Got this message for the first time. I’d like to keep both… is that ok?
yay -Syu output w/ error message
$ yay -Syu
[sudo] password for chewie:
core is up to date
extra 2015.2 KiB 407 KiB/s 00:05 [######################] 100%
community 6.3 MiB 446 KiB/s 00:15 [######################] 100%
multilib is up to date
resolving dependencies...
Packages (1) manjaro-application-utility-1.3.3-4.1
Total Download Size: 0.04 MiB
Total Installed Size: 0.17 MiB
Net Upgrade Size: 0.00 MiB
:: Retrieving packages...
error: failed retrieving file 'manjaro-application-utility-1.3.3-4.1-any.pkg.tar.zst' from mirrors.ocf.berkeley.edu : Resolving timed out after 10000 milliseconds
manjaro-applicat... 45.6 KiB 257 KiB/s 00:00 [######################] 100%
(1/1) checking keys in keyring [######################] 100%
(1/1) checking package integrity [######################] 100%
(1/1) loading package files [######################] 100%
(1/1) checking for file conflicts [######################] 100%
(1/1) checking available disk space [######################] 100%
(1/1) upgrading manjaro-application-utility [######################] 100%
(1/1) Arming ConditionNeedsUpdate...
:: Searching databases for updates...
:: Searching AUR for updates...
-> Missing AUR Packages: moka-icon-theme pamac-common pamac-flatpak-plugin pamac-gnome-integration pamac-gtk pamac-snap-plugin
-> Orphaned AUR Packages: agg
-> Flagged Out Of Date AUR Packages: gnome-activity-journal hfsprogs mono-upnp-git
:: 3 Packages to upgrade.
3 aur/lagrange 0.13.2-1 -> 1.0.0-1
2 aur/nordvpn-bin 3.8.8-2 -> 3.8.8-4
1 aur/pamac-cli 9.5.12-1 -> 10.0.0-1
==> Packages to exclude: (eg: "1 2 3", "1-3", "^4" or repo name)
:: Checking for conflicts...
:: Checking for inner conflicts...
Package conflicts found:
-> Installing pamac-cli will remove: pamac-gtk (pamac)
-> Conflicting packages will have to be confirmed manually
[Aur:3] lagrange-1.0.0-1 nordvpn-bin-3.8.8-4 pamac-cli-10.0.0-1
3 lagrange (Installed) (Build Files Exist)
2 nordvpn-bin (Installed) (Build Files Exist)
1 pamac-cli (Installed)
==> Packages to cleanBuild?
==> [N]one [A]ll [Ab]ort [I]nstalled [No]tInstalled or (1 2 3, 1-3, ^4)
:: Downloaded PKGBUILD (1/3): lagrange
:: Downloaded PKGBUILD (2/3): nordvpn-bin
:: Downloaded PKGBUILD (3/3): pamac-cli
1 pamac-cli (Installed) (Build Files Exist)
==> Diffs to show?
==> a
diff --git /home/chewie/.cache/yay/lagrange/PKGBUILD /home/chewie/.cache/yay/lagrange/PKGBUILD
new file mode 100644
index f7ebee7..d3de1b3 100644
--- /home/chewie/.cache/yay/lagrange/PKGBUILD
+++ /home/chewie/.cache/yay/lagrange/PKGBUILD
@@ -2,7 +2,7 @@
pkgname=lagrange
pkgrel=1
-pkgver=0.13.1
+pkgver=1.0.0
pkgdesc="Beautiful Gemini Client"
url="https://git.skyjake.fi/skyjake/lagrange"
arch=("any")
@@ -30,4 +30,5 @@ package() {
make PREFIX="/usr" DESTDIR="$pkgdir" install
-md5sums=('8fdf46325969e0ddd8dd1a29d951e174')
+md5sums=('4f821e05c5ac53bb25293458384ef11c')
diff --git /home/chewie/.cache/yay/nordvpn-bin/PKGBUILD /home/chewie/.cache/yay/nordvpn-bin/PKGBUILD
index 2b98dff..9da6327 100644
--- /home/chewie/.cache/yay/nordvpn-bin/PKGBUILD
+++ /home/chewie/.cache/yay/nordvpn-bin/PKGBUILD
@@ -4,7 +4,7 @@
pkgname=nordvpn-bin
pkgver=3.8.8
-pkgrel=1
+pkgrel=4
pkgdesc="NordVPN CLI tool for Linux"
arch=('x86_64' 'i686' 'armv7h' 'aarch64')
url="https://nordvpn.com/download/linux/"
@@ -28,4 +28,5 @@ package() {
mv "${pkgdir}/usr/sbin/nordvpnd" "${pkgdir}/usr/bin"
rm -r "${pkgdir}/etc/init.d"
rm -r "${pkgdir}/usr/sbin"
+ echo "g nordvpn - -" | install -Dm644 /dev/stdin "${pkgdir}/usr/lib/sysusers.d/${pkgname}.conf"
diff --git /home/chewie/.cache/yay/nordvpn-bin/nordvpn-bin.install /home/chewie/.cache/yay/nordvpn-bin/nordvpn-bin.install
index 0400c44..2065944 100644
--- /home/chewie/.cache/yay/nordvpn-bin/nordvpn-bin.install
+++ /home/chewie/.cache/yay/nordvpn-bin/nordvpn-bin.install
@@ -1,6 +1,27 @@
post_install() {
echo ':: In order to enable nordvpn you have to start the following service:'
echo ' sudo systemctl enable --now nordvpnd'
+ echo ':: You have to add yourself to the nordvpn group:'
+ echo " sudo gpasswd -a USERNAME nordvpn"
+ echo ':: You then have to restart for the group to be created:'
+ echo " reboot"
+post_upgrade() {
+ echo ':: In order to enable nordvpn you have to start the following service:'
+ echo ' sudo systemctl enable --now nordvpnd'
+ echo " reboot"
+pre_install() {
+ chattr -i /var/lib/nordvpn/data/*
+pre_upgrade() {
pre_remove() {
diff --git /home/chewie/.cache/yay/pamac-cli/.gitignore /home/chewie/.cache/yay/pamac-cli/.gitignore
