command not found: downgrade
That is absolutely not related at all.
The downgrade setting is relative to the pacman option -Syuu
the second u
in the command option. It is when a package got downgraded in the repositories, or when you come from a more up to date branch to a lesser updated branch. You should not enable this setting if you don’t have reason to use it.
downgrade
is a program completely unrelated to this setting in Pamac (or Pacman). Install it if you want to use it.
