I’m pretty sure my title doesn’t describe the problem clearly but I cannot think of anything better .
when i search for something in the start menu of kde it gives me an option to install from pamac but clicking that just opens an empty screen in pamac
Apology then. I did perceive it as an objection to sync the system just to install one package.
As you probably figured the number is not the number of files in the mentioned folder - but every file counted from the root of the tree - and that count is bound to change all the time - tmp files are created and removed all the time - so that count is a point-in-time count.
Well - it is pamac - have you tried the Refresh databases option from the menu?
@bogdancovaciu i tried installing it through the method in achieved forums
and also tried installing again by the instructions in gitlab but it didnt work
Maybe it can be changed (did not test) or maybe we can ping @papajoke to see if there will be an update, and maybe @Yochanan to make a PKGBUILD ? hehehe Thanks !
I’m pretty sure the mantra is (unless in extreme circumstances like fixing keys) do not sync without upgrading. And definitely do not sync, then install a new package, without upgrading first.
The commands together equal sudo pacman -Syy seahorse … which is not advisable.
i edited that python file i just commented out that line as it will just throw a warning
and restarted my laptop. Now it’s working. not perfectly though . icons of the packages arent shown
Not sure. Looking at the Application Launcher settings for the plugins, since it uses KRunner, it shows Software Center as being enabled
Searching works, with icons too, but as you pointed out in OP the Pamac windows remains empty when i click on one of the search results.
As i understand it, is either: the result is not passed correctly to Pamac, or Pamac is not getting those search results properly, so not sure where to report that, to Pamac or Kickoff developers …
Hey @LordTermor - any idea about this? Thanks!
as the krunner_pamac which was developed by @papajoke is showing the application from pamac when clicking. It isn’t a bug with pamac. So its a bug with kickoff right?
The issue has now been solved .Last kde update probably did that .now clicking that entry in kickoff opens Discover (kde software center) to show the application.
