I’m having issues with pamac-manager. When I try typing in the the search bar, every character I type is entered twice. e.g. a = ‘aa’. Oddly enough if I try searching pamac’s history, it works fine.
If I close down ibus, it works like normal. Any way to fix this issue? version 9.5.12 works perfectly fine. It only started with version 10.
Thanks.
