JohnML
26 September 2021 14:33
1
This one does not work, because its a one liner?
pamac clean -k 0 -b --no-confirm
Its ok if i split this command in two lines:
#! /bin/sh
echo "pamac clean all caches"
# OHNE build Dateien
/usr/bin/pamac clean -v --no-confirm
# jetzt extra build-Dateien
/usr/bin/pamac clean -b -v --no-confirm
But why is not possible as a one liner?
Just curious.
I would not try to build a systemd service, run every day at 23 o’clock to clean all caches if i could tell pamac or pacman to avoid any use of cache!
-b : remove only aur cache
these 2 caches are very different
you can add 2 commands in an alias as “pacman clean -k 1 && pamac clean -b”
This service exists, and is enabled. You can override him
/usr/lib/systemd/system/pamac-cleancache.timer # run .service one run by month
/usr/lib/systemd/system/pamac-cleancache.service
cache aur or pacman ? not possible to not use cache (where download packages ?) we can only use /tmp/ if we have ram for that. Directory for pacman is in etc/pacman.conf
Do you lack so much space to consider these extremes?
JohnML
26 September 2021 15:06
3
I’m on stable branch and do a complete system-backup every night with backintime. So i never need that cache!
backup and clear “aur build cache” this cache is useful for update ! if you clear him : you not use it and so no raison to backup him
For pacman cache… as written, we have a active timer for clear it, you can change it (OnCalendar key)
Tip: When pasting terminal output on Discourse forums, one can either…
Highlight it and use the Preformatted text </> toolbar button.
Add three backticks ` above and below the text (Markdown):
text
Use HTML:
<pre><code>
text
</pre></code>
I’ve done it for you this time.
JohnML
26 September 2021 15:44
6
Thank you i have to remember these
Backticks
I’m nearly blind so i have huge fonts and small edit boxes where its really hard to mark text with mouse
JohnML
26 September 2021 16:20
7
I adjusted pamac-cleancache.timer and *.service to be run every day!
I’ll see tomorrow if that works, thank you for that tipp!
system
Closed
29 September 2021 06:20
8
