The last 2 occasions I’ve tried updating my system via pamac-manager I’ve got failures at the post-transaction hooks phase.
The packages download and upgrade but the process gets stuck during the post-transaction hooks with the output shown below. After the first occurence I was unable to get to the login screen and had to resort to getting into the grub menu, restarting into a non-graphical login, then running startx
manually. This works and my desktop runs.
I thought this might be a one-off, and waited for another update to see if it would resolve itself. Unfortunately that wasn’t the case. Any ideas on why this might be happening, and what can be done to resolve the issue?
TIA
#### REMOVED LOTS OF PACKAGES FOR BREVITY
Upgrading xorg-xinit (1.4.1-3 -> 1.4.2-1)...
Upgrading zsh (5.9-1 -> 5.9-2)...
Creating system user accounts...
Updating journal message catalog...
Reloading system manager configuration...
Updating udev hardware database...
Applying kernel sysctl settings...
Creating temporary files...
Reloading device manager configuration...
Arming ConditionNeedsUpdate...
Updating the MIME type database...
Rebuilding certificate stores...
Updating module dependencies...
Install DKMS modules
==> dkms install --no-depmod wireguard/1.0.20211208 -k 5.4.228-1-MANJARO
==> depmod 5.4.228-1-MANJARO
Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'default'
-> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
==> Starting build: 5.4.228-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
loadkeys: Unable to open file: au: No such file or directory
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'fallback'
-> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: bfa
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64.img
==> Starting build: 6.1.0-1-MANJARO
==> WARNING: Possibly missing firmware for module: xhci_pci
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.1-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.1-x86_64-fallback.img
Updating the appstream cache...
✔ Metadata cache was updated successfully.
Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.4-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.4-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
ERROR: asr: reading /dev/sdb[Input/output error]
ERROR: ddf1: reading /dev/sdb[Input/output error]
ERROR: hpt37x: reading /dev/sdb[Input/output error]
ERROR: hpt45x: reading /dev/sdb[Input/output error]
ERROR: isw: reading /dev/sdb[Input/output error]
ERROR: jmicron: reading /dev/sdb[Input/output error]
ERROR: lsi: reading /dev/sdb[Input/output error]
ERROR: nvidia: reading /dev/sdb[Input/output error]
ERROR: pdc: reading /dev/sdb[Input/output error]
