-> Downloading slimerjs-1.0.0.tar.bz2…
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0 > curl: (60) SSL certificate problem: unable to get local issuer certificate > More details here: curl - SSL CA Certificates
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
==> ERROR: Failure while downloading https://download.slimerjs.org/releases/1.0.0/slimerjs-1.0.0.tar.bz2
Aborting…
* Trying 87.98.141.92:443...
* Connected to download.slimerjs.org (87.98.141.92) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: /etc/ssl/certs/ca-certificates.crt
* CApath: none
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (OUT), TLS alert, unknown CA (560):
* SSL certificate problem: unable to get local issuer certificate
* Closing connection 0
More details here: https://curl.se/docs/sslcerts.html
Although the browser says it’s ok
Aha. root cert is missing. Most likely because in webserver config it does not use the fullchain cert.
git clone https://aur.archlinux.org/slimerjs.git
cd slimerjs
edit PKGBUILD, replace "source..." line with this: source=("${pkgname}-${pkgver}.tar.bz2")
Manually download https://download.slimerjs.org/releases/1.0.0/slimerjs-1.0.0.tar.bz2 and place it in the slimerjs folder
makepkg
sudo pacman -U slimerjs-1.0.0-1-any.pkg.tar.xz