index 0000000..81d8e83
--- /dev/null
+++ /home/chewie/.cache/yay/pamac-cli/.gitignore
@@ -0,0 +1,5 @@
+*.gz
+*.tar
+*.tar.*
+/pkg/*
+/src/*
diff --git /home/chewie/.cache/yay/pamac-cli/PKGBUILD /home/chewie/.cache/yay/pamac-cli/PKGBUILD
index 0000000..41684c7
--- /dev/null
+++ /home/chewie/.cache/yay/pamac-cli/PKGBUILD
@@ -0,0 +1,71 @@
+# Contributor: Zeph <zeph33@gmail.com>
+# Maintainer: Zeph <zeph33@gmail.com>
+# https://gitlab.manjaro.org/packages/extra/pamac
+ENABLE_FLATPAK=0
+ENABLE_SNAPD=0
+pkgname=pamac-cli
+pkgver=10.0.0
+pkgrel=1
+_pkgfixver=$pkgver
+_commit='4431c12f2b7920ef437b9a30068f7a545d72549d'
+sha256sums=('142bb64f748e4edcedc71daa6997e403a4e7c4161b2aaf5dc522dee377cd7914'
+ '13159694127c05fdc41f1ad83aa20e6d1c7c44d73b15046c62613d7f8e522c22')
+pkgdesc="Pamac cli frontend for libalpm"
+arch=('i686' 'x86_64' 'arm' 'armv6h' 'armv7h' 'aarch64')
+url="https://gitlab.manjaro.org/applications/pamac"
+license=('GPL3')
+depends=('glib2>=2.42' 'json-glib' 'libsoup' 'pacman>=5.2' 'appstream-glib' 'archlinux-appstream-data' 'git')
+optdepends=('')
+makedepends=('gettext' 'itstool' 'vala>=0.36.6' 'meson' 'ninja' 'gobject-introspection')
+conflicts=('pamac' 'pamac-aur' 'pamac-aur-git')
+provides=('pamac')
+replaces=('pamac')
+options=(!emptydirs)
+install=
+define_meson=''
+if [ "${ENABLE_FLATPAK}" = 1 ]; then
+ depends+=('flatpak')
+ define_meson+=' -Denable-flatpak=true'
+fi
+if [ "${ENABLE_SNAPD}" = 1 ]; then
+ depends+=('snapd' 'snapd-glib')
+ define_meson+=' -Denable-snap=true'
+fi
+source=("pamac-$pkgver-$pkgrel.tar.gz::$url/-/archive/$_commit/pamac-$_commit.tar.gz" "meson.build")
+prepare() {
+ cd "$srcdir/pamac-$_commit"
+ # adjust version string
+ sed -i -e "s|\"$_pkgfixver\"|\"$pkgver-$pkgrel\"|g" src/version.vala
+build() {
+ cp -f "$srcdir/meson.build" "$srcdir/pamac-$_commit/src/meson.build"
+ mkdir -p builddir
+ cd builddir
+ meson --buildtype=release \
+ --prefix=/usr \
+ --sysconfdir=/etc $define_meson
+ # build
+ ninja
+package() {
+ cd "$srcdir/pamac-$_commit/builddir"
+ DESTDIR="$pkgdir" ninja install
+ # clean graphic files
+ rm -rf "$pkgdir/etc/xdg"
+ rm -rf "$pkgdir/usr/share/applications"
+ rm -rf "$pkgdir/usr/share/dbus-1/services"
+ rm -rf "$pkgdir/usr/share/gnome-shell"
+ rm -rf "$pkgdir/usr/share/icons"
diff --git /home/chewie/.cache/yay/pamac-cli/meson.build /home/chewie/.cache/yay/pamac-cli/meson.build
index 0000000..6428c51
--- /dev/null
+++ /home/chewie/.cache/yay/pamac-cli/meson.build
@@ -0,0 +1,162 @@
+gobject = dependency('gobject-2.0')
+gio = dependency('gio-2.0')
+gthread = dependency('gthread-2.0')
+libalpm = dependency('libalpm')
+json = dependency('json-glib-1.0')
+libsoup = dependency('libsoup-2.4')
+polkit = dependency('polkit-gobject-1')
+# libnotify = dependency('libnotify')
+appstream = dependency('appstream-glib')
+# gio_unix = dependency('gio-unix-2.0')
+# gtk3 = dependency('gtk+-3.0', version : '>=3.22')
+# gdk3 = dependency('gdk-3.0')
+# gdk_pixbuf2 = dependency('gdk-pixbuf-2.0')
+gmodule = dependency('gmodule-2.0')
+posix = meson.get_compiler('vala').find_library('posix')
+math = meson.get_compiler('c').find_library('m')
+vala_deps = [gobject]
+alpm_deps = [libalpm, gio, posix]
+alpm_c_args = ['-D_FILE_OFFSET_BITS=64']
+common_vala_args = ['--pkg=posix', '--target-glib=2.38', '--vapidir=' + join_paths(meson.source_root(), 'vapi')]
+common_c_args = ['-DGETTEXT_PACKAGE="pamac"']
+common_sources = ['package.vala', 'alpm_package.vala', 'pamac_config.vala']
+# transaction_gtk_sources = ['transaction-gtk.vala', 'choose_provider_dialog.vala', 'choose_pkgs_dialog.vala',
+# 'transaction_sum_dialog.vala', 'progress_box.vala']
+# preferences_sources = ['preferences_dialog.vala']
+libpamac_sources = [common_sources, 'version.vala', 'alpm_config.vala', 'aur.vala', 'database.vala',
+ 'transaction_interface.vala', 'alpm_utils.vala', 'transaction_interface_root.vala',
+ 'daemon_interface.vala', 'transaction_interface_daemon.vala', 'transaction.vala',
+ 'updates_checker.vala', 'plugin_loader.vala', 'snap_interface.vala', 'flatpak_interface.vala']
+libpamac_dependencies = [alpm_deps, math, json, appstream, libsoup, gmodule]
+# libpamac_dependencies = [alpm_deps, math, json, appstream, libsoup, libnotify, gmodule]
+if get_option('enable-snap')
+ snapd = dependency('snapd-glib')
+ libpamac_snap = library('pamac-snap',
+ sources: ['snap_interface.vala', 'snap_plugin.vala', 'package.vala'],
+ vala_args: common_vala_args,
+ c_args: common_c_args,
