Was building Veloren from AUR, then it ate up both RAM and swap and I had to hard reboot. Photo below shows frozen screen before manual reboot. After reboot, it seems Pamac didn’t install Airshipper which the games uses as launcher. I wonder if somehow it works as requirement for the Veloren AUR package.
Any ideas?
Output of inxi -v7 --filter
. Btw this RAM is brand new working perfectly.
Kernel: 5.19.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Dell product: Inspiron 3584 v: N/A
Mobo: Dell model: 05RCHV v: A00 serial: <superuser required> UEFI: Dell
v: 1.17.0 date: 03/24/2022
ID-1: BAT0 charge: 10.6 Wh (92.2%) condition: 11.5/42.0 Wh (27.4%)
volts: 12.9 min: 11.4 model: BYD DELL FW8KR96 type: Li-ion serial: <filter>
status: charging
RAM: total: 7.66 GiB used: 2.75 GiB (35.9%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: dual core model: Intel Core i3-7020U bits: 64 type: MT MCP
smt: enabled arch: Amber/Kaby Lake note: check level: v3 rev: 9 cache:
L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 1468 high: 1548 min/max: 400/2300 cores: 1: 1520
2: 1343 3: 1463 4: 1548 bogomips: 18406
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx
msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg
sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
arch: Gen-9.5 ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:5921 class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD type: USB driver: N/A
bus-ID: 1-5:3 chip-ID: 0bda:5520 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x71ec res: 1366x768 hz: 60 dpi: 101
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") modes: 1366x768
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
Sound Server-1: ALSA v: k5.19.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.58 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel pcie: speed: 2.5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-7:5
chip-ID: 0cf3:e009 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 931.51 GiB used: 95.82 GiB (10.3%)
ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-75Z10T2
size: 931.51 GiB speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A03 scheme: GPT
ID-1: / size: 37.11 GiB used: 24.79 GiB (66.8%) fs: ext4 dev: /dev/sda8
label: N/A uuid: d490644f-c0c6-4cd2-a1b8-3399f98ade5c
ID-2: /boot/efi size: 511 MiB used: 304 KiB (0.1%) fs: vfat
dev: /dev/sda7 label: NO_LABEL uuid: F9C1-B0CE
ID-3: /home size: 118.56 GiB used: 67.29 GiB (56.8%) fs: ext4
dev: /dev/sda10 label: N/A uuid: 3989e7da-996f-4a8c-9b06-6d3d52e37b63
ID-4: /mnt/veracrypt4 size: 4.93 GiB used: 3.74 GiB (75.8%) fs: ext4
dev: /dev/dm-0 mapped: veracrypt4 label: N/A uuid: N/A
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda9 label: N/A uuid: f8aae6e5-5e27-4d69-8332-16701ccef143
ID-1: /dev/sda1 size: 650 MiB fs: vfat label: ESP uuid: D211-7C1A
ID-2: /dev/sda2 size: 128 MiB fs: <superuser required> label: N/A
uuid: N/A
ID-3: /dev/sda3 size: 752.71 GiB fs: ntfs label: OS
uuid: 8868568F68567BBE
ID-4: /dev/sda4 size: 990 MiB fs: ntfs label: WINRETOOLS
uuid: 2E66E97566E93DE9
ID-5: /dev/sda5 size: 12.33 GiB fs: ntfs label: Image
uuid: 1AC8EA5AC8EA33A3
ID-6: /dev/sda6 size: 1.22 GiB fs: ntfs label: DELLSUPPORT
uuid: 8C98D3C298D3A8CA
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-3:2 info: MosArt Wireless Mouse 2.4G type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 062a:4106 class-ID: 0301
Device-2: 1-5:3 info: Realtek Integrated_Webcam_HD type: Video
driver: N/A interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-3: 1-6:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-4: 1-7:5 info: Qualcomm Atheros type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 0cf3:e009
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 46.0 C pch: 42.5 C mobo: 44.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 2674
Processes: 219 Uptime: 20m wakeups: 1 Init: systemd v: 251
default: graphical Compilers: gcc: 12.2.0 clang: 14.0.6 Packages:
pm: pacman pkgs: 1450 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.21
