Pamac-manager won't start "No provider of glGenSamplers found"
pamac-manager does not start either from the desktop icon or from the command line.
#> pamac-manager
(pamac-manager:2973): Adwaita-WARNING **: 11:13:00.017: Using GtkSettings:gtk-application-prefer-dark-theme with libadwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
bef flathub/app/com.mojang.Minecraft/x86_64/stable flathub
aft flathub/app/com.mojang.Minecraft/x86_64/stable flathub
bef flathub/app/com.slack.Slack/x86_64/stable flathub
aft flathub/app/com.slack.Slack/x86_64/stable flathub
bef flathub/app/com.discordapp.Discord/x86_64/stable flathub
aft flathub/app/com.discordapp.Discord/x86_64/stable flathub
bef flathub/app/com.spotify.Client/x86_64/stable flathub
aft flathub/app/com.spotify.Client/x86_64/stable flathub
bef flathub/app/com.skype.Client/x86_64/stable flathub
aft flathub/app/com.skype.Client/x86_64/stable flathub
bef flathub/app/com.valvesoftware.Steam/x86_64/stable flathub
aft flathub/app/com.valvesoftware.Steam/x86_64/stable flathub
No provider of glGenSamplers found.  Requires one of:
Desktop OpenGL 3.3
GL_ARB_sampler_objects
OpenGL ES 3.0
zsh: IOT instruction  pamac-manage
There was a major update yesterday, which introduced a problem with libpamac. The package was updated earlier today. Have you updated your system yet? :arrow_down:
sudo pacman-mirrors -f && sudo pacman -Syyu
Be sure to let it finish and do not interrupt the process.
I had already updated the mirrors and installed the latest updates. The problem persists. I guess the problem is related to the video driver because of the last lines of the error message.
Desktop OpenGL 3.3
OpenGL ES 3.0
My driver is nvidia-340, owner driver installed from aur.
#> glxinfo | grep "OpenGL version"
OpenGL version string: 3.3.0 NVIDIA 340.108
Have you also updated your AUR packages? :arrow_down:
yay -Syu
Yes, the driver is up to date.
My desktop environment is KDE.
In my laptop which has a Intel video driver everything works fine.
Your desktop environment has nothing to do with that. :wink:
Then I guess it must be related to your proprietary Nvidia driver, and in that case, I’m afraid I myself can no longer be of assistance. Hopefully someone with more knowledge about Nvidia graphics will be able to help you.
:man_shrugging:
OK. I find a solution for this: Just install pamac-gtk3 from command line
pamac install pamac-gtk3
And now is working!
…and following this thread
https://aur.archlinux.org/packages/nvidia-340xx-dkms#comment-931145
turns out there is a conflict between Nvidia driver and gtk4. A proposed solution is to add the following environment variable:
/usr/bin/env GDK_DEBUG=gl-glx YOURPROGRAM
Were you using pamac-gtk (gtk4) before ?
Yes!! pamac-gtk was replaced by pamac-gtk3