+ dependencies: [gio, math, snapd, gmodule],
+ install: true,
+ install_dir: [true, true, true])
+ common_vala_args += '--define=ENABLE_SNAP'
+endif
+if get_option('enable-flatpak')
+ flatpak = dependency('flatpak')
+ libpamac_flatpak = library('pamac-flatpak',
+ sources: ['flatpak_interface.vala', 'flatpak_plugin.vala', 'package.vala'],
+ dependencies: [gio, math, flatpak, appstream, gmodule],
+ install: true,
+ common_vala_args += '--define=ENABLE_FLATPAK'
+endif
+libpamac = library('pamac',
+ sources: libpamac_sources,
+ dependencies: libpamac_dependencies,
+ c_args: [common_c_args, alpm_c_args],
+ vala_gir: 'Pamac-10.0.gir',
+ install: true,
+ install_dir: [true, true, true, true])
+# create pkg-config file
+pkg = import('pkgconfig')
+pkg.generate(libpamac,
+ description: 'Pamac Library')
+# create typelib files
+g_ir_compiler = find_program('g-ir-compiler')
+custom_target('pamac typelib', command: [g_ir_compiler, '--shared-library', 'libpamac', '--output', '@OUTPUT@', join_paths(meson.current_build_dir(), 'Pamac-10.0.gir')],
+ output: 'Pamac-10.0.typelib',
+ depends: libpamac,
+ install: true,
+ install_dir: join_paths(get_option('libdir'), 'girepository-1.0'))
+libpamac_dep = declare_dependency(link_with: libpamac)
+daemon_sources = ['version.vala', 'package.vala', 'alpm_package.vala', 'aur.vala', 'alpm_utils.vala',
+ 'alpm_config.vala', 'pamac_config_daemon.vala', 'daemon.vala', 'plugin_loader.vala',
+ 'snap_interface.vala', 'flatpak_interface.vala']
+daemon_dependencies = [vala_deps, alpm_deps, json, math, libsoup, polkit, appstream, gmodule]
+executable('pamac-daemon',
+ sources: daemon_sources,
+ dependencies: daemon_dependencies,
+ install : true)
+executable('pamac',
+ sources: ['version.vala', 'transaction-cli.vala', 'cli.vala'],
+ dependencies: [gio, posix, math, libpamac_dep],
+ vala_args: [common_vala_args, '--pkg=linux'],
+ install: true)
+# executable('pamac-tray',
+# sources: ['tray.vala', 'tray-gtk.vala'],
+# dependencies: [gtk3, libnotify, libpamac_dep],
+# vala_args: common_vala_args,
+# c_args: common_c_args,
+# install: true)
+# libpamac_gtk = library('pamac-gtk',
+# sources: [transaction_gtk_sources, transaction_resources],
+# dependencies: [gio, gtk3, posix, math, libpamac_dep],
+# install: true,
+# install_dir: [true, true, true])
+#libpamac_gtk_dep = declare_dependency(link_with: libpamac_gtk)
+# executable('pamac-manager',
+# sources: ['version.vala', 'history_dialog.vala', 'updates_dialog.vala', preferences_sources, 'local_config.vala', 'package_row.vala', 'manager_window.vala', 'manager.vala', 'search-provider.vala', manager_resources],
+# dependencies: [gtk3, libsoup, gio_unix, libpamac_dep, libpamac_gtk_dep],
+# install: true)
+# if get_option('enable-fake-gnome-software')
+# executable('gnome-software',
+# sources: ['fake_gnome_software.vala'],
+# dependencies: [gio],
+# install: true)
+# endif
+# executable('pamac-installer',
+# sources: ['progress_dialog.vala', 'installer.vala', installer_resources],
+# dependencies: [gtk3, gio_unix, libpamac_dep, libpamac_gtk_dep],
+# install: true)
+executable('dependency-checker',
+ sources: ['alpm_config.vala', 'dependency_checker.vala'],
+ dependencies: [vala_deps, alpm_deps],
+ install : true)
+executable('outdated-checker',
+ sources: ['alpm_config.vala', 'outdated_checker.vala'],
+ install : true)
==> Proceed with install? [Y/n]
:: (1/3) Parsing SRCINFO: lagrange
:: (2/3) Parsing SRCINFO: nordvpn-bin
:: (3/3) Parsing SRCINFO: pamac-cli
==> Making package: lagrange 1.0.0-1 (Sun 20 Dec 2020 12:02:29 PM CST)
==> Retrieving sources...
-> Downloading lagrange-1.0.0.tar.gz...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 72 100 72 0 0 12 0 0:00:06 0:00:05 0:00:01 18
100 13.4M 0 13.4M 0 0 325k 0 --:--:-- 0:00:42 --:--:-- 372k
==> Validating source files with md5sums...
lagrange-1.0.0.tar.gz ... Passed
==> Making package: nordvpn-bin 3.8.8-4 (Sun 20 Dec 2020 12:03:15 PM CST)
-> Found nordvpn_3.8.8_amd64.deb
==> Validating source_x86_64 files with sha256sums...
nordvpn_3.8.8_amd64.deb ... Passed
==> Making package: pamac-cli 10.0.0-1 (Sun 20 Dec 2020 12:03:20 PM CST)
-> Downloading pamac-10.0.0-1.tar.gz...
100 832k 100 832k 0 0 85891 0 0:00:09 0:00:09 --:--:-- 202k
-> Found meson.build
pamac-10.0.0-1.tar.gz ... Passed
meson.build ... Passed
==> Making package: lagrange 1.0.0-1 (Sun 20 Dec 2020 12:03:31 PM CST)
-> Found lagrange-1.0.0.tar.gz
==> Extracting sources...
-> Extracting lagrange-1.0.0.tar.gz with bsdtar
==> Sources are ready.
