresh
as well.
Fourth, as you did use sudo you may need to delete the build directory.
mirto
3
Thanks a lot. It worked.
BTH why pamac don’t need sudo?
Command output:
~ lang=C pamac upgrade --aur --force-refresh ✔ 19s
Preparazione...
Autenticazione richiesta per installare, aggiornare o rimuovere pacchetti
Multiple identities can be used for authentication:
1. Mirto (mirto)
2. Federica (federica)
3. Enrico (enrico)
Choose identity to authenticate as (1-3): 1
Password:
Sincronizzazione database dei pacchetti...
Aggiornamento core.db...
Aggiornamento extra.db...
Aggiornamento multilib.db...
Aggiornamento core.files...
Aggiornamento extra.files...
Aggiornamento multilib.files...
Aggiornamento AUR...
Niente da fare.
Transazione completata con successo.
cscs
4
It uses polkit if/when necessary to elevate privileges.
Using root/sudo will break the permissions of the build directory.
system
Closed
6
