Pamac hangs during update - trashes linitramfs & leaves system unbootable
Home Theater server hangs while updating with pamac-daemon while running mkinitcpio leaving initramfs files full of garbage and the system unbootabe. :anguished:
Screen grab of pamac output from vinagre:
There are no other systems on this server for os-prober to find.
How to fix this (relatively) remote server?
fixed for all kernel <510
Issue is fixed. Sorry for the problem caused by that …
BTW ~ Do not think this is related to “Issue with mkinitcpio” as my other four manjaro systems updated without problems. All but one of the five manjaro systems is updated daily. I use command line update except today used GUI pamac-daemon because of libcanberra-streamer conflict.
In any case thanks :smiling_face_with_three_hearts: for the fix, the last time I had to do this was on a long since deprecated xubuntu system (back when the dead sea was just sick :wink:)
was a problem with only kernel < 5.10 (your screenshot)
for this conflit, use sudo pamac update
All fixed (more or less)
Booting live and manjaro-chroot (as per papajoke above)
Required removing /var/lib/pacman/db.lck
and running pacman -Syu which fixed mkinitcpio
Then booting (sans live) into linux510 resulted in network fail :roll_eyes:
Reboot into linux54 got network success, deprecated linux510
Enough for a while… … … .
