Pamac GUI GNOME error
After a recent update(1st of august) GUI of pamac reports an error during every attempt to refresh, search for updates. I’ve got no other issues what soever, even pamac CLI works and updates properly.
Screenshot from 2023-08-16 18-28-39
There was a bug in pamac in those days, and that update also included the merger of the Community repository into the Extra repository. In a terminal, issue the following commands… :arrow_down:
sudo pacman-mirrors -f 5 && sudo pacman -Fy && sudo pacman -Syyu
pamac update --force-refresh
When done, be sure to also merge your .pacnew files.