==> Making package: lagrange 1.0.0-1 (Sun 20 Dec 2020 12:03:33 PM CST)
==> WARNING: Using existing $srcdir/ tree
==> Starting build()...
-- The C compiler identification is GNU 10.2.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Compiling bincat for merging resource files...
-- Configuring done
-- Generating done
-- Build files have been written to: /home/chewie/.cache/yay/lagrange/src/build/res
Scanning dependencies of target bincat
[ 50%] Building C object CMakeFiles/bincat.dir/bincat.c.o
[100%] Linking C executable bincat
[100%] Built target bincat
-- CPU supports SSE 4.1
-- Found PkgConfig: /usr/bin/pkg-config (found version "1.7.3")
-- Checking for module 'zlib'
-- Found zlib, version 1.2.11
-- Checking for module 'libpcre'
-- Found libpcre, version 8.44
-- Checking for module 'eopenssl11'
-- Package 'eopenssl11', required by 'virtual:world', not found
-- Checking for module 'openssl'
-- Found openssl, version 1.1.1h
-- Looking for strnstr
-- Looking for strnstr - not found
-- Looking for sys/dirent.h
-- Looking for sys/dirent.h - not found
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Looking for threads.h
-- Looking for threads.h - found
-- Looking for smmintrin.h
-- Looking for smmintrin.h - found
-- Check if the system is big endian
-- Searching 16 bit integer
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of unsigned short
-- Check size of unsigned short - done
-- Searching 16 bit integer - Using unsigned short
-- Check if the system is big endian - little endian
-- Checking for module 'sdl2'
-- Found sdl2, version 2.0.12
-- Checking for module 'libmpg123'
-- Found libmpg123, version 1.26.3
-- Preparing embedded resources...
-- Configuring done
-- Generating done
make: Entering directory '/home/chewie/.cache/yay/lagrange/src/build'
make[1]: Entering directory '/home/chewie/.cache/yay/lagrange/src/build'
make[2]: Entering directory '/home/chewie/.cache/yay/lagrange/src/build'
Scanning dependencies of target the_Foundation
make[2]: Leaving directory '/home/chewie/.cache/yay/lagrange/src/build'
[ 1%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/audience.c.o
[ 2%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/array.c.o
[ 3%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/the_foundation.c.o
[ 4%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/block.c.o
[ 5%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/blockhash.c.o
[ 6%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/buffer.c.o
[ 7%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/class.c.o
[ 8%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/commandline.c.o
[ 9%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/crc32.c.o
[ 10%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/file.c.o
[ 11%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/fileinfo.c.o
[ 12%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/future.c.o
[ 13%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/garbage.c.o
[ 14%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/geometry.c.o
[ 15%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/hash.c.o
[ 17%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/intset.c.o
[ 19%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/map.c.o
[ 19%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/list.c.o
[ 20%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/md5.c.o
[ 21%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/mutex.c.o
[ 22%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/math.c.o
[ 23%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/math_sse.c.o
[ 24%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/noise.c.o
[ 25%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/object.c.o
[ 26%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/objectlist.c.o
[ 27%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/path.c.o
[ 28%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/ptrarray.c.o
[ 29%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/ptrset.c.o
[ 30%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/punycode.c.o
[ 31%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/random.c.o
[ 32%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/rect.c.o
[ 34%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/queue.c.o
[ 35%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/sortedarray.c.o
[ 36%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/stream.c.o
[ 37%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/string.c.o
[ 38%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/stringarray.c.o
[ 39%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/stringlist.c.o
[ 40%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/stringhash.c.o
[ 41%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/stringset.c.o
[ 42%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/thread.c.o
[ 43%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/threadpool.c.o
[ 44%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/time.c.o
[ 45%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/version.c.o
[ 46%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/platform/linux.c.o
[ 47%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/platform/posix/address.c.o
[ 48%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/platform/posix/datagram.c.o
