Hello together,
I have the problem, that the icons in pamac for select / unselect not correct visible. I tried many themes, but without solution.
look at that:
can you help me?
System: Kernel: 5.13.8-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.22.4 Distro: Manjaro Linux
Machine: Type: Laptop System: TUXEDO product: TUXEDO Pulse 15 Gen1 v: Standard serial: <filter>
Mobo: TUXEDO s model: PULSE1501 v: Standard serial: <filter> UEFI: American Megatrends v: N.1.07.A02
date: 12/08/2020
Battery: ID-1: BAT0 charge: 88.9 Wh (97.1%) condition: 91.6/91.6 Wh (100.0%)
CPU: Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP cache: L2: 4 MiB
Speed: 1397 MHz min/max: 1400/2900 MHz Core speeds (MHz): 1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397 7: 1397
8: 1397 9: 1397 10: 1397 11: 1397 12: 1395 13: 1397 14: 1396 15: 1391 16: 1374
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Renoir driver: amdgpu v: kernel
Device-2: Chicony HD Webcam type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.13 driver: loaded: amdgpu,ati unloaded: modesetting resolution: 1920x1080~60Hz
OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.8-1-MANJARO LLVM 12.0.1) v: 4.6 Mesa 21.1.6
Audio: Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.13.8-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.33 running: yes
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb
Drives: Local Storage: total: 232.89 GiB used: 36.8 GiB (15.8%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SA2000M8250G size: 232.89 GiB
Partition: ID-1: / size: 219.86 GiB used: 36.8 GiB (16.7%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 511 MiB used: 304 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 34.4 C mobo: 33.0 C gpu: amdgpu temp: 33.0 C
Info: Processes: 332 Uptime: 9m Memory: 7.19 GiB used: 1.4 GiB (19.5%) Shell: Bash inxi: 3.3.06
regards
caho
