Pamac CLI Password prompt
When using pamac-cli and typing the password wrong, it exits without being able to simply retype it again like pacman does for example.
Password:
polkit-agent-helper-1: pam_authenticate failed: Authentication failure
==== AUTHENTICATION FAILED ====
This is painful when using pamac-cli in bash scripts for example.
Would it be possible to change that?
Thanks!
I don't think that is possible - it is a Pamac developer choice to fail on invalid authorization.
I made a feature request, let's see how that goes :wink:
If you don't want to build package from AUR you can also run pamac with sudo in your script.
That is exactly the issue because I use it to update the AUR in a bash script and can't use sudo :see_no_evil:
Ok but it can't be easily done. The only solution would be to code our own polkit agent.
@guinux
I did already fear something like that, but wasn't sure about the implementation in Pamac.
Do you think it's worth bringing this topic to upstream as a feature request?
Thanks for looking into it!
Yes you can. Know pamac-cli uses pkttyagent.