[ 50%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/platform/posix/locale.c.o
[ 51%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/platform/posix/pipe.c.o
[ 52%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/platform/posix/process.c.o
[ 53%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/platform/posix/service.c.o
[ 54%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/platform/posix/socket.c.o
[ 55%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/regexp.c.o
[ 56%] Building C object lib/the_Foundation/CMakeFiles/the_Foundation.dir/src/tlsrequest.c.o
[ 57%] Linking C static library lib_Foundation.a
[ 57%] Built target the_Foundation
Scanning dependencies of target app
[ 58%] Building C object CMakeFiles/app.dir/src/main.c.o
[ 59%] Building C object CMakeFiles/app.dir/src/bookmarks.c.o
[ 60%] Building C object CMakeFiles/app.dir/src/feeds.c.o
[ 61%] Building C object CMakeFiles/app.dir/src/app.c.o
[ 62%] Building C object CMakeFiles/app.dir/src/gmcerts.c.o
[ 63%] Building C object CMakeFiles/app.dir/src/gmdocument.c.o
[ 64%] Building C object CMakeFiles/app.dir/src/gmrequest.c.o
[ 65%] Building C object CMakeFiles/app.dir/src/gmutil.c.o
[ 67%] Building C object CMakeFiles/app.dir/src/gopher.c.o
[ 68%] Building C object CMakeFiles/app.dir/src/history.c.o
[ 69%] Building C object CMakeFiles/app.dir/src/media.c.o
[ 70%] Building C object CMakeFiles/app.dir/src/lookup.c.o
[ 71%] Building C object CMakeFiles/app.dir/src/mimehooks.c.o
[ 72%] Building C object CMakeFiles/app.dir/src/prefs.c.o
[ 73%] Building C object CMakeFiles/app.dir/src/visited.c.o
[ 74%] Building C object CMakeFiles/app.dir/src/audio/buf.c.o
[ 75%] Building C object CMakeFiles/app.dir/src/audio/player.c.o
[ 76%] Building C object CMakeFiles/app.dir/src/audio/stb_vorbis.c.o
[ 77%] Building C object CMakeFiles/app.dir/src/ui/bindingswidget.c.o
[ 78%] Building C object CMakeFiles/app.dir/src/ui/color.c.o
[ 79%] Building C object CMakeFiles/app.dir/src/ui/command.c.o
[ 80%] Building C object CMakeFiles/app.dir/src/ui/documentwidget.c.o
[ 81%] Building C object CMakeFiles/app.dir/src/ui/indicatorwidget.c.o
[ 82%] Building C object CMakeFiles/app.dir/src/ui/listwidget.c.o
[ 84%] Building C object CMakeFiles/app.dir/src/ui/lookupwidget.c.o
[ 85%] Building C object CMakeFiles/app.dir/src/ui/keys.c.o
[ 86%] Building C object CMakeFiles/app.dir/src/ui/metrics.c.o
[ 87%] Building C object CMakeFiles/app.dir/src/ui/paint.c.o
[ 88%] Building C object CMakeFiles/app.dir/src/ui/playerui.c.o
[ 89%] Building C object CMakeFiles/app.dir/src/ui/scrollwidget.c.o
[ 90%] Building C object CMakeFiles/app.dir/src/ui/sidebarwidget.c.o
[ 91%] Building C object CMakeFiles/app.dir/src/ui/text.c.o
[ 92%] Building C object CMakeFiles/app.dir/src/ui/util.c.o
[ 93%] Building C object CMakeFiles/app.dir/src/ui/visbuf.c.o
[ 94%] Building C object CMakeFiles/app.dir/src/ui/window.c.o
[ 95%] Building C object CMakeFiles/app.dir/src/ui/widget.c.o
[ 96%] Building C object CMakeFiles/app.dir/src/ui/inputwidget.c.o
[ 97%] Building C object CMakeFiles/app.dir/src/ui/labelwidget.c.o
[ 98%] Building C object CMakeFiles/app.dir/embedded.c.o
[100%] Linking C executable lagrange
[100%] Built target app
make[1]: Leaving directory '/home/chewie/.cache/yay/lagrange/src/build'
make: Leaving directory '/home/chewie/.cache/yay/lagrange/src/build'
==> Entering fakeroot environment...
==> Starting package()...
Install the project...
-- Install configuration: "None"
-- Installing: /home/chewie/.cache/yay/lagrange/pkg/lagrange/usr/bin/lagrange
-- Installing: /home/chewie/.cache/yay/lagrange/pkg/lagrange/usr/share/applications/fi.skyjake.lagrange.desktop
-- Installing: /home/chewie/.cache/yay/lagrange/pkg/lagrange/usr/share/icons/hicolor/256x256/apps/fi.skyjake.lagrange.png
-- Installing: /home/chewie/.cache/yay/lagrange/pkg/lagrange/usr/share/lagrange/resources.binary
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> WARNING: Package contains reference to $srcdir
usr/bin/lagrange
==> Creating package "lagrange"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: lagrange 1.0.0-1 (Sun 20 Dec 2020 12:03:53 PM CST)
==> Cleaning up...
loading packages...
Packages (1) lagrange-1.0.0-1
Total Installed Size: 19.76 MiB
Net Upgrade Size: 0.02 MiB
(1/1) upgrading lagrange [######################] 100%
(1/3) Arming ConditionNeedsUpdate...
(2/3) Updating icon theme caches...
(3/3) Updating the desktop file MIME type cache...
==> Making package: nordvpn-bin 3.8.8-4 (Sun 20 Dec 2020 12:03:56 PM CST)
-> Extracting nordvpn_3.8.8_amd64.deb with bsdtar
==> Making package: nordvpn-bin 3.8.8-4 (Sun 20 Dec 2020 12:04:02 PM CST)
==> Creating package "nordvpn-bin"...
-> Adding install file...
==> Finished making: nordvpn-bin 3.8.8-4 (Sun 20 Dec 2020 12:04:09 PM CST)
==> Cleaning up...
loading packages...
Packages (1) nordvpn-bin-3.8.8-4
Total Installed Size: 37.54 MiB
(1/1) upgrading nordvpn-bin [######################] 100%
reboot
(1/4) Creating system user accounts...
(2/4) Reloading system manager configuration...
(3/4) Creating temporary files...
(4/4) Arming ConditionNeedsUpdate...
==> Making package: pamac-cli 10.0.0-1 (Sun 20 Dec 2020 12:04:14 PM CST)
-> Found pamac-10.0.0-1.tar.gz
-> Extracting pamac-10.0.0-1.tar.gz with bsdtar
==> Starting prepare()...
