So, guys, I am a bit confused here, and please sorry for asking this (I have not found any thread who explains this).
Well, I have installed a few software from AUR in my Manjaro. But, I done this through pamac install PACKAGENAME instead the way I heard about (pamac build).
So, am I correct when supposing that Pamac “does” everything automatically in this case? I will never have to use pamac build when leading with software from AUR?
Title doesn’t make a lot of sense. All AUR helpers build PKGBUILDs automatically - as opposed to using ‘makepkg’.
And you have to do anything manually when using ‘build’?
Anyway, as I just said recently, this is just bad design. Either have different arguments for different things, or, if you have to, have one argument for everything and remove duplicates.
If you have AUR enabled in Pamac Settings, then using INSTALL will also look into the AUR if the package is not found in repositories I think, and then if you don’t have the setting enabled, you will need to use BUILD because INSTALL will not look for AUR then.