==> Making package: pamac-cli 10.0.0-1 (Sun 20 Dec 2020 12:04:22 PM CST)
The Meson build system
Version: 0.56.0
Source dir: /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d
Build dir: /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir
Build type: native build
Project name: pamac
Project version: 10.0
Using 'CFLAGS' from environment with value: '-march=x86-64 -mtune=generic -O2 -pipe -fno-plt'
Using 'LDFLAGS' from environment with value: '-Wl,-O1,--sort-common,--as-needed,-z,relro,-z,now'
Using 'CPPFLAGS' from environment with value: '-D_FORTIFY_SOURCE=2'
C compiler for the host machine: cc (gcc 10.2.0 "cc (GCC) 10.2.0")
C linker for the host machine: cc ld.bfd 2.35.1
Vala compiler for the host machine: valac (valac 0.50.2)
Host machine cpu family: x86_64
Host machine cpu: x86_64
Found pkg-config: /usr/bin/pkg-config (1.7.3)
Program glib-compile-resources found: YES (/usr/bin/glib-compile-resources)
Run-time dependency gobject-2.0 found: YES 2.66.2
Run-time dependency gio-2.0 found: YES 2.66.2
Run-time dependency gthread-2.0 found: YES 2.66.2
Run-time dependency libalpm found: YES 12.0.2
Run-time dependency json-glib-1.0 found: YES 1.6.0
Run-time dependency libsoup-2.4 found: YES 2.72.0
Run-time dependency polkit-gobject-1 found: YES 0.118
Run-time dependency appstream-glib found: YES 0.7.18
Run-time dependency gmodule-2.0 found: YES 2.66.2
Library posix found: YES
Library m found: YES
Program g-ir-compiler found: YES (/usr/bin/g-ir-compiler)
Configuring org.manjaro.pamac.manager.service using configuration
Configuring org.manjaro.pamac.daemon.service using configuration
Configuring pamac-daemon.service using configuration
Configuring pamac-cleancache.service using configuration
Program pacman-mirrors found: YES (/usr/bin/pacman-mirrors)
Program a2x found: YES (/usr/bin/a2x)
Program gzip found: YES (/usr/bin/gzip)
Build targets in project: 20
Found ninja-1.10.1 at /usr/bin/ninja
Generating targets: 0%| | 0 Writing build.ninja: 0%| | 0 [1/52] Compiling Vala source ../src/al...ig.vala ../src/dependency_checker.vala
../src/alpm_config.vala:348.2-348.18: warning: method `AlpmConfig.write' never used
public void write (HashTable<string,Variant> new_conf) {
Compilation succeeded - 1 warning(s)
[2/52] Compiling Vala source ../src/al...nfig.vala ../src/outdated_checker.vala
[6/52] Compiling Vala source ../src/ve...ace.vala ../src/flatpak_interface.vala
../src/alpm_package.vala:127.3-127.26: warning: method `Pamac.AlpmPackage.set_as_app' never used
internal void set_as_app (As.App? as_app) {
../src/alpm_package.vala:1274.3-1274.36: warning: method `Pamac.AURPackageLinked.initialise_from_json' never used
internal void initialise_from_json (Json.Object? json_object, AUR? aur, Alpm.Package? local_pkg, bool is_update = false) {
../src/aur.vala:121.3-121.50: warning: method `Pamac.AUR.get_multi_infos' never used
public GenericArray<Json.Object> get_multi_infos (string[] pkgnames) {
../src/aur.vala:150.3-150.41: warning: method `Pamac.AUR.search' never used
public GenericArray<Json.Object> search (string search_string) {
../src/alpm_utils.vala:913.3-913.33: warning: method `Pamac.AlpmUtils.trans_check_prepare' never used
public bool trans_check_prepare (bool sysupgrade,
../src/snap_interface.vala:32.3-32.35: warning: method `Pamac.SnapPlugin.search_snaps' never used
public abstract void search_snaps (string search_string, ref GenericArray<unowned SnapPackage> pkgs);
../src/snap_interface.vala:33.3-33.52: warning: method `Pamac.SnapPlugin.search_uninstalled_snaps_sync' never used
public abstract void search_uninstalled_snaps_sync (string search_string, ref GenericArray<unowned SnapPackage> pkgs);
../src/snap_interface.vala:34.3-34.40: warning: method `Pamac.SnapPlugin.is_installed_snap' never used
public abstract bool is_installed_snap (string name);
../src/snap_interface.vala:35.3-35.39: warning: method `Pamac.SnapPlugin.get_snap' never used
public abstract SnapPackage? get_snap (string name);
../src/snap_interface.vala:36.3-36.49: warning: method `Pamac.SnapPlugin.get_snap_by_app_id' never used
public abstract SnapPackage? get_snap_by_app_id (string app_id);
../src/snap_interface.vala:37.3-37.42: warning: method `Pamac.SnapPlugin.get_installed_snaps' never used
public abstract void get_installed_snaps (ref GenericArray<unowned SnapPackage> pkgs);
../src/snap_interface.vala:38.3-38.48: warning: method `Pamac.SnapPlugin.get_installed_snap_icon' never used
public abstract string get_installed_snap_icon (string name) throws Error;
../src/snap_interface.vala:39.3-39.41: warning: method `Pamac.SnapPlugin.get_category_snaps' never used
public abstract void get_category_snaps (string category, ref GenericArray<unowned SnapPackage> pkgs);
../src/snap_interface.vala:43.3-43.30: warning: method `Pamac.SnapPlugin.refresh' never used
public abstract void refresh ();
../src/flatpak_interface.vala:30.3-30.42: warning: method `Pamac.FlatpakPlugin.load_appstream_data' never used
public abstract void load_appstream_data ();
../src/flatpak_interface.vala:31.3-31.40: warning: method `Pamac.FlatpakPlugin.get_remotes_names' never used
public abstract void get_remotes_names (ref GenericArray<unowned string> remotes_names);
../src/flatpak_interface.vala:32.3-32.38: warning: method `Pamac.FlatpakPlugin.search_flatpaks' never used
public abstract void search_flatpaks (string search_string, ref GenericArray<unowned FlatpakPackage> pkgs);
../src/flatpak_interface.vala:33.3-33.55: warning: method `Pamac.FlatpakPlugin.search_uninstalled_flatpaks_sync' never used
public abstract void search_uninstalled_flatpaks_sync (string[] search_terms, ref GenericArray<unowned FlatpakPackage> pkgs);
../src/flatpak_interface.vala:34.3-34.43: warning: method `Pamac.FlatpakPlugin.is_installed_flatpak' never used
public abstract bool is_installed_flatpak (string name);
../src/flatpak_interface.vala:35.3-35.55: warning: method `Pamac.FlatpakPlugin.get_flatpak_by_app_id' never used
public abstract FlatpakPackage? get_flatpak_by_app_id (string app_id);
../src/flatpak_interface.vala:36.3-36.45: warning: method `Pamac.FlatpakPlugin.get_flatpak' never used
public abstract FlatpakPackage? get_flatpak (string id);
../src/flatpak_interface.vala:37.3-37.45: warning: method `Pamac.FlatpakPlugin.get_installed_flatpaks' never used
public abstract void get_installed_flatpaks (ref GenericArray<unowned FlatpakPackage> pkgs);
../src/flatpak_interface.vala:38.3-38.44: warning: method `Pamac.FlatpakPlugin.get_category_flatpaks' never used
public abstract void get_category_flatpaks (string category, ref GenericArray<unowned FlatpakPackage> pkgs);
../src/flatpak_interface.vala:39.3-39.42: warning: method `Pamac.FlatpakPlugin.get_flatpak_updates' never used
public abstract void get_flatpak_updates (ref GenericArray<unowned FlatpakPackage> pkgs);
../src/flatpak_interface.vala:42.3-42.30: warning: method `Pamac.FlatpakPlugin.refresh' never used
Compilation succeeded - 25 warning(s)
[9/52] Compiling Vala source ../src/pa...ace.vala ../src/flatpak_interface.vala
../src/alpm_utils.vala:657.3-657.28: warning: method `Pamac.AlpmUtils.download_pkg' never used
public string download_pkg (string sender, string url) {
../src/snap_interface.vala:40.3-40.32: warning: method `Pamac.SnapPlugin.trans_run' never used
public abstract bool trans_run (string sender, string[] to_install, string[] to_remove);
../src/snap_interface.vala:41.3-41.37: warning: method `Pamac.SnapPlugin.switch_channel' never used
public abstract bool switch_channel (string sender, string name, string channel);
../src/snap_interface.vala:42.3-42.35: warning: method `Pamac.SnapPlugin.trans_cancel' never used
public abstract void trans_cancel (string sender);
../src/flatpak_interface.vala:40.3-40.32: warning: method `Pamac.FlatpakPlugin.trans_run' never used
public abstract bool trans_run (string sender, string[] to_install, string[] to_remove, string[] to_upgrade);
../src/flatpak_interface.vala:41.3-41.35: warning: method `Pamac.FlatpakPlugin.trans_cancel' never used
Compilation succeeded - 9 warning(s)
[52/52] Linking target src/pamac
[0/1] Installing files.
Installing subdir /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/gnome-shell/pamac-updates@manjaro.org to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/gnome-shell/extensions/pamac-updates@manjaro.org
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/gnome-shell/pamac-updates@manjaro.org/README.md to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/gnome-shell/extensions/pamac-updates@manjaro.org
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/gnome-shell/pamac-updates@manjaro.org/metadata.json to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/gnome-shell/extensions/pamac-updates@manjaro.org
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/gnome-shell/pamac-updates@manjaro.org/extension.js to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/gnome-shell/extensions/pamac-updates@manjaro.org
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/gnome-shell/pamac-updates@manjaro.org/stylesheet.css to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/gnome-shell/extensions/pamac-updates@manjaro.org
Installing subdir /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/icons/hicolor to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/icons/hicolor
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/icons/hicolor/scalable/status/pamac-tray-no-update.svg to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/icons/hicolor/scalable/status
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/icons/hicolor/scalable/status/pamac-tray-update.svg to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/icons/hicolor/scalable/status
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/icons/hicolor/16x16/apps/system-software-install.svg to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/icons/hicolor/16x16/apps
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/icons/hicolor/48x48/apps/system-software-install.svg to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/icons/hicolor/48x48/apps
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/icons/hicolor/32x32/apps/system-software-install.svg to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/icons/hicolor/32x32/apps
Installing src/libpamac.so to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/lib
Installing src/pamac.h to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/include
Installing src/pamac.vapi to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/vala/vapi
Installing src/Pamac-10.0.gir to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/gir-1.0
Installing src/Pamac-10.0.typelib to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/lib/girepository-1.0
Installing src/pamac-daemon to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/bin
Installing src/pamac to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/bin
Installing src/dependency-checker to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/bin
Installing src/outdated-checker to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/bin
Installing data/polkit/org.manjaro.pamac.policy to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/polkit-1/actions
Installing data/doc/pamac.8.gz to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/man/man8
Installing data/doc/pamac.conf.5.gz to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/man/man5
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/meson-private/pamac.pc to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/lib/pkgconfig
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/applications/pamac-installer.desktop to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/applications
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/applications/org.manjaro.pamac.manager.desktop to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/applications
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/applications/pamac-tray.desktop to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/etc/xdg/autostart
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/applications/pamac-tray-budgie.desktop to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/etc/xdg/autostart
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/config/pamac.conf to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/etc
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/data/dbus/org.manjaro.pamac.manager.service to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/dbus-1/services
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/data/dbus/org.manjaro.pamac.daemon.service to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/dbus-1/system-services
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/dbus/org.manjaro.pamac.daemon.conf to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/etc/dbus-1/system.d
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/gnome-shell/org.manjaro.pamac.manager.search-provider.ini to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/gnome-shell/search-providers
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/mime/x-alpm-package.xml to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/mime/packages
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/data/systemd/pamac-daemon.service to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/lib/systemd/system
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/data/systemd/pamac-cleancache.service to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/lib/systemd/system
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/systemd/pamac-cleancache.timer to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/lib/systemd/system
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/systemd/pamac-mirrorlist.service to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/lib/systemd/system
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/data/systemd/pamac-mirrorlist.timer to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/lib/systemd/system
Running custom install script '/usr/bin/meson --internal gettext install --subdir=po --localedir=share/locale --pkgname=pamac'
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/af.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/af/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/ar.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/ar/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/ast.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/ast/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/az_AZ.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/az_AZ/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/be.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/be/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/bg.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/bg/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/bn.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/bn/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/bs.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/bs/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/ca.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/ca/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/ca@valencia.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/ca@valencia/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/cs.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/cs/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/cy.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/cy/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/da.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/da/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/de.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/de/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/de_CH.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/de_CH/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/de_DE.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/de_DE/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/el.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/el/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/el_GR.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/el_GR/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/en_GB.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/en_GB/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/eo.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/eo/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/es.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/es/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/es_419.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/es_419/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/es_AR.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/es_AR/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/es_ES.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/es_ES/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/es_MX.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/es_MX/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/es_SV.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/es_SV/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/et.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/et/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/eu.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/eu/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/fa.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/fa/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/fa_IR.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/fa_IR/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/fi.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/fi/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/fo.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/fo/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/fr.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/fr/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/gl.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/gl/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/gl_ES.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/gl_ES/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/gug_PY.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/gug_PY/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/he.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/he/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/he_IL.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/he_IL/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/hi.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/hi/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/hi_IN.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/hi_IN/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/hr.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/hr/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/hr_HR.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/hr_HR/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/hu.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/hu/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/id.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/id/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/ie.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/ie/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/is.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/is/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/is_IS.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/is_IS/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/it.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/it/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/ja.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/ja/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/ka.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/ka/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/kab.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/kab/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/kk.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/kk/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/ko.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/ko/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/lt.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/lt/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/ml.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/ml/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/ms.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/ms/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/nb.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/nb/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/nl.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/nl/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/nl_BE.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/nl_BE/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/nl_NL.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/nl_NL/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/nn.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/nn/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/or.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/or/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/pl.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/pl/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/pt.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/pt/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/pt_BR.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/pt_BR/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/pt_PT.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/pt_PT/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/ro.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/ro/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/ru.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/ru/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/si.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/si/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/sk.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/sk/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/sl.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/sl/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/sl_SI.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/sl_SI/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/sq.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/sq/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/sq_AL.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/sq_AL/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/sr.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/sr/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/sr@latin.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/sr@latin/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/sr_RS.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/sr_RS/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/sr_RS@latin.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/sr_RS@latin/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/sv.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/sv/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/sw.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/sw/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/tr.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/tr/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/uk.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/uk/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/ur_PK.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/ur_PK/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/uz.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/uz/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/vi.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/vi/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/zh.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/zh/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/zh_CN.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/zh_CN/LC_MESSAGES/pamac.mo
Installing /home/chewie/.cache/yay/pamac-cli/src/pamac-4431c12f2b7920ef437b9a30068f7a545d72549d/builddir/po/zh_TW.gmo to /home/chewie/.cache/yay/pamac-cli/pkg/pamac-cli/usr/share/locale/zh_TW/LC_MESSAGES/pamac.mo
-> Removing empty directories...
==> Creating package "pamac-cli"...
==> Finished making: pamac-cli 10.0.0-1 (Sun 20 Dec 2020 12:04:49 PM CST)
==> Cleaning up...
loading packages...
:: pamac-cli and pamac-gtk are in conflict (pamac). Remove pamac-gtk? [y/N] n
inxi -Fxxxza --no-host
$ inxi -Fxxxza --no-host
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=c3b1cff2-ed37-4ee0-af3b-d404097c96ef rw quiet
cryptdevice=UUID=eb7684b1-691d-476a-81d7-9f553231a205:luks-eb7684b1-691d-476a-81d7-9f553231a205
root=/dev/mapper/luks-eb7684b1-691d-476a-81d7-9f553231a205 apparmor=1
security=apparmor
resume=/dev/mapper/luks-1aa70ee5-d740-4f20-a0ae-699cefa5a54f
udev.log_priority=3
Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.38.2
Distro: Manjaro Linux
Type: Desktop System: Apple product: iMac12,1 v: 1.0 serial: <filter>
Chassis: type: 13 v: Mac-942B5BF58194151B serial: <filter>
Mobo: Apple model: Mac-942B5BF58194151B serial: <filter> UEFI: Apple
v: 87.0.0.0.0 date: 06/14/2019
Info: Quad Core model: Intel Core i5-2400S bits: 64 type: MCP
arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
L2 cache: 6144 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20010
Speed: 2844 MHz min/max: 1600/3300 MHz Core speeds (MHz): 1: 2844 2: 2966
3: 2842 4: 2811
Type: l1tf
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0102
Device-2: AMD Whistler [Radeon HD 6630M/6650M/6750M/7670M/7690M]
vendor: Apple driver: radeon v: kernel bus ID: 01:00.0 chip ID: 1002:6741
Device-3: Apple FaceTime HD Camera (Built-in) type: USB driver: uvcvideo
bus ID: 1-2:3 chip ID: 05ac:850b serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: gnome-shell
driver: ati,intel,radeon unloaded: modesetting alternate: fbdev,vesa
display ID: :1 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.0x11.3")
s-diag: 1055mm (41.6")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 103 size: 475x267mm (18.7x10.5")
diag: 545mm (21.5")
Monitor-2: DisplayPort-0 res: 1920x1080 hz: 60 dpi: 103
size: 475x267mm (18.7x10.5") diag: 545mm (21.5")
OpenGL: renderer: AMD TURKS (DRM 2.50.0 / 5.9.11-3-MANJARO LLVM 11.0.0)
v: 3.3 Mesa 20.2.3 compat-v: 3.1 direct render: Yes
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1c20
Device-2: AMD Turks HDMI Audio [Radeon HD 6500/6600 / 6700M Series]
vendor: Apple driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 1002:aa90
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Broadcom and subsidiaries NetXtreme BCM57765 Gigabit Ethernet
PCIe
driver: tg3 v: kernel port: 2000 bus ID: 02:00.0 chip ID: 14e4:16b4
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter
vendor: Apple AirPort Extreme driver: ath9k v: kernel port: 2000
bus ID: 03:00.0 chip ID: 168c:0030
IF: wlp3s0 state: down mac: <filter>
Local Storage: total: 8.64 TiB used: 6.04 TiB (69.9%)
ID-1: /dev/sda vendor: Western Digital model: WD5000AAKS-402AA0
size: 465.76 GiB block size: physical: 512 B logical: 512 B
speed: 3.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1D02 scheme: GPT
ID-2: /dev/sdb model: Mercury Electra 6G SSD size: 931.51 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 7B0
scheme: GPT
ID-3: /dev/sdd type: USB vendor: Western Digital model: WD Elements 25A3
size: 7.28 TiB block size: physical: 4096 B logical: 512 B
serial: <filter> rev: 1021 scheme: GPT
ID-1: / raw size: 918.37 GiB size: 902.95 GiB (98.32%)
used: 412.57 GiB (45.7%) fs: ext4 dev: /dev/dm-0
ID-1: swap-1 type: partition size: 12.85 GiB used: 1.37 GiB (10.7%)
priority: -2 dev: /dev/dm-1
System Temperatures: cpu: 58.0 C mobo: N/A
Fan Speeds (RPM): cpu: 1199
Processes: 313 Uptime: 6d 4h 01m Memory: 11.68 GiB used: 5.61 GiB (48.0%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 alt: 6 clang: 11.0.0 Packages:
pacman: 2158 lib: 431 flatpak: 0 Shell: Bash v: 5.0.18
running in: gnome-terminal inxi: 3.1.08
